Samsung SGH-A707 Cellular Phone Logo
Posted on Jan 04, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i turn the keypad sound off on the SGH-A707 model?
Anonymous
Level 2:
  • Expert 51 Answers
  • Posted on Jan 04, 2009
Anonymous
Expert
Level 2:
Answers
51
Questions
Helped
154056
Points
136
Take your manual or download it from
SGH-A707 manual
Got to page 75. Here it is explained how to change the sound settings for the different phone modes. Most probably you are only using the normal mode. Following the instructions in the manual, go down to the
"Volume, Phone Sounds" submenu and choose the volume level "0".
Now the keypad should be silent.
Cheers
Critter
What is the unlock code for sgh-a707
You can get the samsung SGH A707 Model Unlock code from here Superunlockcodes.com
and Unlock it from network lock.
1helpful
How do I unfreeze my att samsung eternity without a computer cord
Computer card Unlocking is very Big process,So that You can use the Unlock code....also in computer card Unlocking you need to use Cable,Software,USB port,Boxes etc,so take big time ,it's risk process,cost High also,So that i would suggest the Unlock code the simple method to Unlock Your Samsung SGH-A707 SYNC phone,You need to Unfreeze means specify the Network ,Country it locked now?
You can get the Unfreeze Code at
Simpleunlocking and Unfreeze the Phone from Lock...
Samsung SGH-A707 SYNC Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your Samsung SGH-A707 SYNC mobile phones. If you enter over a certain amount of wrong unlock codes on your Samsung SGH-A707 SYNC mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON your Samsung SGH-A707 SYNC with a NOT ACCEPTED SIM Card.
2 - Compose : #7465625*638*CODE# (or *#7465625*638*CODE#).
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Samsung SGH-A707 SYNC is locked to.
CODE: Its the unique Unlock Code for your Samsung SGH-A707 SYNC.
Each Samsung SGH-A707 SYNC mobile phone has an unique unlock code. You can buy the unique unlock code for your Samsung SGH-A707 SYNC mobile phone using the form above.
Cell phone
thus it have a memory card, try to remove it first and wait for five minutes before you turned it on, dont put back the memory card
update us what happen
When i turn on my phone none of the buttons work.can answer calls
your keypad is bad, you should save your money and get a brand new phone
Cell phone key volume
Go into settings and search somewhere either for Main Menu settings or for Sound Settings. If you cannot find it then, just open every setting and read them. You will find it. Hope I Helped!
SGH-A707
There a many factors that can case this issue:
*Software issue
*Battery issue
*Hardware issue
You can take your phone to a cell phone repair center.
SGH A707 Stuck
if the menu does'nt appear you cannot do the codes... firmware problem... need the the software to reprogramme it... service center has it...... tns
My sgh-a707 wont go past the model number start up screen
hi there you can,t manually reset that now cuz' every time you power it on only logo appears, the problem for that is the program, you should have to go to your nearest sevice center to reprogram your unit. ok!
peace!
Samsung sync at&t sgh-a707 cell phone
I had the same problem and fixed it by turning off the phone, removing and re-inserting the battery.
Phone freeze unlock code
my samsung z500 hang after 1 min it turn on. keypad and other thing does not work.
Nov 07, 2007 • GPS
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mike Cairns
Mike Cairns
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
