Question about Pride Mobility Products Pride Mobility Maxima 4 Wheel Hd Scooter with 55AH Battery & Charger + Flat Free Tires 22x18 Hi Back Deluxe Fabric Seat
Battery power on mobility scooter
My mothers shoprider deluxe 4 wheel mobility scooter has lost some of its speed and distance,was told batteries u/s and replaced them [ no joy ] new batteries fully charged goes approx 100m and the power and battery level indicator starts to drop when in motion, stop and the battery level indicator is back up to full. I have checked that the front wheels are free to turn and the magnetic brake is operating as it should.
  • 3 more comments
  • Dan Hudson May 11, 2010
    Do you have a voltmeter? Check the voltage on both batteries 5 minutes after charging but before you use the scooter and post the results here.
  • Anonymous Mar 14, 2014
    batteries for medline 3 wheel mobility scooter
    just fitted two new batteries fully charged
  • Anonymous Mar 26, 2014
    Checked two fuses both ok battery fully charged no sound when trying to move forward or back
  • Anonymous Mar 28, 2014
    There is no more to add
The Hand Control has probably bent in from use. ( Where she Pushes the throttle Control )
Grab a hold of it and bend it out towards you slightly
The part about the indicator going down when she moves and back up when she stops is normal
Posted on May 07, 2009
  • 40 Answers
Most scooters show a drop on the battery level meter when in use, as long as it is`nt slowing down it should`nt be a prob. I mean,when you engage the throttle you ARE putting a load on the batteries,so it`s only par for the course that the indicator would drop a bit.
Posted on Apr 03, 2009
How to find serial number and model for Shoprider deluxe
Hi most scooters have serial numbers & date of manufacture on the frame around the transaxel under the rear cowling cheers
Apr 25, 2016 | Shoprider Sprinter Deluxe Four Wheel...
My shoprider dasher has no power
hi, you need to check the battery pack is supply power to the scooter , first check the connections where it connects to the scooter ... , check the fuse(s) contained with the battery pack...
Regards
Rob
www.gewizrepairs.co.uk
Aug 06, 2014 | Shoprider Dasher 4 - Power Wheel Scooters
Why is my shop rider deluxe not working proper with new battery's
Is the high low speed switch turned to high. If it is and its still slow it would indicate a throttle pot fault
Jul 06, 2014 | Shoprider Sprinter XL4 Deluxe
My Battery on my Shoprider Delux is fully charged but lasts only about 45mins is my Battery Knackered?
first of all , this is a common mistake , can you borrow another charger to make sure that is not causing the problem , you need to convince yourself that the charger is okay then lok at the batteries located under the cover located under the seat, make sure the batterys connectors are clean and tight, if all fails sadly it is a batteries replacement.
Nov 21, 2012 | Shoprider Sprinter Deluxe Four Wheel...
No power
The scooter has several safety cutouts, Make sure the charger is unplugged, the free-wheel shift is fully in the engaged position. Then turn the key off and back on. Make sure the speed pot is in the middle position.
Jul 06, 2012 | Shoprider Sprinter Deluxe Four Wheel...
Hi there i have a sHOPRIDER MOBILITY SCOOTER WHICH HAS NOT BEEN USED FOR ABOUT SIX MONTHS AND I NOW NEED TO USE IT I HAVE TRIED TO CHARGE IT UP BUT THE BATTERY INDICATOR ON THE SCOOTER SAYS ITS FULL SO IVE...
The battery it is dying and it dead and the core of the battery it self can't retain enough the of charge of the electricities for to the battery to move the scooter.Change to a brand new battery ur scooter should work fine.
Oct 27, 2011 | Shoprider Sunrunner 4 - 4 Wheel Scooter
Shoprider mobility scooter seems to die of power on incline and battery level indicator goes down to half way can anybody help thanks
Hi my shoprider mobility scooter keeps stopping. Have to switch it off for few mins then it worked. Now when it stops its not starting again and has to be pushed. Has new batterys about 6 mths ago and have checked all connections but cant find any problem. Please help. Pam x
Jun 04, 2011 | Shoprider Sunrunner 4 Deluxe
I have the Shoprider Delux scooter.I brought it second hand.I put in a new battery but its not holding the charge. I seem to have to charge it up before any trips out.When its fully charged and I go about...
Yvonne,
When you say that you put in a new battery, I hope you mean new batteries. This particular scooter takes 2 batteries and just changing one will leave the remaining one in poor condition. Make sure that you have replaced the batteries with the correct size and type. This scooter takes 2, 40 amp hour batteries. Sealed gel AGM batteries are preferred. The batteries should have the number 40 on them with a date code. You need new, fresh batteries to have them work properly. A date code tag of A1 indicates the A month(1st month) or January of 2011 (1 is for 2011). If you are not sure of the battery condition a local shop can load test them for you.
There is a possibility with a 5 year old scooter that a worn motor/brake will cause excessive current draw and drain your batteries. A qualified technician can determine this for you with a service call.
Hope this helps.
Mar 18, 2011 | Shoprider Sprinter XL4 Deluxe 4 Wheel...
Pride Mobility Products Pride Mobility Maxima 4 Wheel Hd Scooter with 55AH Battery & Charger + Flat Free Tires 22x18 Hi Back Deluxe Fabric Seat Logo
529 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
Robin Hill
Robin Hill
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
