Question about KitchenAid KGRC707 Stainless Steel Gas Kitchen Range
RESALE CAN YOU PLEASE GIVE ME AN IDEA OF THE PRICE I CAN SELL THE KITCHEN AID KGRC707 STAINLESS GAS KITCHEN RANGE WHICH I'VE USED FOR TWO YEARS ONLY?
gwshaw71
  • 83 Answers
SOURCE: wiring diagram
try the whirlpool or kitchen-aid web sites I looked up your model # at 1st source parts and that model is not there
Posted on Dec 07, 2007
  • 41 Answers
SOURCE: oven will not lite or work
most likely the ignitor has gone out. it is a simple fix that you can perform yourself if you wish. the ignitor runs about $70. Joe
Posted on Nov 18, 2008
dmftrucker
  • 1922 Answers
SOURCE: blown fuse inmy kitchen aid range
if you havnt lost your main input 120/240 voltage then check around the control panel,you'll probably find a special control fuse in this area
Posted on Jul 28, 2009
fixyourboard
  • 310 Answers
SOURCE: Kitchen Aid KESC307 Electric Range oven shuts down unexpectedly
We've seen similar problems due to an intermittent failure in the control board. If you can have it removed we can likely repair it for you.
Best Regards,
Bruce
www.fixyourboard.com
Posted on Oct 13, 2009
Testimonial: "Prompt response and likely the solution although I have not experienced the problem again. "
SOURCE: Kitchen Aid gas range error code "F6E4 lost communications"; oven not turning on
i had some milk boil over and got this error message on our oven. we had a tech come out and he said that we would have to replace a control board for $280. he went away to order the part and in the mean time i had to shut off power to some circuits and when i turned the power to the over back on it worked fine. i would try this before replacing the part
Posted on Nov 04, 2010
I recently install a new control panel & display board now f1 e3 displays in clock . Any ideas of reason why ?
The "Cavity Size Select" jumpers in the wiring harness indicate a cavity size different from that which the control was previously configured for. Check the jumpers in the harness to make sure they agree with the actual oven size.
Oct 14, 2010 | KitchenAid KGRC707 Stainless Steel Gas...
Broiler element comes on on Kitchen Aid KDRP407 on all settings
Have you resolved your oven problem ? If so, what was it ?
I have the same exact thing going on....
Brad
Feb 03, 2010 | KitchenAid KDRP407H Dual Fuel (Electric...
Kgrc707 oven not working
it may hav over heated and caused the one time safty on back of oven to trip . replace safty and it should work . ps some times if it has a cooling fan the fan may have quit causing this problem . when the saftey failes look for the cause .. it will do it again . and the safty is about 30 .00 .. mm
Dec 24, 2009 | KitchenAid KGRC707 Stainless Steel Gas...
Good morning. No parts promblem but needs parts
I have one supplier and possibly another. Until you talk with them I am not sure about the price. Click Here=> AmericanHVACparts.com I don't think too many people like to sell the conversion kits because it requires a little knowledge and a lot of know how and caution. Call them if you have a problem there please let me know, Thanks Sea Breeze
Dec 16, 2009 | Jenn-Air JDS9865BDP Stainless Steel Dual...
F-1 code keeps comming up on my Kenmore Gas Range
The information I found today says to replace the keypad or the clock assembly. The ket pad is around $60.00 and the clock I can sell for $245.00. This will give an idea on cost.
May 13, 2009 | Sears 61301 Gas Kitchen Range
GE Electric Profile Convection Range J B910S0K1SS
Dear friend,
ngfam at you service! happy to assist!
Time for factory service and diagnoses!
You can not remedy electronic problems your self!
If the dishwasher is 10 years or older its not worth investing money to fix it! The new ones are mush more efficient and clean better!
Either way this is a service problem to remedy!
Below I gave you a nation wide service thats very good!
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Aug 28, 2008 | GE Profile 30" Self-Cleaning Freestanding...
Oven not working
Check continuity on gas valve. the middle connector is common, upper is broil and bottom is bake. Resistance between common and bake should be about the same as between common and broil. I believe you'll need to set the ohmmeter to KOhms (or x1000.
If no continuity between any of the connectors - replace gas valve (not much fun, and part is expensive).
Jan 21, 2008 | KitchenAid KGRC707 Gas Kitchen Range
KitchenAid KGRC707 Stainless Steel Gas Kitchen Range Logo
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
