Question about Humidifiers
Safety 1st humidifier won't turn on - Humidifiers
2 Suggested Answers
  • 4736 Answers
SOURCE: humidifier is full of water
More than likely, the float valve in the top of the water collection bucket is broken or stuck in the DOWN position. Turn the unit OFF & unplug it. Remove the bucket for it's holder and empty any water that's in it. Inspect the float valve to see if it moves freely. Jiggle the arm of the float valve to see if it moves up and down freely. If it doesn't then it's stuck or broken. Hopefully, it's only stuck, because in most cases, purchasing a replacement bucket with the float valve installed is your only option.
Hope this helps you solve the problem. Thanks for choosing FixYa.
Posted on Sep 17, 2011
How do i get started using the humidifier?
Fill it with distilled water and turn it on.
The better detailed the problem, the better the solution.
Jun 30, 2014 | Humidifiers
I need help puting the staps back on a safety 1 car seat
Uhm, you're in the Humidifiers section, you may want to move this question to another section...
Apr 08, 2013 | Safety First Safety 1st Healthcare Baby...
Water to humidifer won't turn on.
Check if there is power to the solenoid valve, if ther is , then the solenoid is bad and must be replaced. If there is no power could be a bad humidistat or transformer.
Dec 19, 2012 | Aprilaire 600 Humidifier
Aprilaire model 50 current sensing relay won't close
If the relay is not closing then it must be replaced. It works by sensing the current through the common wire of the blower motor.
Dec 08, 2012 | Aprilaire 50 Current Sensing Relay...
Faulty water level indicator
It is the reed switch inside the post that the float runs on, it gets corroded and needs to be replaced. It is an easy and cheep fix if you can get the reed switch. I would also suggest adding silicone as the factory seal is poor before you put it back together.
Oct 28, 2012 | Sunbeam Humidifiers
Can't turn it on. Power digital readout doesn't work.
Mine would not turn on at all, found the contact pads for the buttons was corroded. Used an eraser and cleaned them, working good now. Of course the whole thing has to come apart to get to the contact pads.
Nov 30, 2011 | Bemis 821 000 Humidifier
Humidifier is full of water but the light shows it's empty. Since the humidifier thinks there isn't any water it won't run.
Sep 17, 2011 | Essick Air Humidifiers
I HAVE A vICKS VAPORSIOR AND HAVENT USED IT VERY OFTER THERES no STEAM COMMING OUT EVER I USE COLD WATER DON'T FILL ABOVE THE FILL LINE I ALSO CLEANED IT REALLY GOOD WITH CLOROX. aNY SUGGESTIONS???
The unit may simply has a calcium scale build up and it's blocking the water passage. To clean it, empty in water remaining in the tank. Mix a 50/50 solution of White Vinegar and Bottled Distilled Water and fill the tank. Allow it to soak for at least one hour, then turn the unit ON. Place you hand in front of the misting nozzle to see if it's working. If you don't feel any mist, turn the unit OFF and allow it sit over night. If you do feel mist, allow it to run until the tank is 3/4's empty Turn the unit OFF, pour out the remaining solution and refill with Bottled Distilled Water. Run the humidifier until it's empty. This will flush the system entirely. In the future, I would recommend you use Bottled Distilled Water, instead of Tap Water. If you do, you won't have to descale the unit any more.
Hope this helped you, please let me know. Thanks.
May 16, 2011 | Vicks Warm Steam Vaporizer 1.5 Gallon...
I tryt to turn on my humidifier tonight.1st the mist was coming out just little bi,but there was no green light on,like the manual sed and the humidifier was making some wird noises too.
Welcome to Fixya!
  • Ensure that the water tank cap is secured properly to water tank.
  •  Empty out water in water basin. Place filled water tank on to empty water basin.
  •  Clean Water Level Sensor.
Hope this helps!
Oct 26, 2010 | Crane Elephant EE-3186 1 Gallon Humidifier
Ruud 90 deluxe plus, in the last week blower motor noiser
George, make sure the belt is not loose flapping around making all that noise.
Not hard to change if you can get one from an hvac friend, they won"t sell to homeowners normally.
Jan 18, 2009 | Honeywell Power Humidifier: Furnace...
Humidifiers Logo
237 people viewed this question
Top Humidifiers Experts
Mack Baxter
Dennis
Are you a Humidifier Expert? Answer questions, earn points and help others
