Question about Breville Blender Professional BBL800
I have a Breville BBL800 Blender. I'm not sure why but the power light comes on but when we put the jug on the light go off so we can't get it working. Any ideas would be appreciated.
3 Suggested Answers
  • 10865 Answers
SOURCE: I need to acquire a glass jug for a breville BLR-3
Hello. The best route to go is to work directly with the manufacturer. here is their contact info
  • AskUs@BrevilleUSA.com
  • 1.866.BREVILLE (1.866.273.8455)
  • 8a to 5p Pacific Time
  • Posted on Mar 22, 2010
    SOURCE: blender will not run. the power button is lite but
    There is a 10 Amp thermal fuse (SF129E) that is supposed to create an open circuit when the motor windings exceed 133 C degrees. Although this fuse should close again when the motor cools down it can become perminantly damaged. Locate the fuse by following the black leads from the coltrol board to the motor brushes. It's inside a cloth insulating sheath secured against the windings with a metal strap and two ty-raps. I bypassed the fuse with a wire instead of replacing it. It would probably just blow again sooner or later. p.s. you need a T10 Torx screw driver to disassemble (screws under rubber feet) $3 at ACE hardware.
    Posted on Jul 22, 2010
    Making a high pitched noise while blending; is motor breaking down?
    there are some Breville Blender troubleshooting tips here
    http://brevilleusasupport.com/bbl550xl/troubleshooting . Tied in with that, a high pitched noise could come in from a few directions:
    Some blenders will use reduction gears to get more torque and power out of a high RPM, lower power motor. If this is the case, the whine could be from the motor, though if you hadn't noticed before, that would not be reassuring.
    Per the troubleshooting, check that the blade is firmly attached, and that the coupling from jug to base is firm. If there are gaps or loos spots, there can be buzzing or whining between sort-of-spinning parts and shafts or bolt threads.
    Check the motor base for dried spilled-on margarita mix or marinara sauce or what have you. they try to seal this pretty tight in a blender, but it has to spin, so food spills can get in the gap and cause friction and resistance, which can in turn cause whining noises from parts not expecting the load. If you do any cleaning or poking there, make sure you unplug the blender first. Shocks are not fun.
    likewise, make sure that blade rotates easily from turning the coupling on the outside of the jug. If not, the bearing may be siezed or contaminated. That you'd likely want to fix by replacement.
    Hope this helps!
    D
    Nov 19, 2015 | Breville Blenders
    Glass Jug replacement for National Blender
    I have that exact same blender, and I'm missing the lid. Are you still interested in the jug?
    May 14, 2014 | Sanyo 5 Piece Cord Free Collection...
    Broken plastic base for CBL25
    FIXYA does not know who might have a broken JUG .
    Dec 03, 2017 | Breville CBL25 Moda Bar Work Top Blender
    Gold powder or particles on base
    It's probably brass, run it a few time and clean it, if it continue, their a good chance that your bearing is dying (grinding it self),check if you can replace that section.
    Jan 06, 2014 | Breville Blenders
    Jug for a Breville Blend Master modelBLR- 3
    Call the manufactor or e-mail the company they'll have it.
    Jan 10, 2013 | Bosch MMB2000 Work Top Blender
    Hello. I need two parts for my Breville Classic BlendMaster Model CBL-10. I need the removable centrally located inner lid and also the blade assembly features patented stainless steel twin cutting...
    Breville CBL10 has been a fantastic appliance but now electrical section works at slow speed only so I will get rid of it, however the glass jug complete with lid, blade etc is still perfect. Does anyone need this part? I am in Rockhampton.
    Jan 23, 2011 | Breville CBL10 BlendMaster Classic Work...
    Breville blender won't turn on. The on light is flashing red instead of solid blue. Worked fine a few days ago.
    FIXED IT - It's the screws on the bottom of the jar assembly, where the blades are attached. There are 4 Torx screws - star-shaped - and when these come loose over time the Blender will start to operate only sometimes. Eventually it will be never.
    Tighten these four screws and everything will be fine!
    Oct 02, 2010 | Breville BBL600XL. 5-Speed Blender
    I need to acquire a glass jug for a breville BLR-3 Blender. Any suggestions would be appreciated !! Thanks
  • Mar 22, 2010 | Breville CBL10 BlendMaster Classic Work...
    Lost Seal for Blender
    I would suggest you contact the company at
    http://www.breville.com.au/ (click on "what's on your mind") and let them know the problem... they should be able to direct you to a UK parts source or help you in some other way.
    Mar 23, 2009 | Breville Blenders
    Any idea where we can get a new jug for a breville blender?
    This happened to me recently. Go to this site and order it directly from Breville. They were very fast and customer service very helpful.
    http://www.brevilleusa.com/home.do
    Jan 11, 2009 | Blenders
    Breville Blender Professional BBL800 Logo
    59 people viewed this question
    Top Breville Blenders Experts
    Mike
    Craig Butler
    Craig Butler
    Joseph Hoffmann
    Are you a Breville Blender Expert? Answer questions, earn points and help others
