Question about Whirlpool LHW0050PQ Front Load Washer
Whirlpool washer model WTW4800XQ1 red light blinks, does not spin or drain properly
Does anyone have the part number for the coupler?
Posted on Jan 14, 2013
abhishek33
  • 1239 Answers
SOURCE: Whirlpool Ultimate Care HD Plus Model #LSR8233EQ0 won't agitate or spin
It sounds like the coupling between the motor and gearbox has worn out. It should cost around $15 plus shipping and handling.
Posted on Jan 07, 2009
SOURCE: My Whirlpool washer won't agitate or spin . But it does drain the water.
i also had the same problem, and it ended up being the coupler. It was not hard to replace, it cost me about 19.00. I didn't follow full recomende instructions. I tipped the washer backwards. Removed the drain pump and the motor itself. Then I removed the old coupling and placed the new one. The washer is working like new...
Posted on Jun 02, 2009
gwshaw71
  • 83 Answers
SOURCE: Whirlpool Washer wont spin or drain
check your lid switch. if it will aggitate and not spin or drain.. then your lid switch is your answer
Posted on Nov 30, 2007
SOURCE: PORTABLE WASHER LCE4332PQ1
did you fix this? i have the same problem.
Posted on Jun 30, 2009
j_alcaidinho
  • 107 Answers
SOURCE: Whirlpool LHW0050PQ will not drain during
you need to check pump assembly for blockage, if there is a kick plate, the will be two or three screws and if the isn't you'll have to go through the back
Posted on Jan 13, 2010
Washer will not spin r drain model whirlpool la7680xmwo
Sounds most likely a broken/defective lid switch. The lid switch on a top-load washer is a safety switch that detects whether the top-load washer lid is closed. The lid must be closed when the basket spins; some top-load models require that the washer lid be closed before the washer drive motor runs (thus no draining). If the lid switch isn't properly detecting whether the lid is closed replace the switch.
Dec 24, 2016 | Whirlpool Washing Machines
Washer does not spin and drain properly
How To Fix A Washing Machine That Is Not Spinning or ...
removeandreplace.com/.../washing-machine-or-washer-dryer-is-not-spin...
May 15, 2013 - Washing Machine Service Repair Manuals Online Your washing machine is not working properly. It does not spin, won't drain, can't turn on, ...‎Washer Not Draining Water - ‎Washing Machine Service ... - ‎How To Fix A Washing ...
Washer Repair - Not draining or spinning ... - YouTube
? 5:17
https://www.youtube.com/watch?v=k41abYwM9WY
Jul 12, 2013 - Uploaded by ApplianceVideo.com
Washer Repair - Not draining or spinning - Repair & Diagnostic- .... off and my machine spins but it doesn't drain (high spin) does not work.
Dec 19, 2015 | Whirlpool Cabrio WTW5500BW White 27"...
Blinking lid locked light and green sensor light on machine won't start cycle
The good ol' Whirlpool Lid Lock Flashing Light Problem - ApplianceBlog
www.applianceblog.com/.../42456-The-good-ol-Whirlpool-Lid-Lock-Fl...
Dec 11, 2013 - 10 posts - ‎3 authors
Red Lid Lock light flashing intermittently when you try to start a cycle. ... I'm going to post what SENSING does first, then you will need to locate your tech. ... start with thelid lock on and blinking, or the unit will not start and spin. FIXED Sense light on light humming noise won't start ...
Aug 9, 2015
Whirlpool WTW4950XW not working
Nov 2, 2013
Stacked GE washer/dryer lights Blinking doeent start at ...
Feb 20, 2012
More results from www.applianceblog.com
Washer Sensing led (Green) on with the lid locking led (Red ...
www.shopyourway.com > Manage My Life > Questions
... this: Sensing led (Green) on, the lid locking led (Red) blinking with a clicking noise ... red led light goes off green led light stays on and the washer does not start.
Oct 27, 2015 | Washing Machines
I have a whirlpool washer model WTW4800XQ1. It spins but doesn't drain. I taken apart all hoses...no clog. The water will drain through the pump when the unit is unplugged. Is there a way
it sounds like the pump does the water run out when the outlet pipe is laid flat on the floor or below the machine's height level? if so then the pump will need to be checked out
Nov 10, 2014 | Washing Machines
My whirlpool AWO 3551 when you start a program, the drain pump runs for a while then the door locked light goes from solid red to flashing red and the pump stops, I have checked the motor brushes and...
I just tried looking your model up but the # you gave is incomplete. If your washer is a top loader and has a belt, my experience has been the mode shift actuator causes lid lock light to blink as you have described. That is a fairly inexpensive and simple part to replace.
Sep 01, 2017 | Washing Machines
Whirlpool cabrio wtw5500xw1 will not spin
This is caused by a major design flaw in this washer. I have the same washer and am having the same problem. If you take the back cover off by removing the small metal cover over the tube coming from the controls and all the screws around the large lower metal cover, you can gain access to the back of the washer. Take the foam noise reduction pad out of the bottom of the washer. There is a white opaque plastic shroud on the bottom of all the motors covering the belt. Remove it by taking out the screw in the front bottom and back bottom of the shroud. You will most likely see that the belt fell off. This is because the drive pulley for this washer has no ridge on it to keep the belt on and most likely rubbed on the shroud and cut a perfect groove in the shroud, allowing the belt to fall off. SHORT STORY: This washer is a piece and you are probably out of warranty. There is no actual way to fix this problem unless Whirlpool has made a new drive pulley that has a ridge on it to keep the belt on the two pulleys. Good luck. I bought mine for $700 and it worked for two years before this happened.
Mar 04, 2012 | Whirlpool Cabrio Washing Machines
Water still in tub water level light blinking
GO TO www.repairclinic.com AND LOOK FOR PART 541811 IT MAY BE CLOGGED AND NEEDS CLEANED OUT THIS IS A LINT CATCHER FOR WASHERS
Apr 16, 2009 | Whirlpool LCE4332P Top Load Washer
AWM 8121 NOT DRAINING OR SPINNING PROPERLY
that isn't a good model number,open the door,look around the opening where you put the clothes in and next time send the model number off of the machine,if you can't get it to drain and water is in the machine get a shop vac,suck out the water from the tub,then go to the pump,loosen the center of the pump until water starts to come out vac it up until no more water comes out,remove the center catch and see if there's junk in there,if so this is your problem,stick the nozzle of the vac inside and clean out the inside,put it back together and see if it will drain
Sep 29, 2017 | Whirlpool AWM6120 Front Load Washer
Whirlpool LHW0050PQ Front Load Washer Logo
531 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
