Question about Moen Plumbing
Leaking blanco masters s baby tap how to remove hose end
Leaking at hose end ? Needs new seal how to remove old seal ? Special tool , if so whats it called
5 Suggested Answers
  • 582 Answers
SOURCE: trying to install new flexhose to water pipe-told
THE FLEX HOSES HAVE SEALS BUILT IN NO EXTRA SEALS ARE NEEDED. ON THE BOTTOM OF YOUR PIPE WHAT TYPE OF THREADS ARE THERE / USUALLY THESE ARE 1/2 INCH MALE PIPE THREAD AND WHERE IT CONECTS TO THE FEED VALVE IS 1/4 INCH OR 3/8 INCH COMPRESSION FITTING, IF YOU ARE USE FLEX HOSES GET THE STAINLESS BRAIDED HOSES THEY HAVE LESS OF A CHANCE OF BLOWING APART AND FLOODING YOUR HOME. HOPE THIS HELPS WITH THE INFO I'VE GOTTEN
Posted on Aug 28, 2009
Dplumber
  • 119 Answers
SOURCE: I have a Blanco BM5300 "Eye" tap and need to
There are several other methods.
Pop out a screw-cover cap on the end of the top of the handle.
Unscrew the base of the handle.
Unscrew the lever off the handle.
Pop out a small setscrew cover plug on the side of the handle under the lever. Hope this helps.
Posted on Sep 11, 2010
Dplumber
  • 119 Answers
SOURCE: i have a single handle blanco classic that is
You need to turn the water off under the sink. Disconnect the sprayer hose from the threaded shank under the center of the faucet body. Pull the spray head out of the faucet. Contact Blanco to receive your faucet parts free.
Posted on Nov 07, 2010
  • 10865 Answers
SOURCE: Blanco Eye Kitchen tap cold water is leaking from
Hello doy.. get a can of WD-40 penetrating lubricant and spray it on the seam connecting the lever and the body. It will penetrate within an hour or so. Repeat if necessary.
Also use a plastic head or a rubber head hammer to tap it up.
Joe
Thanks for choosing Fixya!
Posted on Mar 12, 2011
What are some tips on removing and replacing brake lines etc when replacing the rear end on 97 Dodge 1500
Held on by a bolt and two clips. Bend the clips and remove the bolt. Just be prepared to replace them if they are really rusty. If it were mine, I would pull the axles, Replace the diff and pinion and seal. Replace the axle bearings and seals, if the seals were leaking. If not leaking, just replace the seals.
Mar 06, 2016 | Dodge Cars & Trucks
Rear wheel bearing replacement on a 2001 dodge ram 2wd 1500
Pull the rear axles, remove axle seal. There is a special bearing removal tool that attaches to a slide hammer. Insert tool thru center of bearing and use slide hammer to pull out. Use old bearing against new bearing and tap in with hammer
Mar 08, 2015 | Dodge Cars & Trucks
Leaking blanco single handle faucet with sprayer
minarl deposit bildup in the handol best to just replace the sprayer any hardwer store hose is still good only sprayer head needs replaced comen threds
Mar 11, 2012 | Blanco Plumbing
Front right bearing on my 99 hyundai elantra needs replaced. how hard is it?
IF IT IS DISK BRAKES, NOT HARD! JACK IT UP. REMOVE TIRE. ON BACK OF DISK BRAKE HOUSING IS TWO BOLTS. REMOVE THOSE, AND REMOVE DISK BRAKE SYSTEM FROM HUB. TAKE DUST CAP OFF HUB. REMOVE LARGE NUT. MAY NEED TO REMOVE COTTER KEY FIRST, THEN NUT COVER. FRONT BEARING, AND WASHER WILL COME OUT WHEN YOU WIGGLE DRUM. TAKE DRUM OFF, AND TURN OVER. REMOVE SEAL, AND REAR BEARING. YOU'LL HAVE TO GET A NEW SEAL FOR THAT PART. GREASE NEW BEARINGS, AND REPLACE THEM! THE NEW SEAL CAN BE TAPPED IN WITH A RUBBER HAMMER, OR HAMMER TILL IT IS LEVEL WITH THE RING IT GOES INTO! THEN PUT HUB BACK ON SPINDLE, AND REVERSE DIRECTIONS TILL IT IS COMPLETE!
Feb 20, 2011 | Hyundai Elantra Cars & Trucks
My Blanco Torino faucet is leaking under the button when you press the button on top to use the spray.
Check the hose connections at the spray head nozzle it sounds like it is leaking there and running down the hose and ending up under the sink.
Feb 08, 2011 | Blanco Classic Single Handle Faucet with...
I have a single handle blanco classic that is leaking around the base I have removed the handle and cartridge but cant figure out how to remove the sprayer to replace the seal
Nov 06, 2010 | Blanco Classic Single Handle Faucet with...
Break fluid leaking in buckets from rear disc break on drivers side..is it the break line or caliper. If the caliper how do I replace it?
