Question about Amana NAV2330AW Top Load Washer
How many cubics is amana nav2330aww - Amana NAV2330AW Top Load Washer
3 Suggested Answers
SOURCE: How do you change the
you will need to unhook the belt from the transmission pulley and then take out the 3 screws running up from the bottom of the pump that runs into the motor support and drop off the pump ,,, the easies is to remove the 4 screws holding the motor support in place and set the motor and pump out to remove the pump and swap the belt
Move the washer out from the wall so you can remove the back. You may need another person to help move it because it is full of clothes and water. It would be easier to take the wet clothes out and put them in a pail or nearby laundry sink and then try to bail or pump the water out. It will be a messy operation, but easier in the long run.
Remove the back of the washer. Use screw drivers, nut drivers or hex head wrenches to remove the screws or fasteners on the back casing of the washer. Don't forget to unplug the washer from the electrical socket first. If it is a gas dryer, remove the hose from the gas line and temporarily cap off the line at the wall. Be very careful with gas lines and be sure they are capped off securely.
Find the belt. Belts are usually easy to find. They look much like fan belts in cars or belts in vacuum cleaners. A damaged one will be easy to spot. It will be broken altogether or so loose from wear that it does not grab the pulley and turn the washer drum.
Loosen the bolt on the motor bracket. Use a crescent wrench for this job. In a pinch a pair of pliers may do. Move the motor to put slack in the belt. Even if the belt is broken, you will still need to move the motor to install the new belt.
Remove the old belt. Stretch a new one into place on the pulleys.
Put tension on the new belt by using a hammer handle or a short pry bar to push the motor into position while you tighten the bolt in the adjustable bracket. Leave about 1/2-inch of slack when you press it in the center. If it is too loose, it will slip on the pulleys. If it is too tight, it wears quickly and may start to smoke or burn.
While you are in there tighten the pulleys by checking and tightening set screws all around the pulley hub. You may forestall another problem in the future by taking care of pulleys now while it is convenient.
http://www.servicematters.com/maytag_library/docs/16022937.pdf
Above is your service and repair manual.
Posted on Jun 21, 2010
  • 6277 Answers
SOURCE: My Amana Super Capacity Plus
The first thing to do is to have the leak investigated by somebody there as we could only offer a list of guesses ;-0)
Once it is empty and carefully lifted onto its side, it should be possible to inspect the hoses and clips and hopefully identify the culprit. In some cases it might even be possible to affect at least a temporary fix whilst obtaining the necessary spare.
Sorry we could be only of limited help in this instance- it's very difficult diagnosing this sort of problem remotely ;-0(
Good luck,
John C
Posted on Apr 06, 2011
How many cubic feet is this model of Amana Range?
actual oven space? Never had anyone ask that before. Even manufacturers don't list that info. Why not just measure depth x width x height (of oven cavity) in inches and multiply to get an estimated total of square inches. Then divide by 144 (the number of cubic inches in a cubic foot).
Aug 21, 2014 | Amana ARGS7650SS Gas Kitchen Range
Do you know the capacity (cf) of the amana br22tw,please?
The capacity is given in cubic feet, yours is 22 cubic feet. Note the 22 in the model number that denotes this BR22TW.
Sep 16, 2011 | Amana BC21V1W Bottom Freezer Refrigerator
What are the cu in capacity of each of the freezer & refrig. for an Amana SCD25TW?
Hello, the cubic feet capicaty is 25 cubit feet. 1 cubic foot is 1728 cubic inches so 1728 times 25 is 43,200 cubic inches
Aug 17, 2011 | Refrigerators
My Amana Super Capacity Plus washer, model NAV2330AWW is leaking. Any ideas about the problem and/or cost to fix?
Good luck,
John C
Apr 06, 2011 | Amana ALW480DA Top Load Washer
How do I determine the cubic size of my refrigerator? I have an Amana, model number 85271
Here is a tip that tells you how to figure out the size of your refrigerator...about the third paragraph down...
New Refrigerator Size or Refrigerator Cubic Feet
http://www.fixya.com/support/r4326731-new_refrigerator_size_or_refrigerator
heatman101
Aug 11, 2010 | Amana Refrigerators
I'm trying to find out what the interior cubic footage of my Amana TX21A3W is? How many feet of that are refrigerator and how many feet are freezer?
This is a tip that I wrote and a couple of paragraphs down it tells you how to figure the cubic feet of your unit...
heatman101
Aug 07, 2010 | Amana Refrigerators
NAV2330AWW top loading washing machine will not agitate or spin. what to do?
Check the belt, it is most likely loose or broken.You can access it by removing the lower front panel.
Nov 07, 2009 | Amana ALW480DA Top Load Washer
Very noisy and leaking
Water pump may be leaking. Check idle pulley and big counterweight spring that stedies the drum. Go to www.appliancepartspros.com for a diagram. Have model number ready.
Jun 23, 2009 | Amana NAV2330AW Top Load Washer
Cubic feet?
Most refrigerator models with two digits, the rest letters, the digits stand for the cubic foot capacity of the refrigerator. In you case, 23 cubic foot model.
Sep 16, 2008 | Amana Refrigerators
Amana NAV2330AW Top Load Washer Logo
55 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
