Question about Dewalt DW715 Heavy Duty 12" Single - Bevel Compound Miter Saw
I changed the brushes on my Dewalt dw705 miter saw. Now it won't start
  • 313 Answers
SOURCE: loose bracket miter dewalt dw705 saw
needs model of tool to be able to help you out
Posted on May 27, 2008
Editor925
  • 285 Answers
SOURCE: DW705 Miter saw Spark in motor Compartment
Yes spark in motor compartment is normal. You only need to worry if you see a lot of sparks flying out of the motor compartment! Most power tools will spark inside the motor compartment (particularly if carbon brushes are used).
Bevel and miter could be off... Consult your manual for how to adjust these correctly, but usually the bevel has a 0-degree setting screw or adjustment, and the miter adjustment on the saw is usually done by altering the fence position... Again check your manual for specifics on your saw.
Posted on Mar 19, 2009
rowdy45176
  • 2176 Answers
SOURCE: DEWALT DW705 MITER SAW BRAKE DOES NOT WORK
Could be worn brushes, dirty commutator or a combination of both. Unplug the tool and remove one brush at a time noting the condition and length. Use a flashlight look into brush tube and also not condition of commutator. I would blow is out with compressed air and you can try turning the brushes 180 deg and retry. That is usually the problem
Posted on Jun 27, 2009
rowdy45176
  • 2176 Answers
SOURCE: the saw do not stop when i off the trigger
the commutator might be dirty, try and turning the brushes 180 degrees and you might have to clean the commutator with a stone for that purpose to seat the brushes.
Posted on Jan 14, 2010
miket756
  • 2702 Answers
SOURCE: how to change brushes in dewalt 716 miter saw
look on the motor body there may be two screws over the brushes undo the screws and the brushes are under them if not remove the motor end cap to change the brushes
Posted on Mar 25, 2010
My Dewalt DW705 miter saw just stopped running,instantly. Have power all the way to the brushes,power through the switch when engaged. Still won't run. Any ideas?
The motor may have failed abruptly. There could be an open thermal overload if your saw is equipped with one buried in the motor windings.
Nov 28, 2016 | Saws
Where can I order a replacement trigger switch
How to Install a Switch Kit on a DeWALT DW705 Miter Saw ...
? 12:35
https://www.youtube.com/watch?v=FJ1Wo2xufzI
May 15, 2013 - Uploaded by eReplacementParts.com
Get a replacement switch kit for your DeWALT DW705 miter saw ... kit on a DeWALT DW705 miter saw which replaces thetrigger switch (part ...
Miter Saw Parts ' Tool Parts Direct
www.toolpartsdirect.com/saw/miter-saw.html
Shop the Tool Parts Direct inventory of miter saw replacement parts. A miter saw is designed to quickly make cuts at a variety of angles. Featuring a pivoting ..
Oct 23, 2015 | Saws
Miter saw won't start
It is a burned brush holder...new one cost $15
Nov 11, 2012 | Saws
How do I remove 12" blade from from dw705 miter
loosen the guard screw, UNPLUG tool first, move the guard out of the way, there is a spindle lockon the backside of the gearcase push it and slowly turn the blade until it engages and then remove the bolt, it is a left hand thread. DO NOT disassemble the guard, just loosen bolt and move out away from blade also you need to have the head in the raised position.
Oct 28, 2010 | Dewalt DW715 Heavy Duty 12" Single -...
Need to get owners / instruction manual for my Dewalt DW705 type 3 12" miter saw. Do you know where I can get one quickly?
Hello. DeWalt has 13 types of this saw on file. Here is the link to all:
http://servicenet.dewalt.com/Parts/Search?searchedNumber=DW705&searchType=1
Click on the "more details" arrow of the one that meets your needs, then click the PDF symbol in the top right of the "product information" tab.
If this helps, please rate a four-thumbs up. Thank You.
Sep 12, 2010 | Hitachi C10FCE2 10" Compound Miter Saw
Dewalt dw705 miter trigger won't pull/depress
DeWALT DW705 TYPE 8 12 Inch Miter Saw Parts Sounds like a bad switch, Since you don't have any money it go ahead a replce it. Good Luck
Sep 07, 2017 | Dewalt Saws
Jun 27, 2009 | Dewalt Saws
Mar 19, 2009 | Dewalt Saws
Dewalt DW715 Heavy Duty 12"  Single - Bevel Compound Miter Saw Logo
147 people viewed this question
Top Dewalt Saws Experts
JOHN LAPIER
ken skalski
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