It could be a brake line near the caliper, or the brake caliper itself:
Inspect/Service/Replace To be able to replace brake pads, service the rotor, or to replace the caliper, the caliper must be removed. The procedure for doing this will vary according to caliper design. Always follow the specific procedures given in a service manual. Use the following as an example of these procedures:
  • Remove the brake fluid from the master cylinder.
  • Raise the vehicle and remove the wheel and tire assembly.
  • Make sure the correct caliper is installed on the correct anchor plate.
  • Lubricate the rubber insulators (if so equipped) with silicone dielectric compound.
  • On a sliding or floating caliper, install a C-clamp with the solid end of the clamp on the caliper housing and the screw end on the metal portion of the outboard brake pad. Tighten the clamp until the piston bottoms in the caliper bore , then remove the clamp. Bottoming the piston allows room for the brake pad to slide over the ridge of rust that accumulates on the edge of the rotor.
f46-12.gif Bottoming the piston in the caliper's bore.
  • On threaded-type rear calipers, the piston must be rotated to depress it. This requires a special tool.
f46-13.gif A special tool is required to move a threaded piston into its bore. Courtesy of Ford Motor Company.
  • Disconnect the brake hose from the caliper and remove the copper gasket or washer and cap the end of the brake hose. If only the brake pads are to be replaced, do not disconnect the brake hose. If copper washers or gaskets are used, be sure to use new ones--the old ones might have taken a set and might not form a tight seal if reused.
  • Remove the two mounting brackets to the steering knuckle bolts. Support the caliper when removing the second bolt to prevent the caliper from falling.
  • On a sliding caliper, remove the top bolts, retainer clip, and antirattle springs.
f46-14.gif Sliding caliper removal.
  • On a floating caliper, remove the two special pins that hold the caliper to the anchor plate.
f46-15.gif Floating caliper removal.
  • On a fixed caliper, remove the bolts holding it to the steering knuckle.
  • On all three types, get the caliper off by prying it straight up and lifting it clear of the rotor.
  • Fill the master cylinder reservoirs and bleed the hydraulic system.
  • Check for fluid leaks under maximum pedal pressure.
  • Lower the vehicle and road test it.
Oct 26, 2010 | 2004 Lexus GX 470
Leak from blanco aderlphi tap above sink line may be a washer required
this could be a leaking cartridge or more likely a likely a leaking o-ring that sits around the base and seals the joint between the spout and the base
Jul 01, 2010 | Blanco Plumbing
Leaking seal on front fork
leaking seals usualy require replacement you will first need to remove the front wheel then the mud gaurd haveing done that losen the pinch bolts on the top & bottom tripple clampsthis will allow you to turn &pull down on the fork legs fascilitating the removal of same once removed useing a suitable receptacle ie a tub you dont mind getting oil in remove the drain plugs from the bottom of the fork legs pushing down on the staunchions will force the oil out once you are satisfied there empty you can comence dismantling remove the top caps turn them upside down this will allow the spring to be removed at this point you will either need to use the special yamaha tool to undo the staunchion from the tube assumeing you dont have said tool you can improvise by useing an extension bar and socket to hold the internal nut use a rattle gun to undo the bolt once you haveseperated the staunchion from the leg you will be able to prise the old seals out if you do not have the correct tools to press the new seals in with the staunchion & leg together you will need to use the old seal to aid you to tap the new one in if you have to use this method I advise you to place the new seal in the freezer for a while before insertion into the leg this will shrink the seal & make it easier to fit place the new seal into the top of the leg then place one of the old seals upside down on top of the new one useing a soft faced hammer tap the new seal into place useing the old seal as a drift before comenceing reasembly take care to lubricate the lip of the seals before inserting the saunchions good luck
Mar 16, 2010 | 2005 Suzuki DR-Z 125
Front seal on rear end is leaking how hard is
Not hard to do. You need to remove the drive shaft, to get to the nut that holds the rear yoke from the differential. Once the rear yoke has been removed, you can replace the O ring seal from the differential by using a screw driver to pry out the old seal. Try not to damage it to much so you can use it to help tap in the new seal. Once the seal is out place the new seal in place by hand and then place the old old seal on it and tap in the new seal with a small hammer. Take care to ensure that the new seal goes in straight and place some grease on the seal before you place the yoke back in to place. Tighten up the yoke nut and you may want to replace the U joint at this time too since it's off the truck. Once everything it back together, check the differential oil level and top off. Good luck and hope this helps, you can get the parts at Auto Zone and they can also give you the step by step instructions to getting the job done with common tools. The hardest part that i can see you having is the removal of the yoke nut, the job takes about an hour to do so if your going to have a garage to the job the most would be 1.5 hours but should take them about 30 min to do.
Aug 31, 2009 | 2000 Dodge Durango
Plumbing Logo
97 people viewed this question
Top Moen Plumbing Experts
john h
Don Numinen
Don Numinen
Mike
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
