Question about Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum
Shark steam mop
I took the mop apart to find the steam hose was diconnected from the floor housing with a smaal spring clamp. a long spring fell out and I can"t figure out where it goes .Any help
  • Anonymous Mar 26, 2014
    I was changing the belt and was about to put the swews in when two magnets fell out. Please tell me where they go.
  • Euro-Pro Master
  • 43,501 Answers
The spring slides over the hose to support the hose...
Hereis a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not begetting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Posted on Oct 10, 2010
TAKE APART SHARK S3601
There are two screws under "SHARK" decal, and three under steam mode decal (button that controls three steam options)
Feb 21, 2013 | Shark Professional Steam Pocket Mop -...
My shark steamer is not heating or steaming
I posted this video explaining how to clean the heater core.
http://youtu.be/S4NglGXVv50
Tons of water on the floor might mean that an internal hose or hose clamp has failed. Once you have it apart you can assess and replace the hoses by taking the bad hose to the auto parts store and asking for an appropriate sized replacement.
Dec 18, 2012 | Euro-Pro Shark Steam Mop - Gray/ Purple...
It heats up but no steam
i just fixed mine tonight. it was heating but not releasing steam. i took apart the mop, not the head and found that the tube connecting to the heating element popped off....the spring inside the tube was also haning out. i found the metal clamp that was holding it randomly in there as well. i pushed the spring back in the tube and then pushed the clamped back onto the tubing, then pushed the tubing back onto the heating element then slid the clamp down over the tubing and the heating element and now my shark works great again!!
Mar 26, 2012 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Shark steam mop s3501 no steam
On these steam mops you have to use distilled water, if you use tap water and do not have
a water softner, the feeder tubes that pull the water to create steam will be reduced in size
and clog up. the only other option is to take it apart, and replace the hoses, i used some
small fuel line with spring clamps that i bought at an auto supply, it works! good luck!
Jun 26, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
I pumped my steam mop to get started as I always do. I heard a loud pop and now it won't produce steam and leaks water on the floor.
The mop broke...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
heatman101
Jun 15, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Long spring
The spring goes on the hose to give the plastic tubing some support...
heatman101
Jul 18, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Took apart the s3101 and there is a long spring inside..where's it go. It's not obvious
The long spring goes over the plastic tube that goes to the head to support the tubing...
heatman101
Jun 19, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Shark steam mop
I had the same prob and found this site off google looking for the solution.
I went back to my shark and took out all the screws, some don't feel like they were coming out but it came apart. Take a pair of pliers and release the spring clip holding the hose to the heat nozzle. Then pull off the hose. Then take a paper clip, unkink it so it's sort of straight with a curve to go into the hole . Shove it in and out to clean out the hole. I got my fingers blasted with residual steam so you should let it cool first. But I think the steam bursting out helped clean out the hole. Don't throw it away till after you try that..It worked great after that. All the best, Satch
Oct 09, 2008 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum Logo
374 people viewed this question
Top Euro-Pro Vacuums Experts
Dennis Key
Dennis Key
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
