Question about JVC AV-27820 27" TV
Will the JVC TV model AV-27820 mfg 1997 become obsolete i n February?
    Novelist:
  • 146 Answers
It will still work fine if you have cable or satellite. If you are using an antenna to receive broadcast signal you will need to get a digital converter box from an electronics store like Best Buy. You can get discount coupons from the federal government good for 40 dollars towards the converter. Google "Digital Covnverter Coupon Program" and it should give you a link to the site to apply for up to 2 coupons.
Best wishes
Posted on Jan 04, 2009
Video channel "v" In right hand corner
All depend of the design of the TV and REm CONTROL. See you owner manual or download from www. retrevo.com
God bless you
Oct 18, 2012 | JVC AV-27820 27" TV
JVC AV-27820 turn on the a white line accross middle
Hello
Total failure of vertical sweep occured whic your JVC TV. There are mainly two resons for this fault.Loose soldering terminals of the vertical output IC is the first one. The second one is of failure of the vertical output IC itself. You have to locate this vertical IC. It can be located at the main board. Vertical IC will be screwed on to a metal heatsink to radiate heat from it while it works. You can identify it very easly, if you have knoledge in electronic circuts abd printed circuit boards.
Resolder all the solder terminals of this IC first, by applying a little more solder; without making any solder bridge short in between the close adjecent solder terminals, and see whether it helps you. If not replace it with same type and number. OK.
Oct 08, 2011 | JVC AV-20220 TV
My JCV 1997 TV will not turn on at all I'm missing the power button on the TV it broke and the remote control will not turn it on its been unpluged for month or so . No flaging light just blank. PLEASE...
Push the power button and hold. Check whether lights are ON.
If OK try whether you can keep the switch permanently in pushed
position. Try some paper stuffed tightly.
Otherwise replace the switch.
Aug 11, 2010 | JVC AV-27820 27" TV
White line across center of screen
cold solder in vertical ic or bad.
Apr 03, 2010 | JVC AV-27820 27" TV
Parental lock
i have the same exact problem what i figured out is that i cant watch cable on it but when i hook a vcr to it i can watch movies. but when i hook my dvd player to it the block comes back on. so i hooked my playstation 2 to my vcr and hooked my vcr to the tv and i can watch dvd's that way. thats all i have sorry..
Oct 20, 2008 | JVC AV-27820 27" TV
JVC AV-27820 27
shorted components causes continuous ticking/clicking sound from inside the set! it would really need a shop visit since you have no picture display! if you could trust the service person then it could be worth sending it to a shop!
Dec 06, 2007 | JVC AV-27820 27" TV
JVC Television Model AV 27820
One or more of the electrolytic condensers near the vertical ic are bad
Nov 20, 2007 | JVC AV-27820 27" TV
Jvc AV-36f802 not power up, automaticly shut down within 2 seconds
Hi, You may also want to check the Vertical IC. In some units I've worked on, failure or cold solder in the vertical IC triggers protection. Good luck and cheers.
Aug 15, 2007 | JVC AV-27820 27" TV
JVC AV-27820 27" TV
Im sorry your having this trouble But I cant tell you whats wrong as I havent looked at the set. The problem could be a simple power supply problem or a cold solder connections in the horizontal sweep circuit. If your not a tech this is not a job for an experimenter or tinker . There is hi voltage in these sets even when they are unplugged so you are gonna need to call a pro in to assit you in this repair or geta new one > good Luck
Jun 11, 2006 | JVC AV-27820 27" TV
JVC AV-27820 27" TV
probably some cold solder joints. take your time and check over whole circuit board and re-solder what looks bad.
Jun 10, 2006 | JVC AV-27820 27" TV
Televison & Video Logo
177 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
