Question about Acer Aspire AM5641-U5520A PC Desktop
Acer aspire am5641-b5560a Will not boot - Acer Aspire AM5641-U5520A PC Desktop
2 Suggested Answers
  • 4 Answers
SOURCE: how I can get recovery
Recover to original state using Acer eRecovery Managemet tool.
press alt+F10 during boot-up process.
This opens eReovery main page.
unless you have changed it, the password is six zeros (0s).
Click recovery actions.
Select RESTORE FACTORY DEFAULT IMAGE.
Once you've confirmed that you wish to proceed the computer will reboot and start to restore the system from the image contained in the HIDDEN PARTITION on the hard drive.
Posted on Dec 12, 2010
Brand and model of acer aspier am5641-b5560
If I understood you well, the XP OS installed on WD IDE HDD belongs to another computer, in this case you cannot simply install it on your Acer computer and expect it to boot without problems because the hardware is different. What you can do in this case is a fresh Windows installation.
Feb 20, 2012 | Acer AM5641-B5560A Desktop PC & Monitor...
Will not start boot up
There are some reasons for that.
first, go to the BIOS screen and check the boot device priority.then make sure that your hard drive is in the first priority
if it does, and it still not boot up, try to boot in safe mode. in some cases press F8 button when it just turned on and select "start windows in safe mode". if it still doesn't work, maybe you operating system is broken, so you must re-install the operating system (I recommended to use Windows XP or Vista). if it still doesn't work, it must be your harddisks boot sector is broken
Just tell me what screen shown up, like "NTLDR is missing" or somewhat. because itsn't easy to fix problem without knowing the reason.
I'm so sorry about my poor english
Oh, and please vote if it works
Thanks for using Fixya!
Sep 12, 2011 | Acer AM5641-B5560A Desktop PC & Monitor...
No video no bios no beep
Either the power source or the motherboard have died. Take out the power source and test it by measuring its voltages. If it's OK then the motherboard has died.
Jun 17, 2011 | Acer AM5641-B5560A Desktop PC & Monitor...
How I can get recovery my acer am5641-b5560a?
Oct 19, 2010 | Acer AM5641-B5560A Desktop PC & Monitor...
Compture is on but nothing on the monitor. Monito...
Try to check the power supply at the back of your computer that they have works normally if the fan are not punctioning so it means your power supply are damage. But if they works just checked the connection inside or clean the RAM's pin by wiping of pencil eraser or rubber. Or check the processor that they dont have any overheat, just hold the heatsink of the processor and if it is very heat so your processor is damage.
May 20, 2010 | Acer AM5641-B5560A Desktop PC & Monitor...
Acer AM5641-U5520A will not
If you removed the memory modules and there is no change then I would start disconnecting one device at a time to see if that is causing the problem. Start by disconnecting the cd/dvd rom and then try booting the computer. Then try disconnecting any floppy drives or pci cards(except for video card). If it has a pci/agp video card then you will need to remove it and test it in another computer or test a working one in the problem computer. If it has built-in video then you will need to test a working video card in the problem computer. It could also be an issue with the power supply so remove it and test it in another computer or swap it out with a known working power supply. Also check the mother board screws that hold the board to the chassi are tight(the board uses them as a ground). Blow any dust out of the case and verify that there are no loose connectors. Also verify that the monitor is not the problem by testing it with another computer. Usually when a CPU is defective the computer will not respond to anything and will act "dead" so it does not sound like the CPU. If everything else checks out then it could be a bad motherboard.
Dec 28, 2009 | Acer AM5641-B5560A Desktop PC & Monitor...
Upon booting, fans whirl and I can hear HDD
Sounds like your graphic card is not working. Try replacing that. Check and make sure you have the cable plugged into the right port in your graphics card.
Aug 27, 2009 | Acer AM5641-B5560A Desktop PC & Monitor...
Acer AM5641 Desk-top PC
when u power up the computer u heared any beep check then num lock if u abkle to num lock on and off your cpu is ok.then tv to cpu connection we have to check.
also press F8 key when u power the cpu then go to enable vga mode.
then change resolution to 800*600 or 1024 *768
Nov 24, 2008 | Acer AM5641-B5560A Desktop PC & Monitor...
Acer Aspire AM5641-U5520A PC Desktop Logo
80 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
