Question about Gateway 7330GZ Notebook
Every time I type my cursor goes automatically to somewhere else. How do I turn off the touch pad on my laptop so it is not so sensitive?
  • 827 Answers
Hi, You can adjust the sensitivity of the touchpad by going to Control Panel > Mouse > Device Settings > Settings > Touch Sensitivity.
Hope this helps
Chris (ziraffa)
Posted on Jan 04, 2009
I have a Dell Inspiron 1545 which has three problems, the battery discharges faster than when used by another computer of the same make, the screen lighting often blinks severally before it completely goes...
http://download.cnet.com/ccleaner/
run crude cleaner to get the flicker and speed the laptop up
get a new battery... if discharges too fast.. like less than 45 minutes
cursor jumping around.. watch your touchpad..
commonly you are touching the mouse pad during some keystrokes
you can set the mouse pad sensitivity downward under control panel--> mouse---> synaptics mouse pad sensitivity also
Jan 21, 2011 | Computers & Internet
The cursor jumps from line or field on its own...I could typing away and before I know it, the cursor has moved to another field or to the middle of another word! real pain in the ****
You will probably want to adjust the pressure sensitivity on your laptop's touch pad to alleviate this problem. If you have Windows, enter the control panel from the start menu.
1. START > Control Panel
2. Find Mouse or Pointing Devices.
3. Enter the Pointing Devices Control Panel.
Things can vary a bit in this section. So you should look for anything that deals with Pressure settings or Pointing Settings. One setting should be labeled "Touch Sensitivity." This setting controls how much pressure is required on the touch pad.
-If you move the setting lower (or move the slider to the left) this decreases the sensitivity. It is harder to accidently move the cursor if you brush the touchpad while typing.
-If you move the setting higher (or move the slider to the right) this increases the sensitivity. It is easier to accidently move the cursor if you brush the touchpad while typing.
(Note that in some configurations, these are opposite - left to increase senstivity and right to decrease sensitivity).
Depending on your laptop there may also be a setting labeled Touchpad Pressure. It's a setting that resgisters if you are accidently leaning on the touch pad. It's designed to reduce the chance of accidental clicks or motions. This setting is generally controlled the same way the Touchpad Sensitivity setting is controlled, through left-right sliders. I've found that keeping the touchpad sensitivity low makes it easier to avoid accidental cursor motions. I also keep the Pressure setting relatively high as well. One thing you'll note that if you adjust these settings to far into one extreme or the other, you will have difficulty using your touchpad. Fine tune these two setting until you achieve the results you want.
Dec 05, 2010 | Computers & Internet
The cursor jumps around when I'm typing -- for example when I'm typing, it will just click itself up a few lines and start typing in the middle of another word
The touch pad can cause this problem. Go to control panel to make it less sensitive. I often drag a finger by accident over the pad and away goes the cursor. It is a major grump of mine also.
This web site shows the details, if you need them, to adjust the touch pad. http://www.ehow.com/how_2292964_adjust-vista-laptop-touchpad-settings.html
I do this for fun, so 4 thumbs if it answers your question.
Sep 25, 2010 | Dell Inspiron 1525 Notebook
When typing an email the keys skip back to the
When I have seen this happen, the touch pad was set overly sensitive. When you are typing, your palm may be moving the cursor. If this happens at other times, then this can be corrected in the control panel. Go there and click on touch pad. It will have settings to set the sensitivity for the mouse pad, speed, double click/single, etc. You can change the settings to be more suited to your hands.
FYI: Older laptops were more susceptible to touchpad errors and I have even seen the area on either side of the touchpad to cause the mouse cursor to move and jump.
Good Luck
Dec 16, 2009 | Toshiba Computers & Internet
When I am typing he cursor jumps around
It is a fault with Lenovo laptops. My cursor jumps all the time, no matter what software I am using. It is NOT the 'sensitivity' of the touchpad, for my cursor jumps even when I am not typing, even if I don't touch the laptop! I can set the cursor to a certain point on a document and then, after about 30 seconds, it will just jump to another point, even if I am in another room.
Sep 24, 2009 | Lenovo 3000 Y410 Laptop
Cursor jumping around when typing on a Dell 1530
It is most likely the touch pad...a way you can tell is if you have a USB mouse, turn off the touch pad and use the USB mouse...go to type and see if it still jumps around.
Sep 16, 2009 | Dell XPS M1530 Laptop
Cursor Shift
This could be either a driver glitch or the touch pad is going out, both are common on these models. Start by uninstalling the drivers for the touch pad (some times referred to as the synaptic pointing device), then restart the machine. The machine will find the touch pad and reinstall the drivers automatically. If it's a simple glitch, this will fix it. If it persists, then the pad is failing and will need replaced. The only other thing you might try is to adjust the cursor speed or touch pad sensitivity from the control panel. This will sometimes help to dampen the effect, but usually won't get rid of it entirely.
Sep 04, 2008 | Dell Latitude C610 Notebook
Moving cursor.
well there is a few things that could possibly be happening. if it is a touch pad or a wireless mouse something like a cell phone sitting close enough to them could be causing some interference. the second one is that you could possibly have the mouse keys turned on where you can control the mouse with the keyboard.
Apr 29, 2008 | Dell Latitude D800 Notebook
Cursor skips lines while typing
My experience: cursor suddenly moving backward when i was typing, or moving somewhere else on the page. I would be typing and text suddenly would get highlighted. I followed someone's advice to disable the touch pad. Since I do have a mouse & key pad that was all i had to do.
HOW TO DISABLE THE TOUCHPAD FOR ACER 3680 AND OTHERS??? PRESS Fn +F7
Yep, it was that simple. At first I made sure i typed without my fingers or palms touching or near the touchpad. I noticed it seemed to stop or happen less. Soon as I disabled the touch pad all is back to normal. Yet I spent hrs trying to find out how and there were all these posts by people suggesting downloads and other more complicated things etc..
May 12, 2007 | Acer NSK8458AN Keyboard
Gateway 7330GZ Notebook Logo
71 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
