Question about Toshiba e355 Pocket PC
Connect Toshiba pocket PC E355 to wireless internet
PDA is requiring an ISP username, phone number, password and domain. We have cable wireless internet connection. How can we get the Pocket PC to work with out wireless provider?
5 Suggested Answers
  • 903 Answers
SOURCE: Connect to the internet via
Once the Socketcom Bluetooth card is inserted in the Toshiba Pocket e570 PC and the software has been loaded, the following instructions will set up the Toshiba PDA & Ericsson T39 mobile phone to connect to the Internet. Click on the Bluetooth icon in the bottom right hand corner. Click on Get Connected! Select the device under My Bluetooth phone is: In this case the Ericsson T39. The following information gives details on how to change the name of the Mobile device. Once this has been read, click on Next. The phone now has to be made discoverable so that the PDA will detect it. To do this, use the down arrow on the phone to select Extras and then click on Yes. Scroll down to Bluetooth and Click on Yes. Select Make Discoverable and a message on the phone will appear saying that the phone is discoverable for the next 3 minutes. Click on Next on the PDA. The PDA will now look for a Bluetooth device(s). Once the mobile is detected the PDA will search for the Device Name of the mobile. Click on Select and the devices will not connect and create a partnership. The following Device Bonding window should appear to create a bond between the PDA and phone. Click on Next. To create the bond a passkey must be entered on the PDA. This may be a between a 4-16 digit code. N.B. We would advise that the code be kept to a numeric sequence as the keys contain more than one letter on them, i.e. for the letter L, the number 5 key will need to be depressed 3 times. Once the passkey is entered, click on the Reply button. On the mobile, click on Yes to accept the incoming pass and then enter the same passkey. Click on Yes again to confirm. If the two values are correct, a message will appear on the phone telling you that the devices are bonded. The PDA should now congratulate you on your connection. For Internet access via Bluetooth, please follow the steps outlined below. The above instructions only need to be carried out each time a connection is required. However, the instructions below only need to be setup once. Click on Start, then Settings from the drop down menu. Click on the Connections tab at the bottom of the screen followed by the Connections icon utility. In the first drop box labelled "When needed automatically connect to The Internet using these settings" select New. Under the General tab you will be prompted to give the new connection a name, e.g. Bluetooth. Select the modem "Bluetooth Phone" and click on Next Make sure that the fields for the boxes titled Country code and Area code, are empty. The next field requires the full telephone number, including STD code, you wish to dial, i.e. your ISP telephone number. Put this in and click on Next. The next page contains a time out clause if the PDA is unable to connect within a set time. By default this should be 120 seconds. Make sure the tick box for "Wait befo
Posted on Sep 07, 2005
  • 903 Answers
SOURCE: Toshiba e355. Wireless?
"Certain Pocket PC Models have SD or SDIO slots but are not compatible with the SDIO WLAN Card. These include: Toshiba e350 and e750 – these have SDIO slots but do not have SDIO Now! software from BSQUARE. The e355 is the same as the e350.
Posted on Sep 11, 2005
  • 903 Answers
SOURCE: Can I access internet on a Toshiba e355?
If your cellphone supplier won't demo it, then it's best to say it's not going to work. Instead, the outlook is that WiFi hotspots will be the way to go since you won't get soaked on cell charges.
AvioriX
  • 689 Answers
SOURCE: toshiba pda e310
you may proceed to http://pcrepair.toshiba.com
Locate the most convenient service center in your location. Call the service center to confirm the issue.
Good Luck
Posted on Feb 07, 2008
How do I set this router up with AT&T Internet?
Hi Friend,
Make sure that you have connected all the wires/cables to their respective ports/places. Please follow the steps:
1.Open web browser and type 192.168.1.1 and hit enter.
2.Enter admin as username and password.
3.Select the proper region.
For cable modem:
* For most cable modem users, you should be able to connect to the Internet without any
configuration. If your ISP has provided you with a host name, enter it in the optional Host
Name field.
* If your ISP requires a registered MAC Address, click on the Clone MAC Address button.
Click Apply and OK to save the setting.
* Go to Status tab, Internet connection section to verify if you get the valid IP address
information.
For DSL:
* Select PPPoE from the drop-down menu.
* Enter your username and password provided by your ISP.
Click Apply and OK to save the setting. Go to Status tab, Internet connection section to verify if you get the valid IP address information.
4.Click Wirless (to configure wireless settings).
