Question about Sony Kp-Fx432M91 43" Projection Wega Multisystem Tv
TV won't turn on
Indicator lamp blinking 7 times interval
    Top Expert:
  • Sony Master
  • 14,553 Answers
Here is a link with the codes for this set and others like it:
http://www.scribd.com/doc/43529880/Sony-Blinking-Codes
Personally I would suspect the high voltage block for this set is bad.
Posted on Nov 03, 2012
3 Suggested Answers
  • 1527 Answers
SOURCE: my tv KDF-42E200 sony, after
hello, make sure the lamp is fitted securely and also the lamp cover as well this down to the safety switches hope it works
regards
shaun
Posted on Dec 25, 2010
jdvillanueva
  • 2098 Answers
SOURCE: My sOny tv KF-42WE610.. Won't turn on.. I just
Please let me know how many times it will blink to determine where the exact fault came from.
Jdvillanueva
Posted on Jun 17, 2011
Problem with Sony Grand WEGA KF50WE610 50 in. Rear Projection HDTV-Ready Television. Does this indicate that the lamp is burned out?
if the lamp indicator is blinking and won't turn on which means you will need to replace the lamp.if you don't have an idea how to replace just leave it to the tv technician to fix your tv.
Sep 17, 2012 | Televison & Video
Samsung DLP HL-55086W lamp light flashing slowing just after replacing lamp
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Aug 15, 2017 | Televison & Video
Panasonic TV won't turn on, red led blink
The model indicated was a recalled set--all were supposed to be exchanged under a program Panasonic was forced to use.
The main reason was they were eating lamps up at alarming rates.
I would suggest the lamp (customer replaceable) be removed and inspected---it even if looks good may have to be replaced to see if it is the problem or not.
The lamp issue was caused by a bad Ballast that drives the lamp--kits were eventually made to cure this as the Ballasts were no longer available--rebuilt ones are but not easy to replace.
May 17, 2012 | Panasonic PT-50LC13 50" Rear Projection...
Heard a pop , bulb blew out , replaced bulb , it worked for two days , now red light blinks three times pauses then three times and so on , tv won't turn off light won't turn off unless I unplug...
3 blinks indicates lamp door is not on or has not been reinstalled properly. This also could mean the lamp door switch has failed itself. Try removing the lamp door and putting back on, if that doesnt correct the problem then I recommend having the switch replaced.
Oct 26, 2011 | Sony KDF-E42A10 42 in. LCD Television
My sony trinitron won't come on. I have a blinking light, it blinks 4 times fast. can you help me
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The self-diagnostic function of the TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue.
Few examples are given below; some of the issues may be resolved without the need for service.
1 blink / 2 blinks / 5 blinks: - This indicates that there may be a power-related problem with your set.
3 blinks: - This indicates that there may be a power-related problem with your set. The set will need to be serviced to allow a technician to determine the specific issue that needs to be repaired. If the power light flashes three times in sequence in a Lamp TV, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
4 blinks: - This indicates that there may be a back light or lamp power problem.
6 blinks: - This indicates that there is some kind of audio problem with your set.
7 blinks: - This indicates that there is a temperature problem with your set. Please check to make sure that the air vents on the sides and back of the set are not blocked or clogged and there is adequate ventilation around the television. We recommend that you check and clean the vents periodically to make sure the set receives adequate air flow. If the problem continues, the set will need to be serviced.
8 blinks: - This indicates that there may be a video-related problem with your set. If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Jul 17, 2011 | Sony Televison & Video
I have a sony 65 in. sxrd projection tv that has the red power light blinking and the tv won't come on?
Jul 16, 2011 | Sony Televison & Video
Jdvillanueva
Jun 17, 2011 | Sony Televison & Video
Rear projection tv turns off after 3 seconds, power indicator blinks 3 times at 5 second intervals.
Most times 3 blinks is the defective lamp code. See your owners manual for instructions on changing the lamp.
Feb 24, 2008 | Televison & Video
Toshiba 62HM14
What are the labels on the lights? Timer/Lamp/Service and what color is wich?
Jun 03, 2007 | Toshiba TheaterWide 62HM94 62" Rear...
Sony Kp-Fx432M91 43" Projection Wega Multisystem Tv Logo
131 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
