Running very rich. how to adjust fuel and air screw
First of all are you running kerosene or diesel ? If you are using diesel, it does not burn as clean as kerosene which causes that burning rich smell. If you are going to use diesel, just use #1 diesel only but still may have a little rich smell. Don't use die red off road diesel. If you are using kerosene and want to check your air pressure on your pump, you will need a 10 lb. test gauge with a 1/8" NPT male pipe thread on the end of the gauge.There are 2 plugs on the back plate. Do not remove the upper plug with the hole in it. This is the adjustment screw for pressure. Clockwise increases pressure, counter clockwise decreases pressure. With the heater unplugged,remove the lower plug. Screw the test gauge in and start the heater. Check the pressure. Most are set between 5 1/2 and 6 lb. of pressure. Check your owners manual to see what your setting should be. If your pressure does not change, you have a worn pump and it would have to be repaired. Once you have the correct setting, unplug the heater, remove the gauge and install the plug back. If you feel that you are not qualified to perform this procedure, send it in to a local repair center.
