Question about Home
I have a Liesure Bay lb102 smart series hot tub I replace the heater becuase the person I brought it from said it was not working. The hot tub comes on the heater light is on and stays bright but no heat. I have check all the power, there is power going to the heater the only thing is that the heater has power when the switch clicks on and when it clicks off. Is this why its not heating
4 Suggested Answers
PartsCenter
  • 125 Answers
SOURCE: Jaccuzi hot tub will not heat?
sounds like it maybe the heater again. Have you pulled it out and checked the ohms? it should be at least 10.5 ohms
it could be the thermostat or the pressure switch - if either of those are not working it will not heat either.
Posted on Feb 24, 2009
uspartscente
  • 717 Answers
SOURCE: I just installed a new whirlpool jacuzzi tub with
if the light on the heater is not coming on when the tub is full of water and the pump is on then the heater is not working.
check the circuit breaker to make sure it is on.
the heater and the pump cannot be on the same circuit. They have to be on separate circuits.
Make sure they are on separate circuits.
Check to make sure you have the heater installed in the correct place.
there is a pressure heater that mounts anywhere after the discharge of the pump.
there is a vacuum heater that mounts in front of the pump in the suction line.
if you put on or the other in the wrong place it will never come on.
Posted on Jan 17, 2011
uspartscente
  • 717 Answers
SOURCE: leisure bay spa series c,
What light is blinking? The heater light? Because the heater light will not come on until the spa goes through the purge cycle when the breaker is first turned on.Exactly what is happening once the breaker is turned on
Posted on Feb 11, 2011
I have a orca bay hot tub just replaced upper display now says hl
replace the High limits or make sure recirculation pump is working
Aug 27, 2014 | Pool & Spa
Glacier bay faucet manual
Contact glacier bay to get a replacement control/handle assembly. Usually their customer service department is good at replacing the parts under warranty
You should have individual cold & hot water supply shut-offs in your basement for your tub/shower; if not, now's the time to install them.
If I could be of further assistance, please don't hesitate to ask.
Jul 28, 2014 | Pegasus 873-0127H2 Lyndhurst Single Handle...
Where can i view a leisure bayhot tub manual?
You can find a copy of the Leisure Bay hot tub owners manual on The Cover Guy website. We also have a guide for error codes and information relating to Leisure Bay hot tubs. Leisure Bay Spas Hot Tubs Information
Jun 11, 2014 | Qca Spas Dream Series Dream Master Hot Tub...
Hot tub heater not working
Yes, note the manufacturer and watts of the heating element (should be on the heater)
May 27, 2013 | Qca Spas Majestic Series Aruba Xl Hot Tub
Motor will not come on. flashing OH on tub display dial. Dream maker Model #8003 x 400 series 86L Just purchased used spa and have no manual or directions. thanks
OH stands for Over Heat situation.
If the motor is not working at all, you are getting the OH code because of that. The OH happens when there is not enough circulation in the hot tub which causes the water near the heater to overheat the sensor located in that area. It sounds like either the pump has failed, the wiring has shorted to the motor, or the control board is not telling the pump to come on.
Its probably a bad motor since the heater is obviously activating, which it wouldnt if the pumps motor was getting no power. Replace motor and all should be well again.
Apr 14, 2011 | Dream Maker Spas Dream Maker Ez Spa Hot...
The hot tub is no longer heating
There are two main items to check. I do not recommend them unless you are qualified to work with electrical. The 2 main things that this could be are:
1. Pressure switch failure( (hot tubs need a sensor to tell the computer when it is safe to operate. If the pressure switch is out, then it will not heat) if this is a hot tub with a 24 hour circulation pump, then the pressure switch would actually be a flow switch.
Fix: Replace pressure switch/ flow switch
2. Heater element failure. (This type of failure typically trips a GFCI breaker)
if the heater element is out, then it will short to ground causing the hot tub to shut down repeatedly.
Notes: Are there any trouble codes coming up on the display panel? these help out greatly when troubleshooting like this via- messages
Oct 21, 2010 | Qca Spas Paradise Series Paradise Supreme...
I have a 2004 great lakes hot tub with a balboa controler. My hot tub heats up fine when the pump runs on high but the temp light never comes on when the pump runs in low.
check to see that the flow switch is working properly, it may not have enough flow on low speed to allow the heater to turn on. Make sure your filter/s is/are clean. If you have a pressure switch instead of a flow switch, it may need to be adjusted or replaced.
Feb 04, 2010 | Qca Spas Jewel Series Topaz Plus Hot Tub
Jet pump will not shutt off after I replaced heater relay. Tub is a hot springs landmark with an IQ2000 panel the year is also a 2000
it sounds like the pump relay may be stuck closed. Also check the temp readout, if it thinks the water is too hot it will try to cool the water by running the jets and sometimes the blower as well.
Dec 08, 2009 | RTO 2 Person Spa Hot Tub 8 Hydrotherapy...
Home Logo
260 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
