Question about Eastman Outdoors 38094 Turkey Fryer
Turkey fryer has flame blowback
It wont stay on with out holding dow button for timmer then flame blows back
2 Suggested Answers
  • 10865 Answers
SOURCE: I have a 28 quart aluminum turkey fryer. can I fry
hello. yes, in fact it can handle a 30 pound turkey! Joe
Posted on Mar 22, 2010
Burner wont stay on, once i release the button the flame goes out
You need a new thermocouple. Replacing it you fix your problem.
Dec 27, 2013 | Masterbuilt Turk-'N'-Surf's Turkey Fryer
Turkey fryer won't start
Yo! the Dang pan has to be filled and on the burner which makes contact with the auto shut off sensor that is measuring the temp of the pan. The weight of the filled pan holds that Lil temp sensor down and allows the gas to continuously flow as if you were holding that Lil red button. So after hours of trying to light it without the pan you should find that it does work with the filled pan on the burner holding the red button, stick a match in the hole and let the button go and watch the blue flames flow. My gripe now is that it shuts off after the oil temp reaches 250 to 260 degrees then you have to reignite. Oh yeah my 10lb Turkey was crazy tasty.
Nov 21, 2012 | Brinkmann 815-3786-0 Turkey Fryer
Bass pro turkey fryer wont stay lit
wire around timer or set something on button so runs all time. but also set a cheap alarm or use one on cell phone to remind you time is up.
Feb 25, 2012 | Bass Pro Steamer/Fryer Combos Turkey Fryer
My flame keeps on going out on my turkey fryer it has a heat sensor on it how do i position the sensor so the flame doesnt go out
The heat sensor for your turkey fryer is preset to 375 degrees F. Once the oil reaches that temperature, the sensor turns the flame OFF, so that the oil will not boil over and ignite. Once the oil cools to 325 degrees F, the burner can be relighted . Use extreme caution when relighting the burner. Altering or repositioning the heat sensor would make the fryer unsafe to operate.
I'm sorry. I which I had better news for you. Always, err on the side of caution & safety when dealing with open gas flames.
Jul 06, 2011 | Brinkmann 815-3530-2 Turkey Fryer
Fryer wont stay lit, only two burners will lite, and will only stay lit for about 5 min. will then go out and must start over
Check the gas pressure, it must meet the standard gas pressure written on the nameplate. Check also the quality of pilot flame, poor pilot flame quality will not properly heat up the thermopile which in turn will result in poor fryer operation.
Jun 15, 2011 | Pitco Frialator E24 Deep Fryer
Propane fryer wont stay lit
Probably the thermopile or thermocouple that senses the flame and holds the valve in the ready state.
Mar 14, 2011 | Imperial IFS40 Deep Fryer
Turkey fryer is burning rich w/ yellow flame and cannot be regulated to blue by air mix plates
first check the gas regulator is the presher right? then try cleaning out all the pipe work and the burner jets i bet you have a dead spider stuck in the gas pipe as it enters the burners,,this would upset the air to gas mix,,so its running on a rich gas mix
Aug 09, 2010 | Brinkmann 815-3786-0 Turkey Fryer
Can't light Lodge Outfitters turkey fryer
Turn the timer knob to on. there should be a plunger type button on the botom of the timer. H old this in while pressing the igniter.Continue to hold plunger in for about 10 seconds after the burner lites. If you hear the flame go out , relight and hold a little longer. The timer knob will shut off after about 20 minuites
Jul 11, 2010 | Grilling
Cant get the flame to stay lit after holding the red button
THIS IS FROM BRIKMANN WEBSITE SUPPORTMake sure the tip of the thermocouple is located over the edge of the burner so that it gets hot when the burner is in operation. Also, check all the wiring connections to make sure nothing has come loose. It is also important to use the turkey fryer with the pot that comes with the unit. The pot must sit on the spring loaded temperature switch in order to determine the temperature of the liquid in the pot.
Jun 23, 2010 | Brinkmann 815-3786-0 Turkey Fryer
Dean SR152GN Fryer
Is the unit propane?If so the baffles may be sooted up and need to be cleaned.This usually causes blowback.
May 19, 2008 | Dean SR14E Deep Fryer
Eastman Outdoors 38094 Turkey Fryer Logo
27 people viewed this question
Top Eastman Outdoors Grilling Experts
paulcarew
Dan Webster
Dan Webster
Are you an Eastman Outdoors Grilling Expert? Answer questions, earn points and help others
