Televison & Video Logo
Anonymous Posted on Nov 03, 2012
Yellow red line in fujica 35 viewfiner
Theres a yellow red line in the viewfinder of my fujica 35 automagic camera. Also, only two of the aperture thingys close in. Maybe thats why ?
Anonymous
Level 3:
Top Expert:
  • Master 14,553 Answers
  • Posted on Nov 03, 2012
Anonymous
Master
Level 3:
Top Expert:
Answers
14553
Questions
Helped
2716352
Points
48227
I think you might want to list a new question in the camera section as the site is having some issues where questions get posted in wrong areas.
I advise a high school yearbook and we shoot a d100. Today it's too dark to see through the viewfinder (yes the lens cap is removed), and i ger the r06 error. I've reset the camera, removed and...
First, the "r06" message is NOT an error code. It indicates the number of shots remaining in the internal memory buffer, before the camera must prevent additional shutter actuations so that it may transfer those images already in the buffer to the memory card. This "r" number will decrease with each shot taken in rapid succession until it reaches 0. The shutter release will no longer work until the buffer is transferred to the memory card, then shooting may continue again.
As far as not being able to even see through the viewfinder, it sounds like something may be obstructing the light from reaching the meter and viewfinder. The problem is most likely the position of mirror inside the camera body. With the lens off the body, the mirror should be plainly visible at about a 45 degree angle to the opening. A side view drawing of this is below. The solid red line is the mirror in the normal position. The red dashed line is the up position of the mirror when the shutter is released.
When the mirror is in the "normal" position, the light from the lens is projected on a screen so that the image is visible in the viewfinder for composing and can be metered. When in the "up" position (when the shutter release is fully depressed), the light from the lens is projected on the camera's sensor for as long as set by the manual settings or program; based on ISO, aperture, etc. At the end of this time, the mirror returns to the "normal" position.
If your D100's mirror is not in the lowered 45 degree angle position, the image seen in the viewfinder is inside the camera - not that which the lens would project. Hence, the dark viewfinder, long exposure times and - I'm guessing - severely overexposed pictures because way too much light is striking the sensor because the meter is only seeing darkness.
If the mirror is ok, with the lens removed from the body, look for the aperture lever as shown in the yellow circle in the picture below:
By default, the aperture is at minimum. The camera moves the lever from this position to full open (and anywhere between) as needed. You should gently move the lever to the other end of its travel to open the aperture to maximum. Point the lens away from a light source but preferably at a light colored background. Look through the lens. There should be no obstructions and be clear. Next, look at a dark colored background to find the same results. If you want, you can even allow sunlight to shine through the lens onto a sheet of paper (like a magnifying glass). The result should be a bright circle with no obstructions. Obstructions in the lens will prevent the meter in the camera from getting accurate information about the scene and if significant enough, prevent viewing through the viewfinder.
You may wish to have the camera & lens professionally cleaned and serviced to repair a mirror or lens issue.
If this was helpful, please rate it as such. Good luck!
My AF point aperture (the red dot one) looks like a little bit blurry after i try to clean the lens in the camera body. how can this happen?
This might be because you accidentally moved the little wheel to the right of the viewfinder. You can simply look in to the viewfinder and move the wheel until it all seems to be in focus again.
I have a red line through my photos.
Answer ID 16497 Why do I sometimes see a faint vertical line in my viewfinder? Why do I sometimes see a faint vertical line in my viewfinder? --> With some DSLR cameras, a normally clear LCD screen is used to display Auto Focus area brackets in the viewfinder. When power is supplied to the screen, you may sometimes see a faint vertical line appear in your viewfinder. This is perfectly normal and is just part of the finely etched circuitry used to power and illuminate the liquid crystal segments of the AF area brackets.
1helpful
Dark, cloudy viewing 35-135mm Sigma lens
The problem sounds like the camera did not reset properly after the last exposure. Minolta deigned the camera to keep the aperture fully open except during exposure.
During exposure it snaps the aperture down to the selected opening, then opens it again to allow enough light for proper focusing. If it did not fully open the blades after the shot, much less light would pass through the lens. The viewfinder would be darker and look murky.
Most likely cause? Dried up lubricants in the camera.
Next likely cause? Teeth broken on a plastic gear.
Get it to a camera repair place. Get estimates first.
8helpful
How to KNOW the light is right 4 an Olympus OM20 Manual camera?
OM-20 was basically a upgraded OM-10 with the manual adapter built in and a number of other refinements.
The viewfinder has LED's to show the shutter speed recommended by the camera's lightmeter for the ISO and aperture selected. It also has an exposure compensation indicator (the +/- symbol) and an indicator for flash ready which doubles up as a post-exposure flash confirmation. There is also the indicator lamp to show manual mode has been selected. OM-10 lacks the manual mode lamp and the +/- indicator.
Like the OM-10, the OM-20 is primarily an aperture priority automatic camera. In this mode you set the ISO film speed, choose which aperture you wish to use (with the ability to use the lens depth of field preview button) and then the camera selects the correct shutter speed. The +/- exposure compensation control allows the user to tell the camera to modify the recommended shutter speed by up to two stops either way.
