Question about Dryers
Patton Electric fan motor not working, no hum, no sign of any life when plugged in and switched on
Received this fan not working. It's a Patton Fan with the following information stamped on the motor housing: Mod# PAB06 then there is from what I can make out since its very hard to read 0 or D 2020 then another number E90368 and lastly 80M6 01-06. When plugged in and switched on it does nothing, no humming or any other sign of life, no odd smells or lights nothing at all. Any idea on what to initially check in trouble shooting this fan? Thanks, Les
  • 883 Answers
SOURCE: Electric Fan - Black and Decker Typhoon Stand Fan
can you repeat this problem every time without a "cool-down" waiting period?
Posted on May 20, 2007
night71
  • 328 Answers
SOURCE: Hampton Bay 36" Fan Hums but won't turn
The motor has gotten tired now after being on 24/7. With the blades off, it would turn easily but the weight of the blades strain the motor. You could check that there is proper 110 volt current to the motor because anything less will cause that problem too. You can also help the fan start by spinning the blades while it is on. Short of these suggestions, it is time for a new fan.
Posted on Nov 18, 2007
PegBox60965
  • 51 Answers
SOURCE: Looking to replace Patton fan motor, model 1010mp, style TJ74SP
If you are up to disassembling your motor, you will find a thermal cutout near the windings which frequently fails open. Replacements are readily available, or just jumper it out. If the bearings are shot or the windings burned you're out of luck. Trust me, a new motor will cost more than a whole new fan.
Posted on Jan 01, 2009
SOURCE: Wiring the replacement 3 speed switch (fan motor)
I called King of Fans and the rep that I spoke with gave me the correct wiring for the 3 speed switch:
L White
1 Yellow
2 Blue
3 Black
The problem is that after I wired it this way I am getting the same result (off on 3 settings and a motor hum on 1 setting). So, either the Westinghouse switch that I bought at Home Depot is not compatible or it is the capacitor. The saga continues.
Posted on Feb 19, 2009
  • 10865 Answers
SOURCE: new ceiling fan . Motor has humming noise.
Return it while it is still under warranty.
Posted on May 16, 2009
Can I buy a heating element for this heater?
On google
Patton replace heating element Heaters Questions ... - Fixya
www.fixya.com > Forum > Tags > replace heating element > Heaters
Patton heaters replace heating element related questions and answers. Ask yourPatton ... I can't seem to find a phone number for the manufacturer to call for parts. Any help? ... Question about PQH307UM Electric Utility Heater. 1 Answer ...
Patton PQH307UM Electric Utility Heater Quartz elements ...
www.fixya.com > ... > Patton > Patton PQH307UM Electric Utility Heater
Patton PQH307UM Electric Utility Heater, quartz elements replacement related ...Element. Where can I find replacement quartz tube heating. Element Infrared ...
Patton PQH307UM Electric Utility Heater Element ... - Fixya
Patton PQH307UM Electric Utility Heater, element related issues. Get free help, solutions & advice from top Patton experts. ... The heating element is above the thermostat, and all you will see is a round disc with two wires attaching to. Ad.
Patton PUH680-U Utility Heater Replacement fan motor ...
Jan 19, 2016 | Patton PQH307UM Electric Utility Heater
Why doesn't my fan run.all the lights work but no fan
here is the bionaire support for your tower fan. 1-800-253-2764, if the fan is getting electric to the motor and it just hums, the fan motor may need a good cleaning or if no hum. it is a bad motor or switch. just call above number. good-day !
Jun 07, 2012 | Dryers
NEED REPLACEMENT MOTOR FOR PATTON 1010MP-HY FAN. WHERE CAN I PURCHASE THE MOTOR?
CTG ' Order 1010MP from PATTON ELECTRIC CO INC Now from CTG !
It looks like you can purchase a motor here.
Make sure you have the correct data from your motor.
There is also a contact button so you can probably call, too.
Good Luck,
Your FixYa Texpert,
Gary
Aug 17, 2011 | Patton U2-1487 Floor / Box Fan
I want a new motor for the patton 20'' cvt air fan
You can generally find new motors at an electric motor shop, check the yellow pages. However they are many times more money than a new fan. Then add time and your drive to get the motor, my recommendation is purchase a new fan, cheaper in the long run.
Feb 23, 2011 | Patton 20" CVT Performance Air Circulator,...
I was trying to install a fan control switch on my Patton floor fan and took the 3 speed switch out and disconnected the wires and cannot figure out what wires (too many colored wires) to connect to the 2...
Thr issue you are having you need to look on the motor and see if there is a diagram but you have to use the grey and white for a capacitor because i have an older fan that has no capacitor. and use the red for high
Dec 28, 2010 | Patton U2-1487 Floor / Box Fan
Where do i find a replacement motor for my patton model u-2-1887 fan? 120v/60hz/270w/2.6 amps. or where would i get the motor rebuilt?
Before you replace it, try oiling it -- look at the little oil hole on the back of the motor housing. Or try taking it apart and cleaning it, then oiling.
Did it work before, but gradually slowed down and then refused to start? See other threads on this topic for that fan model.
Jul 15, 2010 | Patton U2-1887HO Floor / Box Fan
Fan keeps cutting off after being taken apart and cleaned
If it was wired wrong it wouldn't run. I would suspect uneven tightening of the motor screws.
Aug 08, 2009 | Patton Electric U2-20 Box Fan
Jan 01, 2009 | Patton (HASF1016UC) Stand (Pedestal) Fan
Motor seized
I just want to know if I can purchase a NEW motor and what the cost is?
Feb 24, 2008 | Patton U2-1487 Floor / Box Fan
Dryers Logo
301 people viewed this question
Top Dryers Experts
