Question about Apple Computers & Internet
Can't connect Thinkpad t43 XP to C1000a wireless
Thinkpad T43 running XP Pro will not connect wirelessly - it sees the router, but will not connect. It connects to several other routers. The C1000a is new, but other devices connect - only the T43 will not connect.
    Habit-Forming:
  • 79 Answers
Try connecting with the IP address of the router on the PC
Posted on Nov 06, 2014
SYSTEM ONE
  • 85 Answers
SOURCE: Wireless network connection on IBM Thinkpad
Ok when looking at your question i became very currious as to the answer myself so i did a litttle research and i think maybe the info on this page here: http://www.eggheadcafe.com/software/aspnet/33307589/certificate-required-to-c.aspx
could be of some use to you . even though the link describes a diferent network adapter the information there is about the same exact error on a router of the same type
I hope this information helps ... if it does not then let me know and i will find some more answers since i used to have the exact same laptop that you have now R40
Posted on Nov 20, 2008
the_fire
  • 432 Answers
SOURCE: Wireless adapter not visible
Is it not physically connected or is there an on off slider switch thats turned off ?
Still does not explain why its not showing up in device manager.
Posted on Apr 15, 2009
bobfreengel
  • 37 Answers
SOURCE: IBM THINKPAD T43. I can find the switch for my ibm thinkpad T43
Are you sure you have a wire card installed? If so, then try this:
  1. Right-click the My Computer icon and select Properties.
  2. Click the Hardware tab and press the Device Manager button. The network card should appear under Network Adapters.
    Note: If the card has a exclamation mark over a yellow background, then this is an indication that the card is experiencing a problem. Go to Driver download step 5.
  1. Verify that the radio is enabled.
    It is possible to disable the transmitter of the wireless card without Device Manager showing any problems.
    Note: Follow the instructions provided to enable wireless card.
    • Most wireless cards will put an icon in the system tray (the line of icons in the lower right corner of your screen). Right click this icon and it may have a menu option to enable/turn on the wireless radio.
    • Some systems come with a Wireless Radio switch to disable the wireless radios. The wireless radio switch is usually located on the front side of the machine. If you are having difficulties with wireless connections, make sure the Wireless Radio switch is set in the On position.
  2. Check for association to an Access Point.
    If you double-click the previously mentioned system tray icon, the configuration utility of the wireless card will appear. This utility will be able to show the status of the wireless card, showing what channel the card is using and what signal strength is being received. It may be difficult to maintain a connection if signal strength is low due to either interference or distance. For example, interference can be caused by 2.4GHz cordless phones, other Access Points in the area, and physical structures such as load bearing walls or metal partitions.
    Note:
    The utility can be used to configure the wireless card settings, but if using Windows XP Zero Configuration or Access Connections, you will need to use those programs to actually configure the wireless card as they will overwrite the setting of the utility.
Posted on Oct 12, 2009
  • 5 Answers
SOURCE: have reformatted the thinkpad t43 with windows xp.
If you have just installed a clean version of XP onto your IBM T43, it will not have the IBM drivers or software needed to enable your wireless, Ethernet etc
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-58597
The Above website is a link to IBM's Driver list. I would recommend downloading, and then extracting, and running the extracted files, (which are usually stored in C:\DRIVERS
WIN... )
Audio v5.12.01.5300
Bluetooth v5.1.0.4700
Modem (If you want it) v7.34.00.00
CMD Ultra DMA IDE Driver (If you have a Dock station) v1.52
ThinkVantage Active Protection System (I would definitly add this) v1.70
TrackPoint only systems v4.69
UltraNav Driver v11.1.21.2
UltraNav Utility v2.11
Broadcom NetXtreme/NetLink Fast/Gigabit Ethernet v10.35.0.0
For your WIFI driver there are three, find out which one yours is then install one of the three drivers, sorry i cant get more specific on that.
