Question about SanDisk Sansa e260 MP3 Player
Won't turn on at all
I came home to put some songs on it and i plugged it in as usual, nothing different. a window popped up telling me a new hardware was found and to install the cd and when i tried it said it couldn't. after that i unplugged the e260 since there was no option to disconnect it and it froze, so i tried to take out the battery since i didn't have much of an option. after that, it wouldn't turn on unless i had it plugged in to charge and that's really all it would do. help please!
  • 8,596 Answers
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Posted on May 24, 2008
SOURCE:
I try to download songs, but AutoPlay keeps popping up.
Test another USB port on your computer, and see if you get the same result. If you get the same result, the USB cable may be faulty.
Here is a test you can do to see if the problem really is the USB cable, or if it is something else:
Triple Reset for Philips’ GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
Feb 02, 2009 | Philips SA3025/37 Flash MP3 Player
My computer isn't detecting my Sansa mp3 player anymore.
First, make sure the lock switch isn't engaged.
Try this: disconnect the player from the computer, turn it off, hold in the volume + (or Record) button, and reconnect the player to the computer while holding the volume + (or Record) button in. Keep holding the volume + (or Record) button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start --> Control Panel-->System--> Hardware--> Device Manager (you computer may vary slightly, depending on Windows Version).
-Tha Mp3 Doctor
Oct 28, 2008 | SanDisk Sansa c200 MP3 Player
My sandisk c240 charges when plugged in but fails to be recognized on the computer
There is quite possibly a problem with the USB cable or the USB port on the computer, but try this shortcut force to force the computer to recognize the Mp3 player: Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard
Jun 23, 2008 | SanDisk Sansa c240 MP3 Player
Sansa e280 freezes and can't get songs on
May 19, 2008 | SanDisk Sansa E280 MP3 Player
ILO not reconized
This is the worst mp3 player ever invented - i have to tell you this up front. There is no driver, the company does not support the product anymore - I would return it now while you still can.
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Apr 04, 2008 | iLO (2 GB) MP3 Player
CONFUSED!
Make sure the songs are in the correct format. Make sure the songs are not AAC, WAV, streaming, or some other non-supported format
Mp3 players are more complicated than ever. This player may only accept DRM-encrypted WMA files. I would first check the songs that you have downloaded to make sure they did not have "temporary" licenses with a fixed end date. You can do this by right clicking on an individual song, clicking on properties, and selecting the "license," "digital rights mgmt" or "media usage rights" tab - the wording varies by configuration. It will give you info on the license. If the song says that it has no license, it will not work with this player. One remedy is to use mp3 converter software to convert all of those wma files to Mp3's - I don't know of any free ones, but you can certainly look for free Mp3 Converters. Another remedy on unlicensed songs is to hit the "acquire license" link in the license tab, if one exists.
-Tha Mp3 Doctor
Oct 13, 2007 | RCA TH1101 MP3 Player
Ilo mp3 player gets stuck on first song...
Aug 07, 2007 | iLO (2 GB) MP3 Player
Ringing sound when playing music
Jun 22, 2007 | SanDisk Sansa e260 MP3 Player
Siren ilo 2 gig frezzing and other problems plz help?
Mar 22, 2007 | iLO (2 GB) MP3 Player
SanDisk Sansa e260 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Gyula Lacz
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