In manual mode, there is no manual metering. The light meter behaves exactly as it does in aperture priority mode and the viewfinder shows the recommended shutter speed and not the manually selected one. Correct metering is therefore a case of adjusting the aperture first, and then choosing the correct shutter speed indicated in the viewfinder. If the user then decides to select a different shutter speed, then the aperture ring must be adjusted to maintain the correct exposure. For example the aperture is set to f8 and the camera recommends 1/60th of a second. The user decides that a faster shutter speed is required and chooses 1/250th, but the viewfinder remains showing 1/60th. In order to keep the same exposure value the user must open the aperture by two full stops to f4. The camera's light meter will detect the new aperture setting and providing the light on the object is unchanged the viewfinder shutter speed display should now show 1/250th as well to confirm the correct adjustment. Alternatively, the user can choose the shutter speed first by looking at what has been set on the control ring (or by turning the ring to the end of its travel and then counting the clicks from there as all experienced OM users do) and then turning the aperture ring until the shutter speed shown in the viewfinder matches what's been manually set.
It all sounds clumsy and complex but is done far more quickly than I've taken to type this and becomes second nature.
Aperture priority metering is selected on the camera by choosing AUTO on the mode selecter. In this mode the shutter speed ring has no effect and the viewfinder always displays the automatically selected shutter speed.
No color in the viewfinder
ag-456 vf is black and white only.
3helpful
My Nikon N60 35 mm camera shows the fEE message
Your lens is not set to the smallest aperture (highest number). Turn the camera off, rotate the aperture ring so the largest number is lined up with the mark on the top, push the aperture lock tab, and turn the camera back on. The aperture ring is the one closest to the camrea body with numbers like 4, 5.6, 8, 11 etc on it. The largest number will be 16, 22, or 32 for most lenses.  If it still doesn't work, turn off, remove & replace the lens, and recheck the aperture ring setting.
Info doesn't appearin viewfinder
Press the info button.. that button will toggle between the different types of screens, also it does in playback also
Aperture priority malfunction
davidsucklin,
You can use the film lens with the D80, but it it not react to the same settings as it did with the film body, the multiplier factor for the focal length is going to be different and it may be stopped down a bit. When you are shooting in aperture mode are you adjusting your shutter and ISO? The camera and the lens have to be communicating the same info to one another inorder for it to work. First set the camera back to auto mode the check the shot to see the settings (f-stop, shutter speed) test them with different ISO's to see what the camera thinks the settings should be, then go back to manual on the camera and lens and try the shutter priority mode with the aperture ring set at the 2.8 to see if it works then change to Aperture mode with the same settings that can take the picture. If it doesn't work keep in mind som of the older D lenses will drop some functionality (like aperture) in certain configurations. You can verfify compatibilty of your specific lens on Nikon's support site.
randy320sgi
2answers
Need Manual
Display Optical Viewfinder Yes Optical VF Type Optical LCD Viewfinder Yes LCD Size (inches) 1.5 Power Battery Form Factor 2 x AA or 1 x CR-V3 Usable Battery Types Alk. / Lithium disposable, NiMH rechargeable Batteries Included 2 x AA Alkaline disposable Battery Charger Included No Flash Internal Flash Yes No of Flash Modes 4 Flash Modes Automatic, Fill (On), Off, Red-eye reduction Flash Range Description Unknown Ext Flash No Connectivity Video Out Yes Video Mode Switchable Yes External Connections USB 1.1 Other Connection DC In Included Software Unknown OS Compatibility Windows, MacOS Image Storage Usable Memory Types SD/MMC Other Memory Types Built In (8MB) Memory Included (MB) 8.0 Uncompressed Format None CCD Raw Format No Compressed Format JPEG (EXIF 2.1) Movie File Format MotionJPEG (AVI) Image Capture Image Resolution 1280x1024, 640x480 Movie Resolution 320x240 Aspect Ratio 4:3 CCD Sensor (Megapixels) 1.30 CCD Manufacturer Unknown CMOS Movie Audio No Quality Levels 3 Lens Digital Zoom Yes Digital Zoom Values 2x Auto Focus No Manual Focus No Normal Focus Range 120 cm to Infinity
49.0 in to Infinity Max Aperture f/3.0 Aperture Range Description f/3.0 Lens Thread Type None Exposure Number of White Balance Settings 5 White Balance Settings Auto, Sun, Shade, Fluorescent, Tungsten Manual White Balance No Longest Shutter Time 1/20 Shortest Shutter Time 1/2500 Exp Adj Range 1.5 EV Exp Adj Step Size 0.30 EV Metering Modes Auto Spot Metering No Aperture Priority No Shutter Priority No Full Manual Exposure No Self Timer 10 seconds General Model Number 3315 Camera Format Compact Currently Manufactured No Retail Price $99.00 Street Price $105.00 Price Update Date 2003-10-07 Date Available 2002-07-22 Remote Control No Tripod Mount Material Unknown Operating System Windows, MacOS Weight 120 g
4.2 oz Weight With Batteries? No Size 108 x 59 x 36 mm
4.3 x 2.3 x 1.4 in Warranty in Months 12
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