Power Manager v1.64
ACPI Power Management v1.55
ThinkVantage Access Connections v5.33
ThinkVantage Fingerprint software v5.8.4.5476
Easyeject utility v2.38
Hotkey utility v2.23.0000
Keyboard Customizer v1.3.53.0
Scroll Lock Indicator v1.07
ATI Radeon/FireGL (Video Card Drivers and Software) v8.593.100.7-090929a
Presentation Director v2.57
Hope this helps
Posted on Dec 09, 2009
SOURCE: IBM thinkpad T43 wireless lan problem
I solve wifi problems on IBM Thinkpad T43 with this driver : http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=18404&lang=eng
Posted on Jul 22, 2010
Wireless and Bluetooth not working running on ubuntu
Instructions
Close any open programs and files. Click "Start," "Run."
Enter "C:\DRIVERS\WIN\WLLANATH\SETUP.EXE" in the "Open:" box.
If your IBM T43 is running Windows Vista or 7, enter "C:\DRIVERS\WIN\WLLANATH\SETUP.EXE" in the "Start Search" box.
http://www.thinkwiki.org/wiki/How_to_setup_Bluetooth
Press the "Enter" key on your computer's keyboard. The Wireless LAN setup wizard will appear.
Follow the onscreen prompts to complete the Wireless LAN installation. You will be prompted when the process is complete.
5
Click "Start," "Turn Off Computer," then "Restart" to restart your computer when the Wireless LAN setup process is complete.
Tips & Warnings
If you haven't already downloaded the Wireless LAN utility to your T43 laptop, click on the "Wireless & Networking Accessories - ThinkPad T43/p" link in the Resources section. Then click on the "ThinkPad 802.11abg wireless Lan Mini PCI Adapter II" link to download the Wireless LAN utility.
Jun 07, 2012 | IBM ThinkPad T43 Notebook
I reloaded xp on IBM t43 but wireless lan is not working. i downloaded driver but still no good
Is the wireless turned on?
Make sure the antenna wires are connected to the WiFi card.
Nov 16, 2009 | IBM ThinkPad T43 Notebook
HP C6180 printer install hangs on my XP Thinkpad T43
If the installation hangs using the setup cd , the best thing that you can do here is to download the printer software from HP site and install it after that and that should correct the problem..
Sep 11, 2009 | HP Photosmart C6180 All-In-One InkJet...
Adding wireless printer to thinkpad T43
If you have a wireless router, the printer will talk to the router and not to the thinkpad. You would have to establish a connection between the printer and the router. Then share the printer to print.
If you dont have a wireles router and you are trying to connect your thinkpad to the printer directly, the wireless card in the thinkpad should be in the adhoc mode. ( See Wireless card properties )
Hope this helps
Thanks
Ranjit www.supportminds.com
PS: Dont forget to rate me if you got your answer.
Aug 13, 2009 | IBM ThinkPad T43 Notebook
Apr 15, 2009 | IBM ThinkPad T43 Notebook
I re-installed XP T43 laptop and my wireless does not work
First thing is to check if the wireless device is working. Go to Control Panel - System - Hardware - Device Manager. Click on Network Adapters. Do you see the the Wireless card?
If not in Control Panel click on Network Connections, do you see a Wireless Connection? If not you need to install the correct wireless network driver, Check the IBM site again, there should be another wireless driver (there are a couple of different wireless card installed on T40 series ThinkPads).
THEN
If you succeed in installing the wireless driver and it is enabled.
Then click Control Panel - click on Network Connections - right click on the Wireless Networl Connection - Click on Properties and check if TCP/IP has been installed, if not install it. Check TCP/IP properties - make sure it is set to Obtain an address automatically and Obtain DNS Server address automatically.
Check the wireless settings on your other laptops, use this information to configure the wireless on the T43, ie the SSID, WEP or WAP settings
You should be able to connect to your wireless router and Internet now - let me know how it goes,
Mar 13, 2009 | Lenovo ThinkPad T43 Notebook PC
Can't set up wireless connection
On IBM laptops, you have to hold "FN" key and push the function key that has the wieless icon on it.
Sep 27, 2008 | IBM ThinkPad T43 Notebook
Wireless / cable connection
By cable connection, do you mean a LAN cable or a phone cable or something else? Let me know and will see what I can do to help.
R-
Nov 07, 2007 | IBM ThinkPad T43 Notebook
Computers & Internet Logo
114 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
