Question about Panasonic Viera TC-L42D2 42" 1080p 1920 x 1080 LCD TV - TC-L42D2
Tc-l42d2 blinks 10 times
Front Red LED blinks 10 times
  • 19 Answers
SOURCE: mod # tc-p42c2 blinks 10 times goes off
this is an error code. the DG board is bad. look up shop jimmy on line enter your info and find out how much the board is. it is easy to replace. you can remove the back of the set while it is still on its stand.
Posted on Aug 19, 2011
  • 1779 Answers
SOURCE: why my red led blinks 10 times and then repeats itself. i have a panasonic px60 screen
I know your frustration, all the brands have problems. It sounds like your inverter has gone bad and they do. I've replaced several of them. Try not to compare the new sets with the old. The new sets will not ---will not last nearly as long or as reliable as the old technology. It's sad that you spend at least $1000.00 for a set these days just to have it a throw-away in two years.
Posted on Feb 12, 2008
SOURCE: 4 blinking lights
I fixed it myself!
I bit the bullet and ordered a replacement Power Board for AUS$290 and swapped it out myself.
Only took ten minutes, most of that time was removing and replacing the 101 screws holding the back panel on!
Working fine again now.
I did sit the two boards side by side and noticed the new one had moved some of the micro components from the back of the board to the front plus some other small component changes.
If your handy with a screw driver and have some technical knowhow I recommend having a go at fixing it yourself as it wasn't hard and probably saved $200 in service charges (all this assuming you are out of warranty!)
Posted on Oct 27, 2008
phil_frye
  • 295 Answers
SOURCE: Panasonic plasma 50PZ85 power led blink 10 times
Either a bad power supply or a bad processor board.
A Good Service Shop should know what the 10 blinks are indicating.
May be a repair cost between $200 and 400 dollars.
Be prepared -
Blessings,
A/V Media Guy
Posted on Nov 22, 2009
  • 8457 Answers
SOURCE: When i turn on the TV, there is no picture or sound
The power supply board it dead.Replaced the power supply board will solved this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Posted on Jun 06, 2010
I have a Panasonic Viera TC-L42D2 that exhibits a 10 blink code & displays no image. There are many YouTube videos that show which component & how to fix, but none show my device. Help?
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Dec 14, 2016 | Panasonic Televison & Video
Panasonic Plasma TC-P42C1 10 light blink code, then the light came on and then no light at all-nothing! Power Suppy board?
By blinking led its shows where is exactly the complaint. You have to count the blinking. How much time its blinks in one sequence. the only it will be possible to say is it power supply or any other boards.
www.electro-medical.blogspot.com
Sep 03, 2015 | Panasonic Televison & Video
Why does my Panasonic Viera VT50 have no picture and red led blinks 3 times
First thing, check the HDMI input and make sure it is firmly connected, same for the power cable, obviously. My Samsung goes similarly nuts if it detects no signal from the currently selected input but after 1-2 minutes it eventually stops and I can change the input source.
Aug 13, 2014 | Panasonic Smart VIERA TC-P55VT50 55" Class...
PANASONIC TC-P42C2 RED LIGHT BLINKS 10 TIMES
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given.
Feb 24, 2014 | Panasonic TCP42C2 42 in TV
I have a Panasonic Viera TC-P50x1 HDTV. When I turn the power on the red light blinks 10 times. What is my problem?
Unfortunately the set will need serviced. I would contact Panasonic or whoever you purchased it from for warranty information.
Jan 22, 2013 | Panasonic Tc-P50x1 50inch Class Viera X1...
TC-P50C2 10 BLINKS
Try this for symptoms and cures
Jan 08, 2013 | Panasonic Televison & Video
TV won't turn on
Before going OFF, the standby LED might blink. These blinks are fault indication. The number of blink should be counted. Count the number of blinks at one time, before the TV goes OFF. [eg: 4 blinks Power SOS P Board; 6 blinks Driver SOS 1 SU / SD / SC Boards
(SC energy recovery circuit)] and so on. you can get more details from this site named 'Electro-help'. You can reach it by searching the keyword "electronicshelponline" by internet.
Jul 03, 2012 | Panasonic TC-P50X1 50 in. Plasma HDTV
I have connected Lantronix UDS1100 Device with Siemens AZL Meters. But not able to get complete data on front end.
The UDS has the following LEDs, which help you diagnose problems.
Power LED (green)
Ethernet 10/100 Link (yellow = 10 Mb/green = 100 Mb)
Ethernet Half/Full Duplex Activity (yellow = Half Duplex/green = Full Duplex)
Diagnostic (red)
Status (green)
Simultaneously lit Diagnostic (red) and Status (green) LEDs mean something is
wrong. If the Diagnostic LED is lit or blinking, count the number of times the Status
LED blinks between its pauses. The following table explains the LED functions:
Aug 27, 2009 | Lantronix UDS1100 (UD110000201)
Panasonic Viera TC-L42D2 42" 1080p 1920 x 1080 LCD TV - TC-L42D2 Logo
305 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
