Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
My GDO only goes down
The opener thinks the door can keep going down when there isn't any more to go?
  • boydpga Jan 04, 2009
    I have a garage door that the drive only goes down. It almost buckled the system when the garage door was down and the drive kept trying to go farther.
  • Joseph Chapman
    Joseph Chapman May 11, 2010
    What kind of operator (box that closes the door) do you have?
    Champion:
  • 244 Answers
Sounds like down travel limit has to be backed off . if this always happened, chain may be out of sync.
Posted on Jan 15, 2009
My garage door opener has power but it doesn't work, sensors got power too, at times it seams to work but it only goes in one direction
If the GDO will only open the door, it could still be the door sensors. They may be slightly out of alignment, or there may be some spiderwebs or debris blocking the sensors. Readjust them by eye.
An easy way to tell for sure is to close the door, if it does not move or goes part way and reopens (caused by the sensors) the light on the GDO will flash 5 times to let you know the sensors have been activated.
On the older machines, there used to be a plug where the wire connected to the sensor. They would corrode due to dampness/moisture. If it is the older style with the plug, replace the sensors.
Also, if the sensors are to blame for your problem. pushing and holding the wall button will close the door fully.
Good luck.
Jan 04, 2011 | Sears Craftsman LiftMaster Chamberlain...
My garage door will only open a little over 5 feet
Close the door and release the GDO from the door by pulling the release handle. Operate the machine without the door attached. Does the trolley go to the full open position?? If so check the door.
Operate the door manually. If it is very heavy and wants to close the door is out of balance.
If the door doesn't work correctly, the GDO will not work. Regardless of the type of door, it should be easy to open manually. Unballanced doors are dangerous. The counterbalance springs may be broken or just require adjusting. The door jamming or hitting an obstruction is another thing to consider. If the door hits an object going up, it will stop, going down it should reverse.
If the door is good, and the machine runs full cycle without the door attached, reattach the door and adjust the "Up Force" adjustment on the end of the machine with the wiring. With proper operating equipment (door, GDO), it should be no more than 6 O'clock. Any higher than that, and the door likely requires servicing.
Dec 18, 2010 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain chain gdo. goes all the way up until it hits gdo box and gets stuck. unstick it and it works for awhile then it happens again
Unstick it and close the door. While the door is closed locate the 'up limit' control on the side of the motor unit. Turn this control 2 full turns in the opposite direction of the arrow printed on the cover. Should be good to go.
Oct 15, 2010 | Sears Craftsman LiftMaster Chamberlain...
My older Craftsman garage door opener comes down about 6" & then goes back up. I just replaced all the rollers o& the opener worked fine. Then I tightened the chain on the opener & it worked ok...
If the main light flashes 10 times when the door goes back up it is a door sensor problem. You chain should sag just a little. If you tighten it too much it will click as it goes over the sprocket. You can increase the down force which is an adjustment near where all those white wires go. A 1/4 turn should be enough. Release the door from the opener and operate it by hand. It should move freely and when you have the door approximately waist high it should stay put. Neither raising nor closing.
Jan 11, 2010 | Sears Craftsman LiftMaster Chamberlain...
The garage door is closed and wont open, it beeps and all the LED's light up. there is no obstructions. I think that it keeps to try and shut but already is. Its a securalift GDO - 7 V1
Tries changes batteries in the remote,unplug the main operation motor,replug it,see if it reset it self.This a temp.fix,call the mamfucture for repair or replacement.
Oct 26, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman GDO 1/2 HP - Remotes not working after storm
sounds like it blew the reciever crystal buy another and return the motor thats fried 4 refund
Jul 29, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman GDO - Remotes not working
I think this is an easier way to program. Press and hold the button on the remote and then press and immediately release the smart/learn button on the rear of the motor unit. Do this for each remote you have.
Jul 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
Lift-Master GDO goes up, not down
If the door operates freely without any binding, while operating it manually then It would appear that the obstruction sensor mounted across the doors path is ether out of alignment, lens dirty,or malfunctioning
Feb 21, 2009 | liftmaster Chamberlain Garage Door Opener...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
50 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
