Acer Mini One's Internal Microphone is Not Working at All!
I just and I mean just bought an acer one. I was very exited. But then I was trying to make a webcam video and guess what NO SOUND! Now I can but don't really want to, buy an external microphone. So if someone could help that would be much apreceatied!
Thanks Much,
LauraLovsYou
  • pandabear101 Mar 03, 2009
    I have the same problem too. I have been to the control panel and I have been under reltek manager, and everything seems to be on. When I plug headphones into the mic jack I could get sound, but I can not get any sound from the built in mic.
I just had the same prob. Thought for a while I ahd a machine fault.
The solution is a bit buried but basically you have to "turn off" the line input feature of the Realtec high definition audio properties.
Get to this through the device manager and sound,videoandgamecontrollers
It will work.
If you cant find change your question and I'll get back to you.
Posted on Feb 12, 2009
    Sergeant:
  • 279 Answers
Check and see in the sound settings if the mic is muted. Windows likes to do that for some reason. It should be fully functional right out of the box (unless it's DOA) but check the mic settings.
Posted on Jan 04, 2009
My acer aspire 4720z mic is not working but the output audio is ok
Try plugging in an external microphone. If it works, then your internal microphone has failed. If the external microphone also doesn't work, then try reloading the Realtek Audio Driver. There is also the possibility if you have previously used an external microphone, that the jack's connections have become unreliable such that the system thinks that an external microphone is still connected after it has been unplugged. With this situation, plugging an external microphone back in will obviously work.
Mar 18, 2011 | Acer Aspire 4720 Notebook
Hi, Internal microphone on my acer aspire 8920g which originally has vista is not working now on windows 7. To be honest I didn't pay attention while I had vista and can't now remember if it worked at...
I suggest you go into control panel and device manager and see if your internal mic is listed there. If it is right click on it and see if it is selected as your default mic. I believe it may be un-selected. If that doesn't work I would just use the external mic with Skype as the internal mics with most laptops aren't that good anyway.
Mar 06, 2011 | Acer Aspire One PC Notebook
Looking for a manual for this comp want to plug a microphone in but one i bought doesn't show up on screenwant to make sure have pluged in to the proper place
Please use this download:
Acer Aspire 3000 3500 5000 service manual
Acer Spire 3000 5000 user guide
There's only one place you connect the microphone, and that would be the "red" jack on the front of the unit. The unit however should have a internal microphone as far as i can recall...
May 28, 2010 | Acer Aspire 3000 Notebook
My internal microphone in my acer laptop doesn't work and it says that the driver is missingwhich driver is for microphone so i can download it from acer
Check the device manager to see any device is missing. If so reinstall the device drivers. You can download the drivers from ACER site.
May 20, 2010 | Computers & Internet
Acer aspire 4720 microphone problem
You can try these steps :
1. Goto Start >> Control Panel >> Sounds >> Recording.
2. Open the 'Microphone Properties' from the list of devices.
3. Change the status of 'Device Usage' to "Use this device (Enable)".
4. Apply settings and close the window.
5. If still the Microphones are not working, try to reinstall the Audio / Sound drivers. Restart your system.
please rate this advice if it helps.....tc! :)
Jan 11, 2010 | Acer Aspire 4720 Notebook
I have an Acer Aspire 5720Z. The microphone will
The fact that your internal mic works and then goes out, is more likelly a drivers problem.
I would run your device manager with all external devices disconnected and look for flags.
If you have a device problem, it will show up here.
Remove and flags and allow your operating system to reload drivers after a reboot.
If this has not fixed your problem, try to boot into safe mode and check your internal sound devices their. Sounds like a driver conflect.
Hope this has helped,
Sep 25, 2009 | Acer Aspire 5720 Notebook
Skype video using Acer Aspire Mini Laptop camera?
If you have a WEB camera you need to configure your video Webcam settings. Open Skype click on Tools - Options - Video Settings - select your Webcam model. When you open Skype click on Tools - Options - Audio Settings and click on Microphone and select the microphone you are using and save the setting.
If you still have problems with your mic. then - To test if the microphone is working, go to Start - Programs - Accessories - Entertainment - Sound Recorder and record you voice. Can you see your voice recording, the green line should vary as you speek.
If you see a flat green line, then the microphone is either faulty or the wrong microphone is selected.
Jun 15, 2009 | Acer Aspire One AOA150-1949 Laptop
Internal Microphone not working
This is not a problem with mic. Settings in System was changed so that mic has been muted. To enable goto contol pannel and Select Sound & Devices and Select Advanced in Device Volume there you will get Master Volume Settings Menu So that uncheck the Mic option and check for Mic Setting in that.
hope this will be helpful.
Thanks & Regards Nanda Kishore.
Apr 10, 2009 | Acer Aspire One Netbook 8.9" Notebook
My microphone on my acer aspire one isnt working
This solution works for the Windows XP version. Go to msconfig.exe, then the Startup tab. UNCHECK rthdcpl and restart. Realtek driver doesn't load, but who cares...the microphone works now.
Aug 09, 2008 | Computers & Internet
Computers & Internet Logo
632 people viewed this question
David Payne
David Payne
