Question about Whirlpool Duet GHW9150P Front Load Washer
Philips Whirlpool 400 AWG 370 door is locked
The door is locked in my washing machine with wet clothes inside.
How to unlock it?
  • sseitani Jan 07, 2009
    unplug the washing machine
    I take the kick panel off from top and I reach down to the right side where the door lock is. there is not a release pull down that releases the door.It's a brown plastic with 3 cables orange, blue and brown attached and all over is fixed without found something to pull down to release.
    When I tried to open the door external my finger from inside touch a smal cnob that just moves in and out and nothing else is there to release.
    Any other suggestion for the model
    AWG 370
  • sseitani Jan 08, 2009
    Dear Egraber
    I appreciate your help, I follow your advice and the water came out from the bottom and the door is unlocked now.
    Thank you Very Much for your help
    God bless you
    Suzan
  • 530 Answers
Take the kick panel off and reach up the right side where the door lock is. there is a release pull down that releases the door.
Posted on Jan 04, 2009
  • 3 more comments
  • erica graber Jan 08, 2009
    Why is this comment inapropriate? If you cannot folloiw these instuctions, maybe you need to call a service technician. This is the way to open the door yes you pull the switch lever domn and pull the door open.
    The kick panel is at the bottom. aka bottom panel. The top is called the lid
    Also, is the unit not draining. If not the reason the door is locked is so water does not flood onto your floor. find the pump make sure that it is not clogged with debrie. Like socks etc...this will cause the door to not unlock. Do you hear a humming sound when you ask the unit to drain, and if it's not draining, theres a clue
    can you download a picture of this washer and the door lock assembly?
  • erica graber Jan 10, 2009
    Wow you are a girl! Guess what I am too. I am very happy to here this solved your problem
I need a user manual for whirlpool awg 370 washing machine. Please help.
This is the link , you can download the manual from it:
http://www.eserviceinfo.com/index.php?what=search2&searchstring=WHIRLPOOL++AWG+370
Jul 07, 2014 | Washing Machines
Washer stopped, wet clothes inside, door locked, --- in message
unplug for about 10 minutes and then plug back in and try to start it.this will reset the micro computer in it.
Oct 31, 2012 | Whirlpool Washing Machines
Hello PHILIPS WHIRLPOOL Washing machine AWG 371 Washer front door - the plastic handle does not function so you can not open or close the door. Can I replace just the handle (were I can get this...
You can buy a handle no problem quite easy to fit buy from Espares.co.uk if you live here or any Philips/whirlpool agent.....Cost about £12.....
Feb 24, 2011 | Whirlpool Washing Machines
Front loader washing machine. wet clothes stuck inside. door lock won't release.
I've had this problem before i unplugged it because holding down the lock button didn't work so unplugging it from the wall for about 20 minutes worked just fine it seemed to reset itself. good luck.
Jan 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool awg 370 front loader
was this model sold in india? Please ask your friend if you are unsure. I have tried to find a manual in all the other whirlpool sites worldwide also, and every other place i could think of with no luck. Try contacting them on; http://www.whirlpoolindia.com/dealerlocator.aspx Hopefully they may help - if not please ask again :)
Jul 16, 2007 | Whirlpool AWG329 Front Load Washer/Dryer
Washing Machine Door won't open
I had the same problem. I went through all the steps on this thread to no avail. Finaly I just pryed the thing open - with no damage, thank goodness.
Once open I saw that the latch in the door didn't move when I pulled the handle. The problem it seems was in the latch on the door itself. If you end up this problem and want to get wet clothes out, just stick a flat-head screwdriver, behind the door latch into the horseshoe-shaped metal bit and lever it open - no prying necessary.
Not sure how I'm going to fix this permantely but at least I got my wet clothes out and can do laundry as long as I keep the screwdriver near by.
To fix - I'll either need to figure out how to disassemble the door and replace the latch mechanism, or just buy a whole new door.
Oct 27, 2006 | Whirlpool LHW0050PQ Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
1,377 people viewed this question
Dan Webster
Dan Webster
Sal De
