Question about Sharp AL-800L Copier
AL-800 cannot make copies jam light remains on with no jams
Sharp AL-800 will not allow copies to be made. I have completely checked complete machine for a jam or something on paper wheels that feed machine. It was working properly when machine quit.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 126 Answers
First, is the paper being fed at all? If the paper is being fed and jams at the same location then a senor, actuator or switch is bad, out of place or broken. If the device will not clear the jam light, completely power down the device, unplug from wall, let set about 30 sec. to 1 min. and then replug in and see if it reset. If the device did not reset then again a senor, actuator, or switch is out of position ( being held up in the paper path). If the paper does not feed at all then the feed section is the problem. Clean the feed tire (s) the rubber restorer or a high alcohol base cleaner. Listen to hear if the feed tire (s) are even turning. If feed is not turning then it could be clutch, motor or board problem.
Posted on Jan 04, 2009
Why does my copier "rear jam" and wrinkle the paper after the fuser?
replace the fuser and check for a blockage after the fuser
Jul 11, 2014 | Sharp AL 1631 Copier
I have a Sharp AL-1631 Copier. The 'P' Light comes on indicating a paper jam, however when I open the machine there is no paper jammed. Any suggestions?
Check the dash and see if the lower tray is selected or the by-pass tray on the side. If the side tray is selected change to the bottom tray.
May 13, 2011 | Sharp AL 1631 Copier
A loud clicking sound
This means that a gear is jammed or broken somewhere. Check for waste full and empty or drum waste roller and unblock the jammed toner inside that unit or check fuser gear if broken then replace it.
Nov 23, 2009 | Sharp AL 1631 Copier
Call for service
Cause The fusing JAM is not completely
removed. (Jam paper remains.)
Fusing unit installation failure
Check and remedy:
Check for jam paper in the fusing section.
(paper winding, etc.)
Check fusing unit installation.
Check the jam sensors in the fuser.
Aug 24, 2009 | Sharp AR-M237 Copier
Sharp AL-800 light copies
Check the machine for a **** or dust glass above the drum.
Check and clean coronas, the wires and shells may be dirty reducing charge.
Run a few white copies, to check of the toner / carrier ratio is low.
Hope this is of some help.
Ed
May 11, 2009 | Sharp AL 800 Copier
Paper misfeed indicator light continues to blink even after paper
some machines will want all covers to be opened, then closed, for good reset. if you are having jams in the adf, then open all adf covers, and lift the adf upward, if it allows. also, try turning unit off, then back on. some jams only clear that way.
Apr 02, 2009 | Sharp AL-1641CS Laser Digital Copier
Sharp AL 1551 CS RSPF not feeding
This can be a fault of the controller of the direct current. Apply to service This fault can be not eliminated by you.
Mar 23, 2009 | Sharp AL-1551CS Copier
Paper Jam light on, but no paper jam
A piece of paper torn from copy paper is caught around registration switch, exit switch or feedshift switch.
so check theme.
Jan 18, 2009 | Sharp AL 1631 Copier
False jam indicator
I had almost the same problem but the problem that I had was that after running 5 or more copies it would show a jam with no paper anywhere. And the only way to clear the jam was shutting the machine off and turing it back on.
What I found out was that the gate (flag) on the fuser unit was heating up and the gate (flag) was sticking a bit. (Plastic that close to the fuser isn't the best design)
Anyway, the only way to resolve this problem was replacing the fuser that had a new gate (flag) already installed.
You can replace the flag by itself also.
The way to see if your machine has the same problem, is if you get a jam and you open the right side door, push the black gate and see if it moves a little bit. If it was stuck then your machine is doing the same as mine was.
Good luck.
Hope this helps.
Mac
Feb 29, 2008 | Sharp AL-1641CS Laser Digital Copier
Sharp AL-800 copier
If you check in the unit where the paper first leaves the paper tray, there is a small black lever called a sensor flag that should move freely in and out of a sensor led.Also one or two more inside the machine and where the paper exits the unit.
Aug 06, 2007 | Sharp AL 800 Copier
97 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
