Question about Air Tools & Compressors
Pneumatic stapler trigger stuck
I have a rigid (home depot house brand) pneumatic stapler that has been used all of 5 times since purchased. I went to use it yesterday, hooked it up to my compressor, lined the stapler up with the material, pulled the trigger and instead of a nice pfffft of air and a staple being imbedded 2" into the wood where moments ago wasn't the trigger simply Clicked, it wasn't a dead trigger feeling like you get when pulling the trigger without an air connection, it like I said Clicked, you could feel the air pressure when pulling the trigger just none was released when the trigger pin was pushed in. The trigger pin remained in the pushed in position and the trigger itself without the pin pressed against it just flops about. I quickly disconnected the gun from the compressor envisioning an unwanted rapid firing of 2" staples being impaled into any unfortunate objects in their path due to the stuck open trigger even knowing it an improbable occurrence. Any thoughts as to what has happened to this barely used gun? Thanks Les
    President:
  • 1,388 Answers
The click sound indicates that the headvalve opened to fire piston down the barrel, however piston is already down or is stuck in-place. If the piston/driver is not broken or stuck, push piston to top of cylinder to reset. If only one shot and piston stays down, most likely the check band is broken. Check band is on the outside of cylinder (lower part) is is usually an oring or band of rubber covering small holes drilled into cylinder. Check valve /band is what causes the piston to return to top. If check band is good, most likely piston is bent or oring is too tight. If you open the gun, lube all parts with white grease or silicone paste lube. Good luck
Posted on Nov 08, 2012
2 Suggested Answers
  • 24 Answers
SOURCE: Makita AF503 Brad Nailer won't fire nail
Take head off of tool. Clean and lube orings on the head valve . Do not use wd40 use air nailer oil.
Posted on Apr 14, 2009
O ring for centralpneumatic nailer/stapler model 68019
Central Pneumatic is Harbor Freight's house brand.
For parts -
Harbor Freight Customer Service: 1-888-866-5797
Monday thru Friday, 5:00 am to 7:00 pm PST
Email: parts@harborfreight.com
Aug 20, 2017 | Air Tools & Compressors
Cant open jt27 staple gun to load staples
Hi Maria, I'm sorry you are not having luck with your JT27 stapler. Unfortunately you did not purchase the correct staples for this tool. The JT27 Stapler uses the JT21 staples in a green box. The staples come in 3 different sizes (1/4", 5/16", 3/8"). You can purchase these staples online or at your local Home Depot or Lowe's Store.
As for opening the tool - please see the attached picture for assistance.
May 07, 2015 | Arrow Tools & Hardware - Others
What is wrong with my Senco pneumatic upholstery stapler?
only a guess but is the anvil sticking out the bottom where the staples come out . if so push it up a little with a flat blade screw driver .
Feb 23, 2015 | Senco Tools & Hardware - Others
Ridgid 18v x3 saws
The battery may have a short in it. Take it back to Home Depot for a new one. Rigid has a lifetime warranty on their cordless products.
Aug 25, 2014 | Ridgid 18v Circular Saw X3 tool Only R865n...
What should I do if my brand new Fasco pneumatic upholstery stapler is leaking air through the tail end...not the hose, but the two holes in the handle? Any suggestions?
Hi Anonymus,
What's happened if the driver blade has stopped in mid stroke, the air will escape. Quickest was 'round this is to take the airline off the tool, then find some scrap wood, place the tool on it as though you're firing it, and in THIS ORDER... pull the trigger and re-connect the airline at the same time. This usually sorts this out. Regardless of the tool make and model this will happen to most users sometime....
Leigh Co Limited
May 25, 2014 | Fasco Tools & Hardware - Others
Stapler trigger stuck
Check for a trigger lock/bar that slides up or down to unlock trigger. If no lock, take a small flathead screw driver and jiggle it in the back of the trigger.
Aug 17, 2013 | Surebonder Pneumatic Stapler
Air leak from trigger in bostitch pneumatic stapler
you need to replace rubber o ring on the trigger shaft pretty easy fix o ring is real small to deal with but doable automotive part stores usuly have assorted size in trays you can take old one out match its size .
Mar 31, 2011 | Stanley Air Tools & Compressors
I have a Bostitch SB-150SX pneumatic stapler. It's about 5 yrs old. I've been using it for the last couple of days without any trouble. Then yesterday, it would not shoot. When I pull the trigger air...
Are you using air-tool oil before each use? Water or debris coming through the air hose can cause like problems. Try installing an in-line filter. Hope this helps!
Aug 13, 2010 | Garden
My Makita AT1150A stapler does not shoot any staples. Air comes out around the trigger when pressed but does not do anything else. What do I do to fix this problem?
Check to see if there is any foreign object jamming the striker bar. These units also have a diaphragm that sometimes needs to be replaced. If you do not have an automatic oiler on the line the diaphragm could have cracked allowing air to pass through. The Stapler can not build up the necessary pressure to fire the striker driving in the stapler. Damaged or cracked this will need to be replaced. Not difficult and easy to DIY job. Do NOT hook up to air when doing this service. Dirt and grim can also jam the unit. Clean lightly oil, work the unit and see if it frees up. I typically put a few drops of oil made for pneumatic tools directly into the unit. Each time I pull the pneumatic tools out to use. I do not have an inline oiler. :)
Typically at the Male nipple connection where the brass female connector hooks too. 2-3 drops only!
Hope this helps!
May 26, 2010 | Makita AT1150A 716inch Medium Crown...
MY PNEUMATIC STAPLE GUN WON'T WORK/ looses air through firing lever.How do I repair it? Where do I put the oil in?
I would agree with rowdy that the make and model number are essential to getting the right parts - If you have that information, just find a dealer that supports your brand. That being said, air leaking out the trigger area is likely to be an O-Ring or Seal problem. Pneumatic staplers have O-rings and Seals that need to be replaced periodically. Most have rebuild kits available that contain all the O-Rings and Seals that need to be replaced. Many staplers have O-rings and/or Seals on or near the trigger shaft that can wear and allow air to leak out
Mar 11, 2009 | Tools & Hardware - Others
Air Tools & Compressors Logo
143 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
