Question about GE DBXR463EBWW Electric Dryer
Dryer belt snaped
Replacing dryer belt, put new dryer belt on second part of drum, seemed a little loose. Put back together turned on and drum still will not turn, makes humming noise. Need belt routing picture
  • Anonymous Mar 15, 2014
    put belt back on drum dryer lea30aw
  • 163 Answers
Hi!!! Make sure you install the belt correctly maybe this can help you..dryer belt snaped - 2447c24.gif
Posted on Jan 04, 2009
My creda simplicity t622cw condenser dryer wont turn
Broken or belt has come off. If can open back and fix or replace. You may need to remove the top. Careful of the heat element, lift out drum and place new belt on motor holding it while you put the drum back keep hold of belt and place around drum replace top and should be ok. Hope this Helps
May 25, 2010 | Dryers
Dryer heats up but the inside doesn't turn.
a dryer will not turn if the belt has fallen off the motor or if it has been broken    replace the belt
Nov 05, 2009 | World Imports Belle Foret N30002TB...
Works but doesnt spin. Where is the belt located. I think that might be the problem.
To access your drive belt, you need to take the front cover off. Unplug the dryer first.
There should be 2 screws on the front cover in the lower front area. Remove the screws and tip the bottom of the front panel forward until the top clips are frree of the top panel. Be careful there is a door safety switch wired. You can disconnect the wire and set the front panel aside.
Look under the drum in the dryer and you'll be able to tell if the belt is broken or loose.
IF you need to replace it, you'll need to take the 4 screws that hold the front drum support/duct assembly loose from the dryer case. Once these are removed you can pull out the whole gray assembly and slide the drum out.
The new belt can be purchased online at repairclinic.com if you want.
To put back in, you can put the belt around the drum and slide it back in. It should have a grooved side and a flat side on the belt. Put the flat side toward the drum. It routes around the motor pulley and a tensioner pulley. It may take a bit to figure out the routing, but the key is to put the belt into the indentation ring on the drum to allow you to get it around the pulley and tensioner... if you leave the drum sticking out of the machine about 8 inches, you can reach thru the drum and hook the belt in place, then slide the drum in and pull the belt out of the indentation and onto the larger circumference of the drum. You may have to twist the belt to get the flat side next to the drum.
You can then put it all back together...
Good luck... be patient and you can do it.
Sep 10, 2009 | Maytag HYG3460AWW Gas Dryer
Need help with installing belt in Maytag Electric dryer
if not able to remove rear panel,you will need to start,like most models,take top cover off and hinge back to wall then remove frt cover including door as a whole assy. lift up drum put new belt on drum ( and position in same area as old belt,it will have marks on drum from where original belt was on drum) then put rest of belt over mtr pulley and then idler pulley, turn drum by hand to align belts and put it back together in reverse order
Jul 28, 2009 | Maytag PYE2300AY Electric Dryer
New belt but drum still won't turn
make sure that he put the tensioner on the right way with the spring it will make the belt really tight !This is sometimes hard to do because the spring will bite you if your not careful !!
Feb 15, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Need to know the exact way to put belt on ge dryer model number DDE7200RALWH cant figure it out around the pulleys , ge assures its the right size belt for the dryer , but belt seems loose and drum wont...
with belt around drum, pull idler back with tension on it and put belt over pulley of motor and let idler up against belt and it should be right ,,,, larryyb
Dec 10, 2008 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
Dryer motor
if the motor buzzes when you push start then it is a bad motor.as long as the drum turns freely by hand.
Oct 29, 2008 | Whirlpool LER4634J Electric Dryer
Dryer belt replacement
Take the top panel off by slideing a putty knife about 2 inches in at the front and releasing the tabs. remove screws from top of front panel after top removed. also remove 2 screws from inside of front panel on both sides about 4 inches down screwing back into front panel. pull front off and slip belt through opening. Feed belt around drum and put tension on the idler spring release onto belt. reassemble unit.
Aug 09, 2008 | Frigidaire AEQ7000ES Dryer
Asko T700 loose belt, access from front?
I think you must replace the belt and the tensionarm. It MUST be done from the backside of the machine... Remove the backpanel, and the drum, change the tensionarm, and put the drum into the machine again. Put on the new belt, and mount it together again. Be careful for sharp edges! Hope this helps :-)
Jan 12, 2008 | Asko T700 Electric Commercial Dryer
Drum won't turn
not really, it may only be a little effort to figure out how the new belt gets wrapped onto the tensioner pulley...the broken one is surely on the floor coiled up under the dryer like a dead snake....don't worry...it's dead.
Oct 31, 2007 | Whirlpool LER5636P Electric Dryer
GE DBXR463EBWW Electric Dryer Logo
331 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
