Question about Dremel Variable - Speed Multipro Rotary Tool 395
Dremel multipro 9.6v model 780 - Dremel Variable - Speed Multipro Rotary Tool 395
  • 13 Answers
SOURCE: switch
Definitely not Home Depot. Try googling 'dremel model 395 switch', you'll probably come up with something. If not, there's always dremel themselves. This is a current model so there shouldn't be any real problem getting parts.
Sorry, don't know about installation, but I can tell you most of these dremels are real easy to fix in general, not complicated at all.
Posted on Jul 29, 2008
  • 3 Answers
SOURCE: worn front bearing on Dremel Multipro
Sorry, here is a link to that picture, full sized.
Grease Monkey 626
Posted on Aug 24, 2009
  • 165 Answers
SOURCE: Dremel MultiPro Model 395 was used to cut out
Drywall dust has ruined your tool. It seizes up bearings and bushings like you wouldn't believe.
Posted on Feb 28, 2010
  • 468 Answers
SOURCE: How do i take the bit off of a dremel multipro
unscrew the collet nut, and then if it's still stuck, tap the end of the bit on the table or something solid. It'll come loose then.
Posted on Mar 16, 2010
  • 10865 Answers
SOURCE: How do I attach tools to my Dremel?
hello. You loosen the arbor at the base of the shaft closest to the tool. There is a tiny wrench in the kit that came with the dremel, or you can use a pair of pliers to loosen it. Joe
Posted on Apr 17, 2010
How do you attach "multipurpose cutting kit model 565" to the dremel multipro model 395?
Remove the collet nut and collet then unscrew the sealing cap (black plastic ring), this has the same thread as the inner of the multi kit tool, so just screw on the tool then replace the collet and nut
Sep 14, 2010 | Dremel 395 Variable Speed Multipro Rotary...
Apr 17, 2010 | Dremel Variable - Speed Multipro Rotary...
Flex shaft attachment
Takes an adapter to screw onto the nose of the Dremel. The shaft itself is gripped by the correct size collet tightened as you would any bit.
Mar 02, 2010 | Dremel 225 Multipro Flex - Shaft...
Dremel Model 395 Type 3 Plastic Drive Shaft Connection broke into pieces. Replacement needed.
You can call Dremel direct at 1-800-437-3635 and order the part. Let me know if you need more information.
Apr 14, 2009 | Dremel 395 Variable Speed Multipro Rotary...
Dremel model 365 type 1 collet lock latch is worn out.
I would go to Dremel.com or call their help line at 1-800-437-3635 and speak with one of their specialists.
Feb 24, 2009 | Dremel Variable - Speed Multipro Rotary...
I need a coupling
Call Dremel at 1-800-275-2052 and they can help with parts and schematicsHope this helps. Dave
Nov 08, 2008 | Dremel Variable - Speed Multipro Rotary...
Switch
Jul 20, 2008 | Dremel Variable - Speed Multipro Rotary...
Dremel Variable - Speed Multipro Rotary Tool 395 Logo
106 people viewed this question
Top Dremel Tools & Hardware - Others Experts
Mike
rodhep
Level 1 Expert
Are you a Dremel Tool and Hardware - Other Expert? Answer questions, earn points and help others
