Model no xg4222
SOURCE: 7 digital photo frame problems
Yeah, I just got one too and I have no USB thingy, and I kinda need my memory card.... hmmm.... maybe it should come with one. That's a bright idea huh! And how on Earth do you get music on it?!
SOURCE: sizing digital photos to display in digital frames
Use the 16:9/4:3 key on the remote to toggle between widescreen and normal view. Most digital camera photos look fine at 4:3.
SOURCE: Transferring photos from digital to photo frame- How to? Please
If you need to transfer to your computer just connect the USB cable from the camera to the computer, switch the camera on, turn the dial to View and Voila! A connect icon appears on the camera screen. Follow instructions on screen to download photos; develop if necessary. Presumably you will then be able to download the jpegs to your photo frame from your computer.
SOURCE: can run photoviewer program for photo keychain
1. Connect the USB cable to your computer and Digital Photo Keychain. Press ^/down to
access the USB update mode on the Digital Photo Keychain and press the menu/power
button ( ). Your keychain will now say, “updating” and you are ready to open the software
on your computer. (Please note that the keychain will continue to say, “updating” the entire
time that you are working with the program on your computer and will change only when you
safely disconnect it from the computer.)
IMPORTANT: The keychain MUST be plugged in and in “update” mode in order for you to
open the Photo Viewer program. If it is not plugged in, or is in the wrong mode, you will get
the following error: No photo viewer is found, program terminated!
2. Once the keychain is plugged in and in “update” mode, double click the Photo Viewer
icon on your desktop to launch the application.
3. Use Photo Viewer’s file manager to browse photos on your computer.
SOURCE: Photo Keychain Won't Work
Found this on Yahoo.
1. Download the drivers from here: www.mscustomercare.com
2. Make sure the device is fully charged and not in charge mode.
3. Unzip and install the drivers with the device connected to your pc.
Try to see if that fixes the issue
