Question about Mitsubishi WS-55511 55" Rear Projection Television
We moved our WS55859 yesterday. Was working fine. Got to new house, plugged in and the timer button keeps blinking and tv won't turn on. Need help. Any suggestions?
  • 6 more comments
  • Anonymous Jan 11, 2009
    my power went out and now the timer light is flashing and thats all the tv will do.its a ws55859 mitsubishi.if changing the fuse is the solution,were is it located.thanks for any help.
  • mweaver004 Jan 11, 2009
    green light is flashing and tv does nothing
  • markc1542 Jan 18, 2009
    anyone have a certain button configuration for the Mitsubishi rear proj 55 inch ws-55511 when the green light just blinks. From time of the plug in it just blinks. Tried the reset button, nothing different. Is there certain buttons to push at the same time to reset it?
  • Anonymous Jan 19, 2009
    Green light flashing vary fast and tv will not turn on.
  • lisanng Jan 23, 2009
    I have the same thing happen to me this afternoon. Our power went out, went back on, and now my TV (which I can't live without) Won't turn on! The green timer button just keeps flashing.. I have unplugged, reset, cleaned out the dust... And still not working... HELP!!!
  • wilberbeast Jan 28, 2009
    power went off then back on and now green timer light keeps blinking have tried to reset several times even unpluged for few days pluged back in and the green light just keeps blinking please help is there a solution?
  • cb_bball123 Feb 11, 2009
    i left the house for a couple of hours when i came back the tv was off and the green timer is blinking
  • jozipp Feb 13, 2009
    The green power light started blinking and was able to reset for awhile by pressing recessed reset but not anymore.
Try tho change fuse
Posted on Jan 04, 2009
My roper dryer worked fine yesterday. It won't work today
remove back cover then locate the blower housing in the back,its round on this is a thermal fuse appx. 1" X 1/4" with 2 wires from it,this is the thermal fuse test it,if its open on continuity its bad and the dryer wont operate the pat number is FSR# 3392519
May 21, 2012 | Roper REX3614KW Electric Dryer
My mitsubishi tv W55613 won't turn on. green light keeps blinking even after resetting
Hit the front of the tv near the blinking light... give it a good rap or two. See if this helps. Helped mine. I had the same problem and the tech who came out to the house told me that it would work and it did! I could hardly believe it but it worked.
Feb 13, 2012 | Mitsubishi WS-55613 55" Rear Projection...
Timer light continous blinking,tv won't turn on!!!
Thats a common problem thats almost always caused by failed capacitors on the DM powerr board. You can get the WS55859 DM repair kit from www.tvrepairworld.com the kit contains the upgraded capacitors and the CD with repair instructions.
May 30, 2011 | Mitsubishi WS-55859 55" Rear Projection...
Blinking green light on my mitsubishi tv....model ws-65869
Replace the Capacitors on the DM board. You can get the WS55859 DM repair kit which covers your model from www.tvrepairworld.com which has the caps and the CD with repair instructions
Jul 14, 2010 | Mitsubishi WS-65869 65" Rear Projection...
We just moved the tv into our new home, when we plugged it in and turned it on nothing happens.. no picture or sound, the timer/standby red light blinks 11 times then nothing. We have tried powering it on...
Well I think what has happened is that the move has caused a failure, it well may have been bumped or jostled, these units are VERY delicate, and should NEVER be moved without using the protective crating, they came that no-one keeps, for any transport, (It is absolutely imperative that you keep your packaging these days as it should NEVER ever be moved without putting it back into that packaging for travel) they really do NOT travel well at all. This what you describe is a classic situation, we see it all the time in my shop. You have little option but to get a "Quote" for a repair. this is indeed unfortunate, but all too common from "shifted" item. Especially TV's.
Mar 22, 2010 | Televison & Video
Mitsubishi WS55859 turns on for 3 sec. then turns off
Ic's went out again. Did you check all the bias resistors? Must always look the board over for cold solder joints also.
Oct 22, 2009 | Televison & Video
Tv won't turn on
i can' turn on my sony tv . no lights are blinking. nothing. could something when it was moved.
Dec 30, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Won't keep digital signal
If you're connected to a digital cable box, I would try using the external component connections and bypass the TV's tuner. If all you have is straight cable coming into the house, it could be the cable signal itself or a defective tuner in the TV assuming all the menu settings are correct in the TV.
Jul 25, 2008 | Toshiba MW20H63 TV
Tv wont turn on
This problem very well could be a DM board problem. I have a how to fix file if this is indeed your sets problem. Leave your email and I will send it to you. Good Luck
Jun 15, 2007 | Mitsubishi WS-55859 55" Rear Projection...
Mitsubishi WS-55511 55" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