SSID: Any name as per your choice.
Operating Mode: Infrastructure
Authentication: Open System
Channel #: 6
WEP: Enabled and type any ten digit number as your password. You can use this password whenever you try to connect your wireless devices.
I hope this will resolve the issue.
Regards
Chiranjeet
Dec 08, 2010 | Airlink AR430W Wireless Router
How do I prevent loosing data when my battery discharges
Hi. Actually, on pocket pcs there's a backup battery onboard, but in your case maybe backup battery is dead. So you can have that changed or you can charge your PDA on regular basis. Hope this helps.
Jun 28, 2009 | Toshiba e355 Pocket PC
I want the ethernet controller driver for my hp dv6000
hi im josh in cebu phils. may i help you?
Chapter 10: Troubleshooting Internet Connections Internet Connection Problem Overview Failure to connect to the Internet is a very common reason why people request service for their computers. We'll cover two main types of Internet connections here: dial-up and high speed. Each type has its own problems, with some overlap. The problems can be put into main categories:
  • You cannot connect to the Internet Service Provider (ISP).
  • You can connect to the ISP, but you can't open Web pages and/or use e-mail.
  • You can connect to the ISP and open Web pages and use e-mail, but your connection is very slow, and/or you get disconnected frequently.
There are many causes of each of these problems, too many to cover them all here. We will attempt to cover common problems here. However, as is the case with other problems, there are times that everything is set correctly, and the hardware is OK, but Internet connections still don't work. When this happens, it might be because of OS corruption serious enough to require a clean install, or it might be one of those Windows things that happens for no real reason, and sometimes resolves itself with no real reason either.
Note We don't cover wireless Internet specifically in this book, although some of the information in this chapter does apply to it.
When setting up or troubleshooting a connection, there are some simple rules to follow, as we discuss in the following sections.
Basic Connection Problems
  • Call the ISP first: There could be an outage in your area. There is no point in troubleshooting before you rule out an outage.
  • ISP settings: Every ISP has its own requirements and specifications for connection configuration. Make sure you follow them.
  • Username and password: Many connection problems could be avoided if users always used the correct username and password. This means that typos must be avoided and that the Caps Lock shouldn't be toggled on. In addition, some ISPs require you to enter your entire e-mail address (such as name@ domain.com) as a username, and some require only the username good luck
Mar 06, 2009 | Computers & Internet
I dont know haow to connect Linksys Wireless-G Broadband Router with SpeedBooster WRT54GS - wireless router
  1. Connect your modem to the Internet port of the router. Your computer needs to be connected to one of the 4 Ethernet ports at the back of the router.
  2. Access the router's setup page by launching Internet explorer and typing 192.168.1.1.
  3. It will ask for a username and password. Leave the username blank and password is admin.
  4. Once your in the setup page, set "Internet connection type" with what your ISP requires you to have.
  5. If you have cable ISP, usually it is "Automatic Configuration-DHCP."
  6. But if you have DSL ISP, then it will be PPPoE. You need to know your username and password from your ISP.
  7. Better yet, verify your Internet connection type from your Internet service provider.
Hope this helps!
Nov 09, 2008 | Computers & Internet
Can not connect to the internet in trying to setup the router.
Yes time warner is a cable connection and they dont require a username and pasword. You can set up the router manually by accessing its set up page. By default the router's IP is 192.168.2.1. Make sure to set the wan connection type to dynamic, change the wan mac address or clone your pc's mac. Then save the settings. Check your internet connection.
Aug 18, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
No owners manual
how to insertsim card in the 3g iphone
Jun 30, 2008 | Computers & Internet
Internet?
Please note that when you want to use pocket (IE) browser of your PPC (pocket PC) phone; you need to ensure GPRS setting has been made in your phone.
For GPRS setting (Example: Airtel India network) please do the following steps.
Start --> settings --> Connections(tab) --> Connections(icon) --> under My ISP tap on "Add a new modem connection" --> enter connection name: airtel --> select a modem: Cellular Line (GPRS) --> access point name: airtelgprs.com --> leave blank on username, password & domain --> Finish.
If you are using different network (sim card) then you need to get "access point name" information from them.
Dec 27, 2007 | i-mate PDAL Pocket PC
Sep 11, 2005 | Toshiba e355 Pocket PC
Sep 07, 2005 | Toshiba e570
Toshiba e355 Pocket PC Logo
53 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
