Question about RCA M4208 MP3 Player
My mp3 player won't stop saying initaliazing
The screen is frozeen on initlazing and won't finish that step
  • 1 more comment
  • Anonymous Jan 05, 2009
    Mine did the same thing. Worked the next day, so I'm hoping it was an internet problem.
  • Anonymous Jan 07, 2009
    Mine is stuck on initalizing. I even tried to reset it and nothing,
  • nm0655 May 18, 2009
    turned player on, i barely noticed it said something about being to hot & it shutdown. I was at work , it wasn't hot. then when i turn it on, it gets stuck on initalizing.
  • 8,596 Answers
Reset the player first, but your database might be corrupt. The firmware upgrade will help you over come the issue one time only.
Here are other things to check:
RCA M4208
Make sure the lock switch on the back is in the unlocked position. For the player to say "Loading," especially the first time you plug it into the computer, is normal - your computer is communicating with the player, installing drivers, and trying to load the Easy Rip Software. If it stays on loading past 10 minutes, however, something is not right. If you have selected to open the device automatically using Windows Media Player, you are headed for trouble, especially if you have more music and other files on your computer than the mp3 player can handle. If you have accidentally done this, disable auto-sync in Windows Media Player.
If you have checked the above, and you are still having problems, disconnect the mp3 player from the computer. Hold in the power button for 10 seconds or more to reset the mp3 player. Try plugging the mp3 player into the computer again. If it stays on loading for more than 10 minutes, unplug the mp3 player, go into the settings menu and change the mode from MSC to MTP or vice versa. If it still misbehaves when you replug the mp3 player into the computer, download the latest Easy Rip software from RCA's website and update your player's firmware - take note of the section they have on Windows Vista if you have Windows Vista. Good luck!
-Tha Mp3 Doctor
Posted on Jan 06, 2009
After charging,the screen says philips,and wont do anything else
Hi Cheryl, The link below is a youtube page full of videos showing how to turn on your mp3 player and unfreeze it.........CHEERS..
how to fix mp3 player that won turn on YouTube
Apr 24, 2016 | Philips GOGEAR Audio Players & Recorders
My computer says my itouch is a camera
This is normal.
Step 1: To sync songs, videos, and apps, get iTunes from the Apple website. http://www.apple.com/itunes/download/
Step 2: Double click the file after it has downloaded and just keep hitting Next.
Step 3: Connect your iPod once it is done installing (the screen with the finish button).
Step 4: Just follow the on-screen instructions, your iPod should now be set up.
Jan 27, 2011 | Apple iPod touch
How do i charge my sansa mp3?
  • Step 1:Plug the appropriate end of the USB link cable that came with your SanDisk MP3 player into the MP3 player itself. The port for this cable can be found on the right side of most models of SanDisk MP3 players.
  • Step 2:Plug the other end of the USB link cable into a free USB port on your computer. This will effectively connect your SanDisk MP3 player to your computer.
  • Step 3:Turn your computer on. This will cause your SanDisk MP3 player to automatically begin drawing power from the computer and charging its battery. On the screen, an indicator light will flash yellow while the player is charging.
  • Step 4:Disconnect the cable from both your MP3 player and your computer when the device has finished charging. You will be able to tell when the charge is complete when the indicator light that previously was flashing yellow appears as solid green.
  • Sep 17, 2009 | Audio Players & Recorders
    I HAVE AN MP610-2G MP3 PLAYER, VIDEO WITH FM RADIO USED IT A COUPLE OF TIMES WENT TO TURN IT ON YESTERDAY AND IT SAY'S FILE SYS ERR I'VE TRIED THE RESET BUTTON BUT STIILL CAN'T DO ANYTHING WHAT NEEDS TO BE...
    whao the is really big, what i will ask u to do is to read the manual were it tells u about troblshooting if u have not done that, try to formate it back to factory settings and if the files ae corrupted delete them and upload new ones. i had a similar problem when i just got mine but didn't show something like that, the file were unable to play and it got frozeen.
    Jan 12, 2009 | Coby MP-C7085 MP3 Player
    The screen is turning white when I change song
    You could possibly try recovery mode?
    or formatting it and starting over, see if that helps
    easy way to format
    1.Shutdown player
    2.Hold Rec button
    3.Turn player on
    4.Plug your player into the PC
    5.Go to My computer
    6.Find a Icon named 16Mb Format
    7.Open that and make a new text file
    8.Name it sansa.fmt
    9.unplug player and it will say Formatting.....
    10.when its finished it will reset , or shut off, when its done turn it on and see if that helps
    May 08, 2008 | SanDisk Sansa e260 MP3 Player
    Sony NW-E405 MP3 Player
    Try formatting the device again using its built-in formatting features.
    (WARNING: There is no way you can retrieve your data. Since it has already been formatted, it's assumed that you have backup.)
    In your Sony NW-E405 MP3 Player:
    1. Press and hold the SEARCH/ MENU button
    2. Go to ADVANCED MENU (press the Play/ Stop button)
    3. Select FORMAT (press Play/ Stop button)
    4. From the opt "Format OK?" select OK (press the Play/ Stop button)
    5. Once finished, you can Cancel out.
    After these steps, your device should screen out "No Data." From there, you can re-transfer your files.
    May 07, 2008 | Sony NW-E405 MP3 Player
    Wont turn on past start up screen
    Here are instructions on how to use recovery mode procedure to make the mp3
    player turn on. Do the following steps:
    1. Turn player off. Hold the power button down for 20 seconds to make sure
    it shuts down then put the "Hold" switch ON. The Hold switch is located at
    the top part of the mp3 player.
    2. Now hold the "Record" button while you connect it to the computer. Keep
    holding it until it finishes installing the new device.
    Mar 26, 2008 | SanDisk Sansa E280 MP3 Player
    Mp3 player keeps saying finishing and won't finish, and says connecting but not connected
    instead of syncing, you can drag and drop the files, just click "open files to view storage", when you plug it in, then drag stuff from the media player onto the mp3 player's file
    Nov 02, 2007 | Samsung YP-Z5FA MP3 Player
    Samsung yp z5 doesnt work!
    see the reset button on the bottom? press it. mite have to use a sharp pencil or a pin.
    Jan 08, 2007 | Samsung Yepp YP-Z5AB / YP-Z5AS MP3 Player
    RCA M4208  MP3 Player Logo
    117 people viewed this question
    Top RCA Audio Players & Recorders Experts
    Gyula Lacz
    Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
