Question about Whirlpool WFW8300SW
Why is fiberglass shredding from drum of whirlpool washer
2 Suggested Answers
  • 84 Answers
SOURCE: whirlpool duet washer, inner stainless drum rubs
This sounds like a worn bearing housing or the bearing itself has packed up,either way you would have to strip and check these and replace what is broken
Posted on Dec 28, 2009
42936- My kenmore elite he front-load washer w/steel tub-has scrapping/unbalanced like sound coming from washer when in spin cycle, then after completed there is shredded plastic/fiberglass like mater
Sound like one of the wights has come off or is loose and damaging the drum and other parts take a under the machine and you may see the problem
Jul 29, 2014 | Kenmore Washing Machines
WHIRLPOOL TOP LOAD WASHER LGR7646 SHREDS CLOTHES
Hi, mfels. My name is Emily and I am a representative of Whirlpool, we're very sorry to hear about the difficulty you've been experiencing with your washer. Below are links to our use and care guides, parts list, troubleshooting, and service. We hope this can help.
http://bit.ly/112Lu7q
http://bit.ly/zkfnZd
http://bit.ly/yLv4Z5
Sep 13, 2013 | Whirlpool LSR7333 Top Load Washer
Why is my kenmore washer shredding sheets?
Check the drum for any Sharpe edges or splits also check the activator for the same . Something in side may have a rough edge to cause this .
Apr 25, 2017 | GE Energy Star WCVH6260F Front Load Washer
Clothes are being shredded in washer
it sounds like you have a bent piece of metal round the drum you will have to make sure the drum is empty with your hand very slowly move it round the whole drum if you find it with a small hammer don't hit it heard OK just tap it till its not going to shred your cloths OK if you don't find any thing you will need to look at the paddle in the drum to make sure there not Brock or moving OK hope i can help
Oct 22, 2012 | Maytag Washing Machines
My Whirlpool WFW8310sw2 is leaking water during the rinse and spin cycles. After opening the bottom panel, I noticed that the water was coming around the cement. After tracing it, I found out that it is...
Hello, W/D here.
If you washer is still in warranty, you should let the company make it right.
If not, you can make repairs yourself. First, determine why the leak occurred. One common problem is a loose or damaged counterweight. If loose, it will need to be tightened up. I have seen a counterweight that was pre-stressed, with a rod between the mounting points that had broken, allowing the counterweight to hit the strainer. This can be repaired by replacing the counterweight part, or by strongbacking with aluminum, and epoxying the weight back into a solid mass. Epoxy also is useful for repairing cracks in tubs. I roughen up the area to be epoxied and apply fiberglass mesh (the self adhesive wallboard tape) to the area, and then applying J-B weld. I've never had a repair like this break. For your repair, I would recommend that you build the joint up well, with layers of the fiberglass tape and epoxy, and feather the repair out onto the drum surface area several inches. The fiberglass tape can be cut into strips and applied like a bandage, if you need to make wraps. Overlapping the joint of the tape pieces contributes to the overall integrity of the repair. Just don't put down so much tape at one time that the epoxy can't get to the surface of the drum. Several layers, with curing time in between applications is the best way to go. Depending on where the crack is, the repair is easier to apply if the surface is more horizontal than vertical as the epoxy tends to try to run until it sets, so try to place the washer in a good position, if possible. Removing the tub may make this easier for you, but it isn't critical. If you DO remove the tub, make a similar epoxy repair from the inside of the tub, if possible. This will provide greater strength and sealing.
Hope this gives you better options, --W/D--
Feb 11, 2011 | Whirlpool WFW8300SW
Whirlpool Front Loading Duet Washing Machine Plastic at drum front shredding
i think your talking about the rubber door seal????
you can change this yourself,,,under the seal on the case is a wire spring unhook it and the door seal will fold inside the washer,,,on the inner drum you will find the other wire spring undo this as well and pull the old door seal out through the hole in the door,,,the new seal is fitted to the iner drun first so you need to turn the new seal inside out to fit it,,,push the seal into the washer and fit the inner wire first then unfold the seal and fit it over the outer door so you can fit the wire spring,,,
easy after you have fitted a fuw 100?
Aug 21, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
Whirlpool Duet GHW9100 Drum Knocking/Plastic Tub Shredding
This is joyce
The bearings is gone in the drum, causing the drum to rub and run the wrong way one the pully, yes it is very exspensive, I have the newer model.
let me know if I can help
thanks
joyce
Feb 13, 2009 | Washing Machines
My front load kenmore elite 110.45872 shakes during spin cycle
your basket shaft is broken or the bearing are bad it probably sounds like a freight train when it goes into high spin you need your washer rebuilt but it would be cheaper to buy a new washer. to rebuild the washer it will cost aleast 800 dollars
Dec 13, 2008 | Kenmore 24032\24036 Top Load Washer
Washer belt is loose, & seem to slip at start of spin cycle.
there are several drive belts for this model... check here to see if the one you are fitting is the correct one... also,is the tensioner siezed? causing the tension to be too slack therefore allowing the belt to shred at speed?
check here .. http://www.partselect.com/AppliancePartList.aspx?Brand=Admiral&Appliance=Washer&ModelNum=&Type=Belt&MinSize=U&MaxSize=U&Electrical=U&Metal=U&Plastic=U&OneColor=U&PageSize=15&FirstPart=1
Dec 03, 2008 | Admiral AAV7000A
Whirlpool duet shredding and causing pulls on clothes
The drum guide was dislocate you may check guide and screw detach , incline drum screw the roller guide test it by turning the roller , if good test drum by turning on it until free to rotate not touching to door giude .
Jan 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool WFW8300SW Logo
Dan Webster
Dan Webster
Sal DeAngelo
