Question about Vacuums
Wont start heater light on but wont start
  • georgeriv839 Nov 03, 2012
    started when handle on floor runs for a minute and stops sounds weired it a bissel pro heat pet carpet shampo
    Top Expert:
  • Vacuums Master
  • 14,553 Answers
If you mean power light (a vacuum) what is the brand and model number?
Posted on Nov 03, 2012
Bissell preheat 9500 2 wont spray water
It is common for the heater cores to clog on these causing no spray. Take it to your local vac shop for bypass surgery . The heater does very little and with it bypassed you won't have any further trouble.
Jun 01, 2015 | Bissell Vacuums
Steamer problems
The light is connected to the heater if it is not working but the unit still gets hot the light may be faulty
If the unit does not get hot then there is a problem with the power getting to the heater element.
The fault may be in the switch
Aug 08, 2014 | Eureka 313A Stick Steam Cleaner
Lux 7000 vacuum cleaner power cord light is on and it wont start
Best case scenerio....check and replace the bag...try it. If no bag, it won't start. If that's not it, could be the on/off button or rocker needs replaced and worse case scenerio, the motor is OUT!... I can help! amerivac4u@yahoo.com
Jun 06, 2014 | Electrolux Lux 7000 Bagged Canister Vacuum
Roomba 4106 new battery charged but wont start
see the diodes, resistor, capacitor inside for test.
since the battery is new, the power charger is faulty, power regulator IC is bad.
God bless you
May 16, 2012 | Roomba 3005 Pro Robotic Vacuum
My Hometek Steam Penguin wont produce steam
Hi
I opened whole thing and found that no suction to the pump or pressure from the pump. Opened the clear box which contains the pump and the el-motor. Then I opened the white pump and found it was assembled wrong way round. There are two tiny one way silicon "valves" which should produce the flow of the water to the heater. I also wiped off part of the sticky grease away. Now it works. 4 hours work, but it was interesting to learn the function :) .
Anssi
Apr 09, 2012 | Euro-Pro Steam Penguin Hard Surface Steam...
My hot water heater won't engage at all.
Sounds like the pilot light is not staying lit, provided you have one. The pilot light is used to keep the gas valve open by way of the thermocouple/switch. When the pilot light goes out the thermocouple cools down and shuts the supply of gas off to the water heater burner. It is not unusual for a thermocouple to go bad at which point it needs to be replaced. The thermocouple is the small rod that sits in or close to the pilot light flame. There is a small copper tube that runs from it up to the gas valve on the outside of the tank. This is where you control the temperature of the water as well as light the pilot light. If you are not experienced in dealing with hot water heater gas supplies, you should get professional help.
Oct 14, 2010 | Vacuums
My bissell wont spray
Depending on which bissell you have; I would check the heater. If it is a newer module I would check the solenoid switch. The heater heats the soap up so much that it clumps the soap up and clogs both of these parts. I would also check the tips themselves to make sure that they are not clogged.
Aug 18, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
Cleaner suddenly stopped working
Based on the other solutions I read, I also traced the problem to clogged input/output ports to the heater. I hadn't used the cleaner for about 2 years and the ports were blocked by calcium and mineral deposits. I took the manifold cover off the bottom of the heater and carefully reamed the ports out with a finishing nail. I then cleaned the ports and manifold with Lime-Away to dissolve any other deposits. I put it back together (with no parts left over!) and it works fine.
Oct 15, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
