Question about Car Audio & Video
Boss BV9962: When drivers lights are on the flip screen turns blue and the radio stops working.
Screen says car < in upper right hand corner of screen and in the middle of the screen it says No video. All the functions on the deck stop working. In some cases I can still hear the radio station but can not turn up the volume or do anything for that matter. Deck wont turn on or off until I turn off the car or turn off the lights. Once I turn off the lights I gain control of the screen and deck again. All wires on the harnest are connected to their color. I bypassed the dvd screen function by hooking the brown (brake wire) to ground. I am guessing the Orange wire doesn't need to be connected Orange is reverseing switch. I have a 2003 dodge grand caravan.
2 Suggested Answers
rockmeister
  • 2047 Answers
SOURCE: BOSS 7300 in dash DVD
The flicker which happens is as a result of a power failure in the unit. Whenever this power fluctuation occurs it causes the unit power to go off and then restart. The restart is what brings about the screen which displays media at the top and the radio display screen. try tracing the cables which supply power to the unit for any inconsistencies to sort this out. Also you can check te use which affects the supply of power to te unit.
Here are 2 links to help with bypassing the brake. The first is a video while the other is a detailed step by step explanation.
http://www.youtube.com/watch?v=NgdfLst2QvQ
http://www.ehow.com/how_7265002_bypass-brake-wire-dvd-player.html
hope this solution has been helpful?
Posted on Mar 27, 2011
Como puedo obtener manual de radio boss BV9962
Request the manual directly from Boss.
Jan 14, 2015 | Cars & Trucks
How do you switch the am and fm on the Jensen Phase Linear UV10 Flip Out MultiMedia Receiver with 7-Inch Touch Screen
touch the source button in the upper left hand corner until you see radio, then hit tune or seek to get the stations you wish.
Nov 21, 2014 | Car Audio & Video
Boss bv9962 car radio i need the system set password
888888888 Just fill the screen with all 8's
Jan 25, 2012 | Car Audio & Video
I turned on my modem, an all that is displayed on my monitor is the blue hp screen. In the botton left hand corner it says <F10=Setup> and <Esc = Boot Menu> and in the right bottom corner, it...
what modem, who's and where, ?
or is modem , monitor?
which blue HP screen there are many,
you left out what it says...
i can not watch you boot, and what is displayed, is key to the cause.
NO OS stated, is this XP?
when you boot, it always prompts in text ,hit ESC key to enter setup"
this is the BIOS hot key prompt that some times shows
a cute small HP icon this too is BIOS created.
then the PC boots and goes to OS, there many OS offered
Windows is XP is one? is it?
or Vista.,w7,/8/10 or PS/2 or linux. HP has many offered OS.
as do Refurb companies endless.
if windows?, the windows log in screen is next.
so my guess is the PC goes to BLUE screen that, before that.
stating (presenting)
startup file failed?
or , HP recover failed.?
or any of 50 other windows blue screens of *****.?
why not post a photo of the screen?
one screen is the XP BSOD , crash screen.
seen here.
one other blue screen is "windows is doing updates" so let it??
one modern HP W10 screen 1 of 50
this is most times below a bad video card driver used on PC.
not matching card to OS. and bam crash.
Aug 28, 2017 | HP Hewlett Packard Pavilion Slimline...
Where the fuse box to a 88 ford thunder bird 5.0 liter
The fuse panel is located underneath the dash, to the left of the steering column, next to the emergency brake pedal. You need to remove the under-dash insulation to access some parts of the fuse panel.
If it doesn't have a diagram inside the box, here's one I found online: http://www.coolcats.net/tech/reference/images/fusepanel.jpg
1 15A Lt. Blue Stop Lamps, Hazard Warning Lamps, Speed Control, Cornering Lamp Relays 2 6A - CB - Windshield Wiper/Washer Pump 3
Spare - Not Used 4 15A Lt. Blue Taillamps, Parking Lamps, Side Marker Lamps, Instrument Cluster Illumination, License Lamps, A/C and Heater Illumination, Radio Illumination, Digital Clock Illumination, Autolamp Relay 5 15A Lt. Blue Turn Signal Lamps, Electronic Day/Night Mirror, Lighted Vanity Mirrors *, Backup Lamps, Illuminated Entry, Keyless Entry, Cornering Lamps 6 20A Yellow Rear Defrost Timer, Chime, Back-Up Lamps, Cornering Lamps, Rear Reading Lamps, Trunklid Release, Digital Clock Display, Illuminated Entry, Anti-Theft Module, Turbo Buzzer 7 15A Lt. Blue Fog Lamps (Turbo Only) 8 15A Lt. Blue Courtesy Lamps, Key Warning Buzzer, Illuminated Entry Module, Glove Box Lamp, Door Lock Relays, Radio Memory, Cluster Memory, Outside Mirrors, Tripminder Module, Analog Clock, Anti-Theft Relay 9 30A Lt. Green A/C Heater Blower Motor 10 20A - CB - Horn, Cigar Lighter, Fuel Filler Door, Flash-to-Pass, Speed Control 11 20A Yellow Radio, Tape Player, Premium Sound Amp, Power Antenna, Graphic Equalizer 12 20A - CB - Power Seats, Power Locks, Keyless Entry 13 5A Tan Instrument Cluster Illumination, Radio, Climate Control 14 20A - CB - Power Windows, Power Moonroof 15 10A Red Taillamps, Rear Side Markers, License Lamps, Electoluminescent Coach Lamps 16 4A Yellow Electronic ATC 17 15A Lt. Blue Electronic Cluster, Tripminder Display, Fuel Gauge (non-electronic cluster), A/C Clutch, Speed Control Module, Graphic Warning Display Module, Electronic Blower Speed Controller 18 10A Red Warning Indicator Lamps, Autolamp System, Throttle Position Sensor, Low Fuel Module, Dual Timer Chime, Tachometer, Washer Fluid Level Indicator
May 20, 2011 | 1988 Ford Thunderbird
I have leapster l-max and am having trouble with the stylus working. when i try to calibrate, i can't click on center targets
Leapster L-Max recalibrates differently. I was trying to use the instructions and it kept asking for a blue button. For the Leapster L-Max push B, A, Hint, and Home when you turn it on. Do not have a cartridge in the player or it will think it is a regular Leapster. Once it says calibrate screen it will say to press A, then wait until a target appears in the upper left hand corner, touch it and you should hear a sound, then a new target appears in the lower left hand, repeat actions, then lower right hand screen, and finally the upper right hand screen. If it stops at any time and doesn't get more arrows, try it again or turn it off and see if the pen works. It may take several times to get it working again.
Feb 05, 2011 | LeapFrog LeapSter L-Max Console
WHERE IS THE WIFI RADIO BUTTON
wi-fi radio button can be found at the upper right hand corner of the laptop or on the LCD screen, there is a symbol located at the lower right hand corner of it.
Aug 12, 2010 | HP EliteBook 6930p Notebook PC
The lower left hand corner of the screen is turning blue
catually is problum is related with blue lcd & blue polizer but first you clean the optical unit if the problum gon then ok other wise must chang blue lcd & blue polorize with uv filter plese contect to your nearst sony service centre
Feb 05, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Olevia 540-B11
damm i have the same issue except the left side of the screen is far darker than the right. It still works but is very noticable. If you get this resolved please reply back!
Aug 19, 2008 | Olevia LT42HVi 42 in. LCD Television
Car Audio & Video Logo
44 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
