Question about ACE Dimplex (r) Compact Electric Fireplace (DFP36430) Heater
BULBS HOW DO YOU GET AT BULBS
  • 65 Answers
Go to: www.dimplex.com
1. click cust suppt.
2. click tech suppt.documents
3. click parts & service
4. click stoves and choose your model
file will come up
Posted on Jan 05, 2009
Ihave a alisun canopy ttanning bed and two lights r not working got two new bulbs and still not working.
humm
correct bulbs fitted but do not work
holding firm at connection points where the bulbs attach
strange
all other bulbs work
if other bulbs do not work in the same bad connection
will need electrician to inspect
try this link .. section 3 on bulbs
http://www.tanningbeds4less.com/lamphelp.htmlc0344ab4-9693-4916-84a5-da99999bec82.jpg
May 19, 2016 | Cars & Trucks
Chevy silverado climate control
you are looking at the bulbs and not the problem beyond the bulbs. If you have power to the bulbs and power through the bulbs then you have no earth return for the power to return to the battery. Check out the earth points for the bulbs.
Mar 02, 2014 | Cars & Trucks
I have a 2005 chev impala can i replace my high beams headlights with just low beam lights
NO YOU HAVE TO REPLACE HIGH BEAM LIGHT BULBS WITH HIGH BEAM LIGHT BULBS BECAUSE HIGH BEAM LIGHT BULBS AND LOW BEAM LIGHT BULBS TWO DIFFERENT TYPES OF BULBS.WEAR CLEAN LATEX GLOVES HANDLING THE HEADLIGHT BULBS WHICH IS HALOGEN LIGHT BULBS, OIL FROM FINGERS OR HAND WILL CAUSE HALOGEN BULBS TO OVER HEAT BLOW OUT.
Jul 05, 2011 | 2005 Chevrolet Impala
Light bulbs keep burning out
voltage regulator faulty ,its built into the alternator
Jan 12, 2011 | 1999 Mercedes-Benz E-Class
My malibu landscape 300w transformer does not want to come on
Check that power pack is getting electricity.
Power pack should make a small humming sound when on.
Scratch a wire across both terminal screws and see if there is spark.
If a bulb burns out, and is not replaced, additional voltage can burn out other bulbs.
Power pack should be unplugged if bulbs are not burning since that can burn out power pack.
Change out a couple bulbs and then plug-in power pack.
Check connections where lights tie into wire.
My power pack was doing same thing, I bought another power pack from Home Depot to check my lights. All but 2 bulbs were burned out. I replaced bulbs and returned new power pack.. and then power pack quit for good a month later.
I found tips to preserve power packs:
1) Match wattage of bulbs with wattage of power pack
-15 each X 20 watt bulbs = 300 watts, so install 300Watt power pack
2) Installing a 500W power pack on 300W of bulbs will burn out bulbs and power pack.
3) Replace bulbs as soon as they burn out or other bulbs will burn out and power pack will burn out.
4) When working on bulbs, unplug power pack or it may burn out.
http://www.malibulights.com/guides_support/low_voltage_planning_guide/select_your_power_pack
Nov 22, 2010 | Intermatic Malibu 300W Power Pack...
My lawn lights stopped working, transformer tested ok. What could be the problem?
You checked that power pack is getting electricity.
If a bulb burns out, and is not replaced, additional power can burn out other bulbs.
Nov 14, 2010 | Intermatic Malibu 300W Power Pack...
The lights stay on all the time and won't shut off. The front ones work fine but not the back lights. Any idea's? thanks,
Unfortunately when the power pack stops working there is no solution.
Your power pack has electricity so that is not the problem.
The bulbs turn on, so the bulbs are ok.
That means the power pack has malfunctioned, and needs to be replaced.
I did find some tips to help folks preserve their power packs:
Nov 12, 2010 | Intermatic Malibu 121W Power Pack...
HOW MANY BULBS ARE IN THE REAR LIGHTS (SUCH AS FOR PARKING, REVERSE, BRAKE). IF WARNING LIGHT ON PANEL IS ONE, WOULD I SEE A BURNT OUT BULB?
You may or may not see a burnt out bulb. The dash light can also mean there's a current issue (ie none of the bulbs are lighting)
2 reverse bulbs
2 license plate bulbs
2 turn signal bulbs
2 rear sidemarker bulbs (side of your tail light assembly)
2 running light bulbs which are the same as your stop light bulbs in the tail light assembly
1 to 6 high mount stop light bulbs (if they're in the window and varies on models)
1 strip of LED brake lights if you have a spoiler
Sep 24, 2009 | 2002 Toyota Camry
All bulbs are burned out. Need to replace.
if only bulbs required normal bulbs will do if bike is 12 volt.
Aug 25, 2009 | 1988 Honda GL 1500 Gold Wing
Heating & Cooling Logo
344 people viewed this question
Top ACE Heating & Cooling Experts
Craig Butler
Craig Butler
Andrew Taylor
Andrew Taylor
Tim Whalen
Are you an ACE Heating and Cooling Expert? Answer questions, earn points and help others
