Pioneer PL-670 record rejects continually
I have a Pioneer PL-670 turntable. When I place a record on the player the needle will go over to the record sit down and then return to the arm rest without ever playing the record.
  • mcmalpas Apr 26, 2009
    The arm will not sit on the record. As soon as it is placed on the vinyl it clicks into 'record-is-finished' mode and immediately returns to the rest position without playing one single note. Hope someone knows how to help as I have spent a lot of money restoring this player.
Are the record size tabs sticking up through the turntable platter cover? They sense the size of the record being played and adjust the run out distance for either 45 or 33 rpm records.
Posted on Apr 10, 2009
Hi! I have a Pioneer PL 530 record player went on the fritZ!! Wont shut off?
Go to the vinylengine website. There are forums full of experienced users to help
Apr 07, 2015 | Pioneer Audio Players & Recorders
Pioneer Pl990 turntable sounds awful.... I have a pioneer pl 990 record player connected to a pioneer amplifier and a sony CD player. when I play an LP, the sound is bass heavy and I can hardly hear t
When the turntable plays, do you get a howling bass heavy sound? Have you tried turning down the volume and bass? If that corrects the problem, you have what's known as Acoustic Feedback. Check to make sure the tonearm is properly set up first. If it is, please visit my website at Audioserviceclinic.com. You may contact me there. Thank you.
Dec 13, 2014 | Pioneer PL-990 Turntable
Record player repair
The top arm that swings over the spindle will control the automatic return. Leave the unit off. Swing the overhead holding top arm over and manually load a record. Now switch the top arm over the niddle spindle. Make sure that the switch is set for 7", 10" or 12" (45, 78, or 33). Manually place the tonearm at the start of the record and flip switch to 'play' (not reject or auto). It should play the whole record and automatically eject at the end and then shut off. Leave the arm swung over the middle after you loaded the record. Good luck. Let me know if you have any more questions.
Aug 18, 2014 | Audio Players & Recorders
I've recently picked up a Pioneer Plx-88z turntable second hand. I know that the player is working ok as putting the arm on the record plays music. The problem is that after a few seconds, no matter what,...
Hi, if it's a second hand device. there must be something wrong with the arm at it's moving axe. if something (dust or broken support) is blocking it, it will return automatically to its rest position to avoid any damage to the fragile and sensible "head"
Jun 02, 2014 | Audio Players & Recorders
Pioneer pl a45d
Hi Javier,
How to change the belt? how to replace belt on pioneer pl x300 pioneer pl x50 turntable .
A place to find the belt. Pioneer PL A45 PL A45D Realistic LAB 1500 TURNTABLE BELT T245
Manual with schematics. Sign up and free. Pioneer PL A45 Manual 2 Speed Belt Drive Turntable Vinyl Engine
How to set it up after you put the belt on.
How to set up Turntable cartridge alignment overhang VTA VTF vibration...
Another look on how to change a belt on a turntable? How to Replace Turntable Belt on Belt Drive Turntable
It is straight forward. Patience. Fare. Well.
May 16, 2014 | Pioneer Audio Players & Recorders
My pioneer pl-200 doesn't play loud enough through my pioneer vsx-521-k receiver
The PL-200 has no pre amp and your VSX-521 has no phono input. You need an RIAA preamp.
Jul 11, 2017 | Pioneer Vsx-521-k 5.1 Channel A/v Home...
The arm will automatically return without playing the record
Hi Lisa, its a bit of a long shot however try this. With the turntable powered of manually rotate the platter approx 12 times to reset the auto operation back to default. John styluscity.com
Nov 28, 2011 | Audio Players & Recorders
Hello i have a pioneer pl-300 turntable. i bought it used and it's been working fine until today. now the needle skips ahead on the record. i am VERY inept with technical knowledge of turntables i just...
if its skipping ahead Almost like the needle is just gliding across the Record. It means your needle is bent, dirty or broken, Take it off and look at it closely.
May 30, 2011 | Pioneer Audio Players & Recorders
I have a Pioneer PL-740 turntable that works extremely well, except there is zero damping when either lifting or dropping (and I mean dropping) the needle. I know there is generally a hydraulic oil that...
most turntables actually only dampen during automatic play and return (eject) not when manually manipulating the needle. Better turntables will have a counterweight at the back of the arm behind the pivot point, but that is to decrease wear on the vinyl and increase needle life and audio fidelity in the higher end.
Some turntables have a lifter arm that is dampened, but if your player doesn't have such a mechanism, or if it has one and you choose to manually manipulate the needle without it's usage, there is no dampening.
The fix unfortunately is to buy a turntable with a dampened lifter arm, and to use the arm when lifting and lowering the needle.
Mar 23, 2011 | Pioneer Audio Players & Recorders
473 people viewed this question
 Grubhead
Grubhead
