Question about Sylvania 6842THG 42 in. Plasma HDTV
Sylvania 42 in 6842THG
I read your solution to the power shutting off. If i purschase the power supply board BL0700M01032, will I be able to replace/do the labor myself? Or should I have a professional do it?
  • Crystal Conyers
    Crystal Conyers Apr 01, 2009
    it turns on an stay on for 5 to 10 min then turns its self off and then it does it ovre and over again
Its actually very simple.If you can set-up a new computer you can do this too. It is just a bunch of connectors and screws. Take a picture of the wiring and then reinstall them one byone.
Posted on Jan 07, 2009
Where can I get the power Supply Board BL0700M01032
Posted on Jul 28, 2009
Won't turn ON. Found F601 fuse blown on power supply/inverter board. What's the most likely culprit?
Emerson BA17F1F0102 Power Supply Repair Kit LC320EM2
$19.94 - ‎In stock
This Emerson BA17F1F0102 Power Supply Repair Kit LC320EM2 ... board. If the TVhas no power it is most likely because of a blown fuse and failure of other preceding components. ... I tested F601, Q600, R602, 608 and 611, and found them to be bad. ...Power Supply / Inverter Board - Joseph A. on March 4th, 2015.
Common TV Repair for Emerson, Sylvania, Philips ...
? 5:35
Oct 11, 2013 - Uploaded by Tampatec
... LCD TV repairs for Emerson, Sylvania, Philips, Magnavox,blowing fuses "no power" i recommend a TV service LCD repair kit at ... powersupply power-supply "power supply" powerboard "power board" part2 part 2 pt2 ...
What Causes a Blown Fuse in TV Sylvania LCD - YouTube
? 15:31
Jan 01, 2016 | Televison & Video
Sylvania lc195sl9a no power only led blink
my tv was in ame condition i replace the board BA8AFOGO4017 and tv turn on
Mar 05, 2013 | Sylvania A8AN2UH Digital Board...
Sylvania Model 6632LG shuts down
Check power supply board and inverter board for faulty solder connections and visually inspect electrolytic capacitors for signs of stress or failure. Bulging tops, black or brown crusty material oozing out of them, are the most common. Replace those that are visibly faulty with high ripple current types.
If that does not resolve it, the next step is to test the transistors in the 24 volt section and inverter section primarily. Recapping the power supply 24 volt section is prudent regardless of physical appearance of the electrolytic capacitors.
Feb 07, 2012 | Sylvania 6632LG 32 in. LCD HDTV
Tv turns on and stays on for a 30 second then shuts down.
You need to check the output voltages of the power supply to see which one goes off. It may be due to short circuits some where,if otherwise the power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like, to buy a whole refurbish power supply board for the replacement.
Hoping this will help in solving the problem....
Aug 05, 2011 | Sylvania LC220SS1 22 in. LCD TV
I have a Sylvania LC370SS8 (37" LCD + DVD) TV. It will stay on for about an hour, then it shuts itself off. The power light flashes while it's off (for about 5-10 minutes) then it comes back on... and...
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Sep 25, 2010 | Sylvania LC370SS8 Television
Sylvania 6842pe blew fuse, replaced fuse, and nothing,no lights, noise, nada. replaced power supply board with the chord attattchment and still no power, no lights, and no noise. Was wondering could it be...
Yes,replaced all the boards that related to the power supply.Useally completely dead,it effect all the ICS in the boards,never able to tell which boards.U are not a tv tech.don't do this everyday's will not have skills or any idea which board is dead.
Apr 06, 2010 | Sylvania 6842-PEM 42 in. EDTV-Ready Plasma...
Sylvania LC320SS8 32 in. LCD Television - Will not turn on
U have power on 10 mins,than is not the power supply board.Ur Tuner board is dead replaced that board.Tries websites, to buy a refurbish tuner signal board.
Feb 09, 2010 | Sylvania LC320SS8 32 in. LCD Television
When i turn my 42 inch plasma sylvania on, it makes a sharp high pitched squeal, then shuts off. it does this repeatedly, whats the problem, and how do i fix it?
You have a short on one of the drive boards making the power supply squeal. You will have to unplug each board until the squeal is no longer there. Which ever board it is will have to be replaced. Thanks for using fixya.
Nov 26, 2009 | Sylvania 6842PE 42 in. HD-Ready Plasma...
Power problem
T v popped ,it comes on then goes right back off power will not stay on
May 09, 2008 | Sylvania 6842THG 42 in. Plasma HDTV
Sylvania 6842THG 42 in. Plasma HDTV Logo
885 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
