Question about Akai Televison & Video
Akai vsg225 error 2
Multiple malfunctions, not ejecting tape wont stop start reads error 2
jomaru
  • 337 Answers
SOURCE: tape door won't open on eject?
Many times I've heard my tape will not eject,most of the time unpluging the unit from the wall for about 10 minutes and then plug it back in,this resets the microprocessor and it goes bak to normal and the tape ejects.I hope it works. Please rate this solution if it does.
Posted on Oct 17, 2006
  • 221 Answers
SOURCE: Error Message and tape is hung up on the drive mechanism.
check the drive belts in both decks. they stretch with age.
Posted on Jan 15, 2008
  • 979 Answers
SOURCE: Tape ejection malfunction
The problem may very well be a slipping spool idler that does not tension the tape properly when trying to eject. Try cleaning the rubber friction surfaces or replacing the part....accordianman
Posted on Feb 15, 2008
dodgecharger
  • 254 Answers
SOURCE: tape doesn't eject all the time
This probably indicates a problem with the mechanicals. The tape carriage mechanism might be out of whack/bent/or broken. You might take the top cover off and see is the mechanism is sticking somewhere.
Unfortunately, modern VCRs (last 10+ years) are very cheaply made, and disposeable, unlike the machines of the '80s which were built like tanks in comparison. Thus, unless the problem is minor, repair is doubtful.
Posted on May 09, 2008
SOURCE: Can't eject tape from deck
On Sony DSR-80P error 02-221 and 02-291 is a problem with the tape pull-in or eject. Mostly the tape stickers are bad situated over the stripe-cover at the top, which should be moving freely!
Remove the stickers from the tape or put them lower on the case. If the tape is already inside the machine is unable to reject the tape - disconnect the machine from electricity to open it or call service...
greetings from berlin, matt.
Posted on Feb 15, 2010
AKAI REEL TO REAL MODEL 1700 OPERATOR'S MANUAL
Here you are Andrew. That is a blast from the past!!
Service Manual and Owner's Manual!
Akai 1700 Manual Stereo Tape Recorder HiFi Engine
Jan 23, 2016 | Computers & Internet
I have an older (1996) Sony Handycam CCD-TRV211. I am using the player to transfer my old 8mm tapes to my computer. The player will play for about 4 seconds then stop. I get a blinking triangle with a...
How are you powering the camcorder ? Many will not transfer videos if battery powered, since the battery may fail. Try again with the camcorder mains powered, see if that helps. Have you cleaned the heads with a cotton bud and a little IPA ?
Mar 01, 2017 | Cameras
I have a jvc gr-sxm26u camcorder and it has two problems... the tape door will not open when the eject button is pushed to the left. 2nd problem. the screen indicates that there is a problem labeled as "...
E01 Mechanism has not fully loaded up to the stop position
E-01, E-02, E-05, or E-06 is an Emergency Error Code. In the event of a malfunction the unit will shut down and display a code which is to inform a technician which area of the camcorder to examine in order to ascertain the nature of the problem. Try the following steps:
1) Remove power source for 1 minute. 2) Reattach power source. 3) Try operating the camera.
The indication E-03 or E-04 is an Emergency Error Code. In the event of a malfunction the unit will shut down and display a code. This is to inform an independent JVC authorized service center which area of the camcorder to examine in order to ascertain the nature of the problem.
The E-03 or E-04 code relates to one of the tape spindles not turning. This could be the result of too much slack on the video tape. If E-03 or E- 04 is displayed it may be possible to correct the problem by removing the tape slack. In order to do this follow these steps:
3) Press "EJECT" (DO NOT PRESS POWER)
4) Repeat above steps until tape ejects.
5) Tighten and insert a new tape."
A common E01 problem with the JVC is caused by electrically conductive residues on the very end of the connector strip which connects the small front circuit panel to the main circuit panel (this residue can only be seen under a microscope). Symptoms are, the mechanism remains closed or the cassette holder will not latch down and remains permanently raised. Basically the micro cannot read the mechanism position data. The connector strip needs to be taken out & carefully cleaned with alcohol.
If all else fails then its a trip to JVC service and a biil of between $`100 and $250 depending on what the problem is. My last E01 was a motor change and cost $180 but the cam has been fine ever since but next cam will be a Canon..
Oct 14, 2009 | JVC GR-SXM260U Camcorder
Samsung vp-d361
This error is a mechanical malfunction, try this:
  1. Eject the tape.
  2. Set to OFF.
  3. Detach the battery.
  4. Reattach the battery.
Here is a link to your manual:
Manual
Apr 18, 2008 | Samsung VP-D361 Mini DV Digital Camcorder
EZECTING TAPE LOADER
  1. Eject the tape.
  2. Set to OFF.
Manual
Mar 28, 2008 | Samsung VP-D361 Mini DV Digital Camcorder
Not ejecting
DRUM FG
In the case there is no DRUM FG input in the
drum rotation mode for 4 seconds or more. This
error is defined as [E04], and the mechanism
mode is shifted to STOP with the pinch roller
set off.
1. The drum cannot be started or drum rotation is stopped
because tape transport load is too high.
1) Tape tension is extremely high.
2) The tape is damaged or soiled with grease, etc.
2. The DRUM FG signal is not received by the syscon
CPU.
1) Disconnection in the middle of the signal line.
2) Failure of the DRUM FG pulse generator (hall element).
3. No drum control voltage is supplied to the MDA.
4. No power is supplied to the DRUM MDA
Dec 23, 2007 | JVC GR-AXM17U Camcorder
Cannot play tape nor record on tape
  1. Eject the tape.
  2. Set to OFF.
Manual
Oct 08, 2007 | Samsung VP-D361 Mini DV Digital Camcorder
CAMCORDER GR-DVL167EK
YOUR TAPE MAY BE DAMAGED IF YOU TRY TO OPEN THE CAMCORDER - HOLD EJECT BUTTON DOWN BEFORE ! YOU REATTACH BATTERY THEN READ THE ERROR CODE ? IF IT STILL DOES NOT EJECT .
Sep 10, 2007 | Video Cameras
TAPE EJECTS WHEN I PUSH THE RECORD BUTTON
Simple solution.In all probability the Erasure prevention Tab on the cassette is broken. Just paste a Scotch tape on the broken Tab and try again.
Mar 18, 2007 | Akai VS-K338 VHS VCR
Televison & Video Logo
21 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
