Question about Olympus Camedia C-150 Digital Camera
My camera is showing Write protect error
I know this might sound like one of the error codes on pg 32 of the user manual but when i tried to change the properties of the folder of the memory of the camera (by unchecking the read only box) using the computer it changes temporarily and when i refresh it the card goes bacj into read only mode. when i format the card directly from the camera i can only open the camera shutter "once" to click snaps, the next time i open the shutter it goes into write protect mode. please help.... :(
You format the card from the menu of the camera, and you open the camera moving the cover on the lens without doing nothing else before and the camera works again, I spend 3 hours with computer and camera and i luckily found the solution.
Posted on Dec 05, 2007
    Genius:
  • 2,985 Answers
You have to now FORMAT the card in the camera. You must never modify the card in a computer - apart from opening/closing a folder or moving files.
Posted on May 19, 2007
I'm getting a r16 error on my D90
The "r16" in the display is not an error code. It is simply informing you of the number of exposures that can be held in the camera's internal high speed memory before shooting would have to stop while the D90 transfers the pictures to the memory card. If you held the shutter release, you could watch the r16 value decilne by one for each exposure (r15, r14, r13, etc.).
Page 256 of the D90 User's manual indeed shows the Err error code, and defines it as a "Camera Malfunction", "Release shutter. If error persists or appears frequently, consult Nikon-authorized service representative." The "err" error code is a generic error. The camera has detected a problem, but it doesn't know exacly what, similiar to the fEE code. The "err" code could be camera / lens contacts or it could be a circuit board or even shutter failure. You've already tried the common contact cleaning fix (that never seems to solve the problem) without any luck, so you might have to call Nikon Support and arrange for service.
Jan 31, 2013 | Nikon D90 Digital Camera with 18-105mm...
How can I reset the passcode for GE Simon XT Alarm .
Here is the user manual for you: http://www.securtek.com/products-services/system-user-guides/ge/GE%20SimonXT%20User%20Manual.pdf . Answers are found on pg 31-32. Go to Section heading entitled "Access codes" (shown in blue). It then walks you through changing the Master Code, User Codes 1 to 8, and the Duress code. Not sure which code you are looking for but the steps for each code are pretty simple. Hope this helps.
Jun 03, 2011 | GE Computers & Internet
Manually how to solve the system error c:32:01 in sony H20 camera when opening video mode
The C:32:01 error code displayed on the Camera screen indicates the internal malfunction happened in the Camera. Try turning off and on the Camera to check if it works. If the issuer persists, perform the following steps:
Performing a manual power reset may help:
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settings Menu of the Camera to OK. This will set the user defined settings back to factory default. The images and videos will not get deleted.
Reset the camera to factory specifications to try resolving the issue.
Thanks for resolving the issue.
Feb 20, 2011 | Sony Cyber-shot® DSC-H20 Digital Camera
Yamaha model HTR 6130 Hardly used , professionally installed , well ventilated has been working well . In the last couple times used after 10 / 20 mins. audio drops out both on T V and D V D mode...
Do you have the users manual? If not, google your model number and select manualslib.com. I am not seeing error codes to help diagnose, do you see any error indication? Your users manual says to check speaker impedance for a mismatch to your amp and speakers. There may be a problem causing the unit to go into protect mode. Check all speakers and speaker wiring. Try removing all speakers and see if problem duplicates. Has a timer function been accidentally programmed? If you have a mute indication display, see if that is activating. Are you using HDMI functions, HDMI intermittencies can be prevalent on different makes and models. Try different inputs, does failure remain? If this doesn't help, more than likely you need professional repair. Is overheat protection showing? Does check spkr wires show on display? As a last resort, before service, do a system reset to factory values, pg 59 or 63 in manual.
Dec 05, 2017 | Audio Players & Recorders
I have a Sony PDX-10 and it's giving me two blinking yellow symbols (underlinded triangle and tape with line through it) when I fire it up loaded with a tape. Tried changing with tapes that work fine in...
Looking at PDX 10 User Manual Page 232
Your description -
Under lined Triangle
Cassette Ejection needed
Slow Flashing: The Write protect tab exposed
Fast Flashing: Moisture Condensation
Cassette out of tape
Self diagnosis display function activated
Sounds like the diagnosis function maybe your best shot......
