Question about Telex H-531 Headset
Headset not working - Telex H-531 Headset
    President:
  • 373 Answers
The problem might be due to the internal wiring damage.do not coil the wire much.you might have to replace it if damaged.
can also be due to the volume control, where there might be a connection loss.will wait for your further comments.good luck.
Posted on Jan 04, 2009
Headset not working in opti point 500 basic
In order for a headset to work on that phone, you first need to make sure your headset is compatible with it. For example, our headset system:
http://www.aiheadsets.com/lxg-800.htm .
From there you would need to make the necessary switch adjustments on the setup . You are probably going to need a battery operated devise like ours. If you could provide your current headset model, I can help further.
Nov 05, 2012 | Siemens OptiPoint 500 Basic Refurbished
Why my headset not working/realtek?
Do the speakers work? Maybe you have the headset plugged into the wrong Jack. Maybe you have the headset on Mute. If the speakers work, unplug where the speakers go into the computer's port and plug the headset into that same port and see if you hear anything. If not, maybe your headset is bad.
Mar 25, 2012 | Computers & Internet
My new blackberry pearl no reconnize my plantronic 330
Test the headset on another phone, if it doesn't work on the other phone then your headset is defective. Connecting the headset to the blackberry is fairly simple. Just verify that the Blackberry's bluetooth connection is active and make sure the headset's connection is active as well. Select the plantronics headset within the Blackberry's bluetooth menu, it should be listed in the menu if the headset is working.
Mar 05, 2011 | Plantronics Explorer 330 Headset
The handset lifter works, but no sound can be heard or received by either party
If you have a 510a base, then purchased a Plantronics Voyager Pro headset to replace your old headset, it won't work. Those are two different headsets. The Voyager Pro is not meant to work with the 510a base. The correct headset is this:
Plantronics Voyager 510 Replacement Headset
Good luck from Headsets Direct!
Jan 27, 2011 | Plantronics Voyager 500A Deskphone Adapter...
Plantronics cs60 cordless headset not working properly with Mitel 5220 ip phone. Cant switch between handset and headset. When you lift the handset sound comes from the headset. The same headset works fine...
I'm sorry for being long on my answer here...
The bad thing here is that the CS60 is not a Mitel approved/supported headset. The only headsets that are approved for Mitel Superset or Mitel IP telephones are the Plantronics Polaris model.
BUT many other headsets do work with Mitel telephones. Since they are not "supported" by Mitel, you should contact the headset manufacturer for configuration guidance. Some have dip switches, or dials that need to be in certain positions to work with certain telephone models. This can be different from one phone to another.
Plantronics web site and their support people should be able to guide you to configuring this headset properly for each model phone.
How is the headset and handset connected? It sounds like the CS60 is connected to the handset port of the phone and the handset is connected to the CS60. When you go off hook with the handset, it sends the signal to the CS60 and depending on the switch on the CS60, it will send the signal to either the handset or the headset.
OR
The CS60 is connected to the handset port and the handset is connected to the headset port. To make the headset port work, you must have the CS60 connected to the headset port and the handset connected to the handset port. Set the phone to Headset mode.
Dec 13, 2010 | Mitel 5220 IP Phone
Headset
try to barrow your friends headset and try it..if it works your headset is broken but if it didn't work your gadget is broken.
May 22, 2008 | Logitech ClearChat Stereo Headset Headset
Headset problem with Uniden 1558
Determine if this is a VOX problem or a headset problem.
Turn off the VOX. Does the headset work for normal transmit and receive?
Remove the headsets. Do the radios work normally on speaker?
Plug one headset in And test with the (other) radio in speaker mode. Does it work? Now turn on VOX in this mode (yes it will work this way). Does vox work (put you mouth right on the mic)
If so swap headsets and try the other.
If one Hset works but not the other its the headset. If neither works its likely the radio ..but before you decide try the same headset experiment on the other radio. Find out which of the 4 devices the problem follows.
Happy New year
Dec 24, 2007 | Uniden GMR-1558 / 2CK 2-Way Radio
Microphone not working
maybe its a problem with your sound card. Check your microphone settings in Windows.
Dec 11, 2007 | Altec Lansing Stereo Headset with...
Tried unmuting the headset
voice dial work throught your phone.unmuting the headset is it at the phone not at the headset.
Jun 21, 2007 | Motorola Mobility H700 Wireless Headset
Telex H-531 Headset Logo
142 people viewed this question
Top Telex Radio Communications Experts
Mike Charette
Andrew Taylor
Andrew Taylor
Are you a Telex Radio Communication Expert? Answer questions, earn points and help others
