Question about Datacard SP35 Printer
Datacard SP35 Printer not ready red light flashing
When i on the printer first its warm up then suddenly its came red light with flashing
SOURCE: Problem with temperature
I can resolve this problem! Using Diagnostics software, I change values and this problem ends..... Thanks for all!
Posted on Jul 31, 2007
  • 9 Answers
SOURCE: Having trouble installing the software for this SP35 Card Printer
Installing printers seems to be a problem after installing Service Pack 3. You might be best doing it from the Control Panel - printers and Faxes - Add Printer. It took me several attempts to get it installed.
Posted on Aug 10, 2009
  • 1015 Answers
SOURCE: Am trying to install Datacard sp35 plus card
Make sure you have the driver available. Then click on the "add a device" under the hardware and sound tab. Windows should start looking for connected devices and find the Datacard. Then when it starts to install it windows will ask for the driver location. Now the problem is windows 7 is so new that there might not be a driver available for it to run the datacard and the windows xp driver might not work. So also check the manufacturer's website for a updated driver.
Posted on Nov 11, 2009
  • 36 Answers
SOURCE: I need Mac driver for Datacard SP35 Plus printer
There is no Driver from Datacard for Mac, windows only, you may possibly be able to use opencard format but SP35 does not support opencard
Posted on Mar 18, 2010
  • 36 Answers
SOURCE: drivers datacard sp35 pour windows 7 ou par defaut windows vista
www.datacard.com Drivers are available, Download link in top left corner, Contact MidWestIDSolutions.com if you need more info
SP35 cards not printing more than one colour
Check to see if you have the current firmware installed on the printer. You can discover the version by going to Start > All Programs > Datacard Card Printers > Datacard Printer. Look at the bottom of the of the dialog box [Printer Toolbox] for the number following Printer Firmware Version. The number should be above version 24.49.
Datacard released a a new ribbon model that includes a new RFID chip. Printers with the older firmware will not recognize the new chip and thus think the ribbon is black only.
  1. Update the firmware by going to the Datacard website and use the search function in the top right corner of the website.
  2. Enter the search string "SP35 Firmware" one of the top links will point you the the Driver and Support page.
  3. Once the page loads, scroll down to the firmware subsection.
  4. Click on the "Begin your Go Green firmware upgrade now" link.
  5. Enter the contact info and click submit.
  6. Click download link once page loads.
  7. Open or Run download.
    1. This program will install software on the computer to update printer to new version of firmware. After the firmware is updated the program will ask if you would like to uninstall at end.
  8. A new dialog window will display Card printer Firmware Update.
  9. Select from drop down the Datacard printer that requires a firmware update.
  10. The dialog box will either display the update firmware version that can be flashed or indicate the "printer contains the latest firmware."
  11. If a update is possible click the Update button in the bottom left corner of the dialog window.
    1. Do Not Disconnect the power during the flash process.
    2. The printer will make beeps while the printer is flashing, this is normal.
  12. Wait till you hear the printer perform it's start-up sequence and you see a dialog on screen for success.
  13. Open Printer toolbox as mentioned above and review the firmware version number in the bottom left corner. Notice it should be a number greater than 24.49.
  14. Click on the Supplies tab in the printer toolbox dialog window and review the ribbon type.
Apr 10, 2014 | Datacard SP35 Printer
The SP35 red light is on
please give me the solution as fast as possible.
( out of print ribbon.(pr-01726) replace the K print ribbon, replace the cleaning sleeve, and click ok when ready
Mar 17, 2010 | Datacard SP35 Printer
Mar 14, 2010 | Datacard SP35 Printer
How do i upload firmware to an SP35 plus printer
This site has "utilities". They run under different levels of Windows, back to w2000. Grab the one that is right for your system and install it. It should guide you through the firmware (available from the same page) installation.
http://www.datacard.com/id-card-printer-support-and-drivers/sp35-plus-card-printer
Feb 01, 2010 | Datacard SP35 Printer
Drivers datacard sp35 pour windows 7 ou par defaut windows vista
Jan 18, 2010 | Datacard SP35 Printer
Setup datacard sp35
Download Newest drivers from Datacard.com
Install drivers and supply in printer before connecting the USB cable
Oct 20, 2009 | Datacard Group SP35 Card Printer
Printer does not initialize,LED flashes red
actually red light indicator is for the alarm of your printer. check your cartdriges intalled it properly and reset the alarm.
Jun 05, 2009 | Datacard SP35 Printer
Apr 09, 2009 | Datacard SP35 Printer
Datacard SP35 - High Temperature
If you want to "control" the temperatur on the printhead , you first of all need to install Diagnostic program for your printer.
On the menu go to values.
Find Ymck power, which probably is on 0. and try to adjust to MAX 50 or -50.
Push the : Save current values to power on , button.
The passaword is 42360..
Dec 03, 2008 | Datacard SP35 Printer
Datacard SP35 Printer Logo
62 people viewed this question
Top Datacard Office Equipment & Supplies Experts
Safe-Card ID...
jason
Don  Farrell
Don Farrell
Are you a Datacard Office Equipment and Supply Expert? Answer questions, earn points and help others
