Non functioning cd player in my Fisher PHD 650 audio system
How many screws need to be removed to disassemble the CD Player from the Fisher PHD 650?
  • 130 Answers
SOURCE: CD player
All this cd systems have the same problem. If you're using burned cd's sometimes they don't work so you need to close the session after burning in your burning program. If you're using original cd's it means that the device needs to be cleaned up (especially the lens) because the structure of a 5 cd combo device gets very dusty after a while. Also from my experience after cleaning it put a cd in each deck (even if it's off) so they could prevent it getting dustier again. Hope it helps, good luck!!
Posted on Feb 12, 2006
hardrocko
  • 1476 Answers
SOURCE: AUDIO
First make sure that the speaker wires haven't fallen out of the wonderful spring clip connections the factorys use. If they are hooked up properly and you have a headphone jack plug in a set of headphones and check for sound. If you have sound the problem is in the power amp. If not it could be in the preamp or power amp. At this point if sound is absent and you can solder, open the unit and check the solder joints for bad connections and resolder anythhing which looks questionable. These days the majority of problems are related to cold solder joints. If the unit still is not working you will need an O Scope to trace the signal. If this is beyond your capabilities any repair shop should be able to find the problem.
Posted on Jun 23, 2006
SOURCE: CD player stops, won't open
there is a spring loaded mechanical switch under the cd rack that often breaks
I am trying to fix one right now and i am going to rig a three phase switch on the out side of the case
Posted on May 16, 2008
SOURCE: How do you remove Audio-CD player from a 2002 Kia Sportage
after you remove all the screws from the dash you have to get down to a section by the pedals and remove something like the airbag to get at the last part of the dash apart. then you need to unplug the mirror and back wiper switches (opt i think). then you have access to your radio. These are all things i gathered from watching the guy at futureshop do, it was about $100 and now I don't have fm radio. but I am now going to try it on my own.
Posted on Oct 23, 2008
  • 8 Answers
SOURCE: CD Player does not recognize CD
If using computer generated dics , disc usally bad burn progam , bad disk, burn speed to fast. Check out NERO burn. OR dirty eye, clean, laser eye with disc clean disc
Posted on Dec 11, 2008
Tad-da350 unit sayes no disc in cd player when there is a cd in player?
salut, j'ai un fisher tad da 350 j'ai egare le circuit integre de puissance. Est-ce -que vous pouvez m'aider a trouver son numero ?
Sep 29, 2011 | Fisher DCS-DA350 Shelf System
Fisher studio 60 cd player,constant M-error..Disks are all in the slots..
The CD feed gear is mis-aligned or broke. It need to be disassembled and repaired. Underneath the drive is a gear that drives the CD into place before it plays - it's stuck or broken. This is a common problem.
Feb 23, 2011 | Fisher Audio Players & Recorders
Stuck CD in the multi CD player of 2004 Chevy Malibu Maxx
The only thing that is left for you to do is to remove the stereo and then disassemble it and remove it yourself. A little daunting but needs to be done. Sounds like it went in wrong and then became jammed
Jun 10, 2009 | 2004 Chevrolet Malibu
Disc will not eject nor play on fisher studio 24 management system. It holds 24 cds. My husband is furious, says I loaded cds backwards. PLEASE give any possible solutions. Thanks. Tina Georgia
remove the screws to your cd player and take this apart and remove the disk by hand and put system back together. It should work after that. I am a former tv technician. just be careful how you take it apart to put it back together again. do not plug unit in untill it's all done to avoid eye damage from the UV rays.
Feb 24, 2009 | Fisher Audio Players & Recorders
Jammed CD
Remove the top cover of the head unit with a screw driver. You may also need to remove the face and the front part of the unit. Once the top is exposed showing the cd inside the mechanical parts of the cd player, try to look for a mechanical lever that holds the cd in place. Usually in the middle(ID) of the cd. You'll most like would have to lift the middle part, then slide the the cd out. Check and observe the function of the mechanical parts. And last, try not to exert to much pressure or strain on the parts, because it may not function the same way once its reassembled. It's easy.
Nov 15, 2008 | Pioneer DEH-1600 CD Player
Sep 12, 2008 | 2002 Kia Sportage
Sony Xplod CDX-S2210S
It is more then likely your faceplate has become non functional, and if so the cd player is almost none functional. If you can remove the faceplate try cleaning the connections that clip into the cd player. But by the sounds of it, your face plate is die'ing out on you. Sorry
Good luck,
IF you need any more help just ask.
Thankyou
Aug 10, 2008 | Sony CDX-M610 CD Player
Cd player
i need part # 6142539071 for fisher tad 993
Jul 09, 2008 | Audio Players & Recorders
CD player won't eject CD and does not recognize the CD
You will have to remove the player from your Sierra and disassemble it sufficiently to remove the stuck CD.
May 30, 2017 | Car Audio & Video
Cd player
M-Error is a mechanical error and could have a multitude of causes. just went through it with a TAD-5160 unit where it was a small slip gear moving a tin lever to ingage the transport sled to insert or eject the disk from and to the carusel. You may have to take the unit apart and asess the problem. Harleysp.
Mar 19, 2007 | Fisher 9925 Shelf System
32 people viewed this question
 Grubhead
Grubhead
