Question about Locks & Locksmithing
Lockwood Deadlock is loose
Lockwood Deadlock key barrel is loose, how do you remove the back cover to re-tighten
How Do You Tighten The Barrel On A Model 49dl Marlin 22 Lr
A lot of times there is a hidden screw behind the back of the stock where your shoulder rests.. Be sure you don't have what they call a floating barrel. This style can not be tightened per say if what your calling a loose barrel is the rest under that style of barrel.
Apr 23, 2018 | Firearms
Can not remove key with out disconacting battery
There are two solenoid under the gearshifter cover that releases the shifter and locks the shifter and allows the key to be removed when it's in park. They get loose over time and some electronically go bad over time... First must check,to see if they are loose. If they are, tighten them back into place and try to remove the key without disconnecting the battery. It may be all you need to do! Its what happened to mine!!! Lol!!! Good luck!!
Mar 07, 2015 | 2005 Chevrolet Aveo
The round metal piece outside the door where the key is inserted to open the door of my Lockwood deadlock is loose, how to tighten it please
go to the inside of the door and tightened the 2 screws from the back that holds the lock in the door.
Jan 12, 2015 | Cars & Trucks
How do I change the code on a lockwood digital door lock 530
First determine the code you want to use; find the tweezers and spare red and blue tumblers if you are going to change the length of your code. The factory-set code is 5 digits. You can only use each key once and the C key cannot be included in your 4-6 digit long code. Next you need to disassemble the lock with the lock kept horizontal during the recoding process. If the lock has been installed, you need to uninstall it from the door. Remove the two mounting screws from the interior face plate. Then separate the exterior section from the spindle connecting it to the interior face plate. If the lock has not been installed or the previous step is done, remove the adapter plate from the back of the digital lock (exterior plate) if it is fitted on the unit. Next remove the four red screws that hold the back plate onto the lock and remove the backplate. Press and hold the C button at the lower left (as viewed from the back where the tumblers are) below the most of the other keys on the faceplate. With the tweezers, remove tumblers and put a red tumbler in the spots corresponding to your new code. Put a blue tumbler in the all of the other spots. Make sure that the color side is up and that the square cutout is facing the side of the lock. (Thus on the right side keys, the square cut faces right and on the left keys, it faces to the left.) When all of the tumblers are in place, release the C button. Test your code and check that it works after replacing the backplate and adapter plate but before putting the lock on the door. Save the tweezers and additional tumblers for future code changes.
The directions for resetting the code on any Lockwood Digital Lock are provided in the service manual here: http://www.lockweb.com.au/Local/AU/Technical%20Downloads/Lockwood/Mechanical%20Digital%20Locks/530%20Digital%20DX/Lockwood%20DX%20Digital%20Service%20Manual.pdf . Other details for the lock installation are available here: http://www.lockweb.com.au/en/site/lockweb/Lockwood-Products/?productId=948353 .
I hope this helps.
Dec 04, 2014 | Locks & Locksmithing
Honda civic stuck in deadlock can't open any doors as the key won't work in any of the door lock's or boot
Try having a new key cut using the key code, at a dealer, not tracing the old key.
Feb 25, 2013 | 2003 Honda Civic
1990 Jeep Cherokee 4.0l 6cly fuel inj.... recently my steering column has play into up/down and right to left. Steers fine, except it's loose. Key sometimes won't come out and the fuse on the instrument...
Hi, I know the problem well. Had 2 different columns apart recently. What happens is the star bolts holding the lower bearing assembly get loose. You have to take everything off to get to them. First the airbag, if you have one. You have to disarm it first by taking both cables off the battery and touching them together. With the airbag off, take the bolt off the steering wheel and use a puller to get the wheel off. Then the dust cover. With the cover off, you need a lockplate compression tool to push the lockplate down while you remove the locking clip. The lockplate comes off, then the the turn switch canceler, then the turn switch. You have to take the wand and hazard button off to get the switch out. There are then 3 screws holding the upper bearing housing on. First remove the key barrel set screw and remove the barrel. Then remove the 3 screws. Next, you have to pull the ignition switch linkage off the gear opposite the key barrel. The linkage looks like a big key. The housing then comes off and hangs on the turn switch. Make sure you catch the bearings if they are loose. At this point, if you don't have a tilt column, you may be able to see and tighten the star bolts. If you have the tilt column, you will have to take it off. There are pins in each side. An 8/32 screw can be screwed in and pried to pull the pins out. Take the adjusting rod off and the tilt mechanism will come off. The return spring and retainer will also be loose. Now you can tighten the bolts and put everything back together. Now, you're going to want to see some pics to help you. Fortunately, there are a lot of these out there. Here is one, but there are many more: http://www.epiccomputer.com/dale/jeepjunk/tilt/tilt.html . You will want to find one that's like yours--tilt if you have tilt or non-tilt if you don't. Please let me know if you have questions, and thanks for using FixYa.
Apr 19, 2011 | 1990 Jeep Cherokee Limited
I have Lockwood deadlock[20years old] which has come loose. I don't know how to remove rear cap to enable me to get to the screws, the rear cap has 2 holes in it which I assume cover the retaining...
Try turning the inside cylinder with the key. When the "holes" line up with the screws, insert the appropriate screwdriver and tighten them.
Dec 26, 2010 | Locks & Locksmithing
How do you remove throttle/idle control cable from lower switch housing.
2008 fl models dont have throttle cables. If you have a non touring model you have to pull back the rubber boots that cover the adjusters, loosen the jam nut and screw the barrels all the way down till they stop. Take the top cover off the handlebar switch, the cables should be loose enough that the brass cable stops should easily just lift out of the retaining guides, be careful not to drop the brass barrels, they fall off easy and are hard to find when they fall on the floor. Assembly is just the opposite, put the brass barrels back on the cable ends and put them back in the slots, turn the adjusters back out and tighten the jam nuts.
Jul 14, 2009 | 2008 Harley Davidson FLHRC Road King...
My front door has a Roto R627 lock. I can't get
If the deadlock moves a little bit, The deadbolt may not be lining up with the hole. Put some lipstick on the deadbolt tongue and try to turn it. Then check where it is hitting the frame. You might have to just tighten up the hinges to shift the door position.
Jul 03, 2009 | Locks & Locksmithing
LEITZ TRINOVID 10X22C BINOCULARS
Yes , but note that covers are glued so use a pin to  lift cover gently . The screw should be secured --when you are finished tightening-- with 'locktight' or touch of nail varnish.
Oct 28, 2007 | Carson Optical Tracker 8 x 21 mm Ruby Wide...
Locks & Locksmithing Logo
807 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