Check displayed error codes in viewfinder on Page 231 of the User Manual or let me know if you dont have copy of them.
Tape Symbol Flashing:
Tape near end
No cassette inserted
The write protect tab exposed.
I think this is basically telling you the loading mechanism has a problem, the viewfinder is displaying an error code indicating the nature of the fault..... IF error Code is : E61:........ or E62........ (dots indicate extra numbers) these MUST be referred to Sony Service Centre.
Hope this may help
Ian 561
Jun 24, 2010 | Sony Dvcam DSR-PDX10 DV Digital Camcorder
2005 Toyota Corolla Radio fuse
Pg. 250 of your 2005 Owner's Manual shows the location of the Fuse Boxes. There is one under your hood on the driver's side and the other is under the dash just to the left of steering wheel. Pg 272, will show you how to replace the fuses. Pg. 286-287 gives a diagram and description of each fuse and what part of the electrical system it enables.
This portion of the electrical system correspondeds to the fuse in position 32 on pg. 287 of the manual.
Your going to have to get on your back with a flashlight and open up the fuse box under the dash by the steering wheel. The lid of the fuse box shows the positions of the fuse and their amperage rating. Like I said, replace the fuse in postion 32 (15 Amp). There is a spare 15 Amp fuse in the fuse box under the hood (easy to get to, see the diagrams in the owner's manual). There is also a fuse puller tool next to the spare fuses.
Aug 11, 2009 | 2005 Toyota Corolla
CF ERROR CODE ON OUR L.G. FRIDGE,WONDERING WHAT THIS MEANS
See pg. 32 of the service manual: http://136.166.4.200/contents/Fridge/LFX25960/LFX25960_Service_Manual.pdf
This morning I woke up to an error code of 1F. Gotta love LG quality!
Dec 21, 2008 | Refrigerators
On board sound
Hi nrls14, it can get pretty confusing with Gigabyte.
Go to page 9 in your manual or Pg 13 if using Adobe Reader. Motherboard layout. If you download the manual which is in pdf format you'll be able to enlarge the manual which will help you to see everything much better.
Download manual from here: http://china.giga-byte.com/FileList/Manual/motherboard_manual_7n400pro2_e.pdf
This is the English manual. (Downloading from china is a faster site).
Find SUR_CEN located between PCI slots 2 & 3 on the motherboard. Than go to pg 32 in manual or pg 36 in pdf. Set the pins SUR_CEN. Set a jumper over pins 1&2 & 5&6.
Front Audio Connector, leave a jumper across pin 5&6 & 9&10 (Default). On page 22 in manual, pg 26 pdf. Follow Method1:
Instructions. (Test your speaker system). You may need some tweaking & this can be done with the software included on the Gigabyte CD by installing the sound effects manager. Go to page 78 in your manual or pg 82 in pdf. Page 80 in manual, pg 84 in pdf. For six channel 5.1 sound. If you decide to use the Advanced 6 Channel Analog Audio Output Mode (using Audio Combo Kit, Optional Device). Follow the instructions on page 81 in manual or pg 85 in pdf. (Do not let the picture on pg 81 spook you). Pg 81 shows a set of pins not located in-between the two PCI slots. You make this connection by removing the two jumpers on SUR_CEN & plug in the SURROUND-KIT on to SUR_CEN pins. Lastly, both motherboard manuals are the same for the GA-7N400 & the GA-7N400 Pro.
Good luck nrls14!
Mike
Aug 25, 2008 | Gigabyte GA-7N400 Pro Motherboard
Turned sound off at wedding and can't turn back on.
On your Setup Menu (icon of tools), check to see if Mute is set to ON. If so, change it to OFF.
Jun 14, 2008 | Canon PowerShot S80 Digital Camera
Soundstorm car dvd player
This is from the soundstorm website: If your DVD player shows a "Parental Code" on the screen. Here is the factory default code. It is 3308. Once you have this code, you can go into the settings and change the level to whichever level you like. Here is a break down of the levels: Level 1 = G Rated Level 3 = PG Rated Level 4 = PG 13 Rated Level 6 = PG-R Rated Level 7 = NC-17 Level 8 = Adult Level 0 = No Parental
May 29, 2007 | Soundstorm SDVD-100 Car DVD Player
Olympus Camedia C-150 Digital Camera Logo
88 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
