Using LCD TV as secondary monitor for PC
I have a LG LCD TV, want to use it as a secondary monitor for my PC. How do I do this?
  • 69 Answers
if u have a videocard that support dvi & HDMI and ur lcd tv support it to than just plug in the cable and go to your ati ccc or nvidia control panel and there u can set the settings
but make sure u have the latest drivers for your video card
Posted on Jan 04, 2009
LG Flatron Monitor flashes on and off intermittently when used with PC
get someone that knows what they are doing and see if someone lives near you and see if they can come over to your house that is technology person and fix it.
Dec 21, 2013 | LG M2362D 23 in. LCD TV
How to PC Monitor Input
use a vga to vga cable and a 3.5mm jack to 3.5mm jack lead like these
you will then need to to switch to pc input and your computer should display on the tv, if your using the tv as a secondary display from your computer. I.E. you already have a monitor connected or its a laptop you will need to go into display properties in your control panel and click on settings and then enable the second display.
Apr 22, 2011 | Memorex MLTD2622 26 in. LCD TV
Trying to hook my home PC into my LG TV gets me the message Invalid Format, what can I do to get the signal or can i use this tv for my monitor with a dell PC
Connect VGA (D-sub 15 pin) cable from PC to TV (RGB PC) input jack. Connect audio cable from PC to TV. Set screen resolution on PC to be compatible with TV, such as 800 X 600 or 1024 X 768 etc. Select on the TV, the PC INPUT using the TV remote when ready to use as monitor.
Under PICTURE on the TV select SCREEN (RGB-PC). You can AUTO-CONFIG or you can set resolution manually to the same you set PC to. Other adjustments can be done here as well to get optimum picture on TV from PC.
Mar 01, 2011 | LG 26LG30 26 in. LCD TV
I have upto now been using my lg Flatron L1919S monitor as a tv with a separate tuner. Today i replaced it with an lcd tv and was going to use the monitor for my computer. However when i connected it up...
It means your PC video resolution is too high for the monitor to display, you need to set your PC video to the native resolution of this monitor, 1280 x 1024 @60Hz.
Start up in sfae mode (hit f8 while booting up), select VGA support, then right click on desk top/properties to bring up display property/setting. set the new resolution , reboot.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 15, 2010 | LG Flatron L1919S LCD Monitor
I have upto now been using my LG Flatron L1919S monitor as a tv with a separate tuner. today i replaced it with an LCD tv and was going to use the monitor for my computer. however when i connected it up...
It means your PC video output resolution is too high for the LG monitor to display (your old monitor (CRT) can handle higher resolution than this LG LCD monitor), you need to set the PC video resolution to native resolutionof this monitor which is 1280 x 1024 @60Hz. You may have to use the old monitor (CRT) to set the resolution to 1280 x 1024@60Hz, then hook up the LCD monitor.
Mar 27, 2010 | LG Flatron L1919S LCD Monitor
Monitor black with green light on
did you changed frequency of that monitor? if it is out of factory setting that could be the problem, try to connect it again as secondary and set Hz to default, if that does n't work try same settings on both monitors? i have connected two monitors i had same problems , my secondary monitor was clone for tv if you are using secondary monitor for clone to ty (with s-video or whateever) if tv is old it must be 60HZ 800x600...
Apr 27, 2009 | Computers & Internet
Connecting laptop to lcd
You may need to use the S-video cable for video. Make sure video mirroring is disabled on the powerbook. Also, make the external monitor the primary display by dragging the menu bar to it in Displays preferences (Mac OS X) or the Monitors control panel (Mac OS 8 and 9).
Mar 14, 2009 | LG 32LG30 32 in. LCD HDTV
Lcd tv wont let me view pc input
First, make sure you do not have a bad cable going from the PC to the TV.
On your computer try the following:
Go to START, CONTROL PANEL, DISPLAY PROPERTIES
Make sure you have the secondary monitor enabled.
Set the screen size for the secondary monitor to 800 X 600
Go to ADVANCED PROPERTIES and make sure the refresh rate for the secondary monitor is set to 60HZ.
These settings on the PC should make the picture compatible with most all TV monitors. If the problem still persists then you may indeed have something wrong with the TV.
Jan 06, 2009 | Televison & Video
Invalid format when conected to laptop
Go into your control panel. Select display. There will be a picture showing 2 screens. Select the 2nd screen, and lower resolution to it's minimum. Apply and test. Slowly increase till you find what your happiest with. Worked for me using a ASUS laptop and LG60'plasma.
Jun 29, 2008 | LG 42LC2D 42 in. LCD HDTV
Computers & Internet Logo
71 people viewed this question
David Payne
David Payne
