Question about Audiovox VE1020 10.2 in. TV/DVD Combo
CD player idicates all disks "bad"
Mechanicly everything seems to work - but any CD or DVD (even directly from Blockbusters) had a "Bad Disk" error after being inserted. I cleaned the lens of the DVD drive, but no help. Any suggestions to fix or to get a new DVD drive for this unit would be greatly appreciated. Thanks.
  • Peter Silversmith May 19, 2007
    I did open the unit and clean the lens - but as I said, this did not help. I'd appreciate any other thoughts, or a source to get a replacement dvd player component, which I could simply swap out. Thank you.
  • mrshah Nov 10, 2008
    Yes, I have the same problem. How did your problem got solved ?
  • 49 Answers
U can manually clean the lens using cotton buds to wipe the lens.but the problem is u need to uncover the tv set.and the player itself inside the tv.u need some assitance from prof. serviceman. hope this help u...
Posted on May 19, 2007
I AM HAVING ERROR EACH TIME I TRY TO PLAY A CD.
When your CD does not read any disk, and returns error, that is usually because of a problem with the optical laser lens that is dirty, faulty or opaque, or a faulty spindle motor unit.
If it is a lens problem, then you will hear disk spinning, whirring and clicking, but the TOC (table of content track at start of CD/DVD will not be read, therefore the error.
Whe this problem is starting you may be able to read only few CD, DVD. After more prolonged usage , the unit will start losing the rest of functions, and ends up not reading anything at all, and returning error.
If instead there is no noise, and disk does not spin at all , then there is a faulty motor, or the motor micro-switch is bad. This situation is far less common than the lens problem.
Try first using a CD/DVD cleaner disk to clean the lens. If that does not work you will need to disassemble the player , and clean lens directly with q tips and isopropyl alcohol, or to replace the lens, or the whole drive unit.
Sep 04, 2009 | Technics SL-MC50 CD Player
Dvd player always says no disc . will not load
That happens because of a problem with the optical laser lens that is dirty, faulty or opaque, and will start operating on certain disks better than others.
In that case you will hear disk spinning, whirring and clicking, but the TOC (table of content track at start of CD/DVD will not be read, therefore the error.
Whe this problem is starting you may be able to read only few CD, DVD. After more prolonged usage , often the unit will start losing the rest of functions, and ends up not reading anything at all.
Try first using a CD/DVD cleaner disk to clean the lens. If that does not work you will need to disassemble the player, and clean lens directly with q tips and isopropyl alcohol, or to replace the CD/DVD lens, or the whole drive unit.
Aug 28, 2009 | Philips DVP3962 DVD Player
Wont recognise any disk
When you get no disk error, that is usually because of a problem with the optical laser lens that is dirty, faulty or opaque, and will start operating on certain disks better than others.
Whe this problem is starting you may be able to read only CD, DVD or Blue ray, or for example only DVD-R and not +R , or only to read and not to write and so on. After more prolonged usage , often the unit goes losing the rest of functions, and ends up not reading anything at all.
Try first using a CD/DVD or Blue ray lens cleaner disk to clean the lens. If that does not work you will need to disassemble the drive , and clean lens directly with q tips and isopropyl alcohol, or to replace the CD/DVD lens, or the whole drive unit.
May 04, 2009 | Televison & Video
No Read error even with out a DVD inserted
Apr 19, 2009 | Panasonic DMRES15 DVD Recorder
I have a 2004 ext cadi and bought a 6 changer cd player. when I place a cd in it shows no disk what gives? radio works, changer light up
hi, hate to be the bringer of bad news but, it seems to be a dead lens you are experiencing. The no disk error basically means that the lens sensor isn't active and it responds as if the disk was not inserted even if it is. replacing the lens will fix this issue.
Mar 07, 2009 | HP LightScribe dvd640i (DVD640I)...
it's either the lense inside needs to be clean off or it really needs a repair.. it will not take much time if you bring it to repairshop..
Jul 29, 2017 | Sanyo HV-DX2E DVD Player/VCR
Can not recognise any dvd or cd
Oct 26, 2008 | Samsung DVD-P144 DVD Player
DVD will not finalize
Bad Disk batch is the most common problem if it is occuring with the same batch of dvds. Other problems could include that you need to get a firmware upgrade for higher speed discs. If you are using a disc that burns faster than the current speed of the machine you need to download the upgrade (follow the directions that are given in most dvd blank packs) and insert the CD that you downlaoded the program onto into the DVD player/recorder.
Feb 09, 2008 | Zenith XBR716
Audiovox VE1020 10.2 in. TV/DVD Combo Logo
100 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
