Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
Display too dim to read
Frigidaire Gallery FEF388WCCD. Everything heats up fine, but you just can't read the temp, or see when the oven is on, etc. Is there a way to adjust the brightness of the display?
  • jrcruncher Jan 05, 2009
    Thanks! Do you know whether these can be installed by the average Joe, or should I hire a service company?
  • 163 Answers
Hi!! you seem to have a bad control board its on the back top panel its shorting out.replace ut and you should be fine..Good luck..
Posted on Jan 04, 2009
  • Boris Chang
    Boris Chang Mar 02, 2014
    Hi. It seems a lot of people have bad control boards. It seems that this was a poorly designed appliance to have so many people complaining they cannot read the display after a few years. A pity.
  • Boris Chang
    Hi. It seems an awful lot of people have bad control boards and cannot read the display after a few years. It's a pity that the manufacturer produced an appliance in this price range with a severely flawed design. Expecting a lay person to take apart their oven and replace and solder etc. etc. is a bit of a stretch. It is likely that hiring a qualified repair technician would probably cost several hundred dollars for parts and labor. Shame on Frigidaire!
Clock light and temp.light fading out.what needs to be fixed
LED clock/temperature light fading an - Appliance Repair Forum
forum.appliancepartspros.com/oven...ranges.../650-led-clock-temperatur...
Aug 20, 2007 - 3 posts - ‎3 authors
The LED clock/temperature/etc control light has been becoming less ... needs to be replaced (board being the oven clock/erc/control board). Control pad temperature light out
Jun 15, 2014
Dim temp lights
Feb 7, 2014
Frigidaire range LED display is dim
Aug 28, 2009
Oven clock & light
1 post
Jun 21, 2009
More results from forum.appliancepartspros.com
Cheap Fix for a Dim Display on an Oven Control Panel ...
Nov 29, 2015 | Whirlpool 30" Self-Cleaning Freestanding...
Lights showing oven temp are too dim to read -- difficult to set oven temp. model feb756cetf self cleaning wall oven
Good Morning Friend,
I understand the control panel is dim and hard to read, on your Frigidaire oven, model# FEB756CETF. Please try resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and set the clock. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 07, 2014 | Frigidaire Ovens
Temp shows 400 but oven is at 300
Is it continues to heat up then its working fine...if it continues to heat pass 400 then your have a thermostat problem and the oven is out of control. I do believe that the display is not an actual reading of the oven temperature, instead it is a reading of where the operator has set the temperature to . I have yet to see an oven with a actual reading temperature display.
Dec 01, 2013 | GE Profile JTP18 Electric Single Oven
Dim temp. light
needs a new clock or find someone to refurb that one
Jun 25, 2009 | Frigidaire FEB27S5A Electric Single Oven
Cannot clear PF light flashing on frigidaire dishwasher
Frigidaire dishwasher will not work at all it has PF blinking
May 27, 2009 | Frigidaire 30 in. Electric Gallery Series...
Oven turn's on, keep's heatings at a higher temp.
This is failed communication between the EOC and the temp sensors located in the oven. i recommend testing the EOC(break point test on the pins) for its operational value and the temp sensors as well. replace any component that doesn't register.
I would also inspect the oven temp sensors for welded harness and fouled housings.
In most cases, this will be a EOC issue.
May 24, 2009 | Frigidaire 30 in. Electric Gallery Series...
Frigidaire Gallery Professional Series - No clock/oven functions
i have an old model of the fridgedare gallery professional series stove. After self cleaning, the ignition sparks for the burners will not come off, they keep clicking and only stops when i pull out the plug. can you help me with this situation?
Nov 01, 2008 | Frigidaire FGB24S5A Gas Single Oven
Oven's digital temp display too dim to read
The electronic control board will have to be replaced
Jun 07, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
657 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
