Question about Xerox DocuColor 12 Color Copier
Calibrating Doc 12 without a platen
Is there a way to color calibrate a Docucolor 12 that doesn't have a document feeder/platen??
  • info867 Jan 05, 2009
    There is no glass on the top of this DOC 12. You can only print from digital files. You can't make copies from hard copies.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 126 Answers
I am to take it that the Platen cover is missing? If this is the case what you need is Ledger (11x17) or just bigger, bright white paper. Make sure that you use about 6-8 sheets (stacked) on to of each other. Place your color calibration test page on the glass and then lay the sheets over the calibration sheet. This should work as well as the platen white back.
Posted on Jan 04, 2009
  • jpd8 Jan 05, 2009
    There is a platen add-on for this model which allows HARD copies to be scanned.
Hp laserjet 1536 dnf MFP. How can I repair document feeder?
how to fix and repair the adf doc feeder Q5997A hp laserjet ...
? 1:36
https://www.youtube.com/watch?v=lpTj4jiLaY8
Dec 12, 2011 - Uploaded by BrokenPrinter1
Parts Available @ BrokenPrinter.com how to fix and replace the rollers on a hp laserjet 4345 mfp and color ...
Fixing Paper Pick-Up Issues - HP LaserJet Pro M1212nf ...
? 5:40
https://www.youtube.com/watch?v=ZXtAhSDYqyU
Jan 23, 2013 - Uploaded by HP Printer Support
Learn what to do if your HP printer does not pick up or feed paper from the ADF when you do have paper loaded, and a Doc feedermispick error message display... ... FIX YOUR PRINTER: ERROR: Printer Does not Grab Paper fromTray ... Kit m3027 mfp- Kit Hp m3027 mfp - Kit Mantenimiento m3027 mfp ...
'Document feeder mispick' Message Displays on the Control ...
Dec 13, 2015 | HP Office Equipment & Supplies
Half copies
could be black developer unit or pcu / try printing something from doc feeder or platen glass in each single color and see if you have same problem. If other color prints find then will narrow down to items above
Aug 29, 2014 | Ricoh Aficio Type R1 3228c / 3235c / 3245c...
I have a docucolor 12 and x12 fiery. I am trying to calibrate from the fiery. It will printer calibration page, but it can't measure scanner. It comes up with check scanner cable connection. I have tried...
You should have a color separation guide with small gray scale from Kodak. You put the gray scale and the calibration sheet on the glass and follow the instructions from the fiery display.
Jan 02, 2011 | Xerox DocuColor 12 Color Copier
How do I get the platen glass off of my M20i? Either it is stuck or I'm doing something wrong. I need to clean the under side of the glass. Can anybody help?
1. Remove the Document Feeder
2. Remove the Doc Scanner
3. Find the hooks on the Doc Scanner to the right and left to separate the glass frame from the plastic scanner housing.
That should give you access. Best of luck.
Whit
Item, Inc.
Aug 20, 2010 | Xerox M20I Grayscale Copier
HP OfficeJet J5780 Vertical Black Line Prints when copying or scaning only. Cleaned rollers and changed black ink cartrigde. Still problem.
Have you tried cleaning the document feeders Scan Glass? (small glass under doc feeder ~ 1" by 9") Most times there is dirt spot on this glass, causing a shadow on scans and copies.
Try copying from the large glass by lifting doc feeder / platen cover and manually placing original. If no line copying or scanning manually from large glass, then small scan glass is deffenitely the culprit. Hope this helps.
Sep 07, 2009 | HP Officejet 5780 Printer
I need the diferences between docucolor 12 and xerox 7132? please
Pretty vague question.
The Doc 12 probably has a Fiery Network controller, while the 7132 has a Fuji/Xerox controller.
The Doc 12 would have limited scanning capabilities while the 7132 can, depending on the config ordered, scan to E-mail, SMB, FTP, Scan to PC, and scan to a mailbox on the Xerox itself. If you have an embedded fax in the configuration, you can set it to catch incoming faxes and forward to e-mail, or a SMB or FTP folder on your PC or server.
The 7132 is rated at 8 pages a minute in color mode, and 30 pages a minute b&w.
The Doc 12 has been around since 2002, the 7132 is about 3 years old and has been replaced by the 7232.
Jun 23, 2009 | Xerox DocuColor 12 Color Copier
The copier keeps saying to put doc. feeder down and i it is. I ha
power supply has the fuse open that feed the voltage for the ardf
Mar 20, 2009 | Toshiba E-STUDIO 450 Copier
Doc 12 printing lines.
Did you tried changing the print cartridge
Nov 22, 2007 | Xerox DocuColor 12 Printer
Xerox DocuColor 12 Color Copier Logo
244 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
