Question about Dishwashers
Door slams down
The door to my washer slams down when opened. There must be a spring or other device that's broken. Where can i find replacement parts? Thanks!
  • erica graber May 11, 2010
    is it a kitchenaid
    Sergeant:
    Champion:
  • 338 Answers
You need to replace the link assemble. is should come with a rope looking thing and wheels/ pulleys.
Posted on Jan 04, 2009
Fuse blew as garage door was closing.Door slammed shut ,now only goes up 2inches then closes when switch touched !!!
Sounds like it may be a broken spring. Look above the door at the coils on the steel rod and see if there is a separation of the torsion springs. Or if extension spring it will be hanging down on one side above the tracks. If it is a broken torsion spring I would advise calling someone with experience. If not what is the make and year of opener?
Aug 16, 2011 | liftmaster Chamberlain Garage Door Opener...
When i open the door it felt like a spring broke. i have to hold the door from slamming open now
That would be a broken door spring, and it's best to replace them in pairs.
On some models, this can be a difficult job.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Good luck.
May 25, 2010 | KitchenAid Microwave Ovens
The door on our dishwasher no longer opens gradually, it slams to the ground. I think it is the hinge or spring mechanism but I don't know what I need to replace.
You need to open the washer and then remove the side pannels (sometimes you must first unscrew fro back and the front bottom of the washer). Some have sprinngs that just unhooked and some have springs and nylon rope etc attached to the door spring that breaks). Only by opening will you be able to physically see the problem.
Mar 26, 2010 | Dishwashers
My machine wont start ,unless i really have to slam the door real
Either the switch striker/actuator on the door is worn or the door lock/switch assembly on the right side of the door opening is faulty. It is recommended to replace both parts when one is faulty or worn. The door lock/switch assembly is part number 1094190 and costs about $55. The switch striker/actuator is part number 906446 and costs about $5.
Door Lock/Switch Replacement Procedure
  • Unplug the machine.
  • Open the machine's door.
  • Locate the retainer spring of the seal boot retaining hoop at the bottom of the door opening.
  • Stretch the retainer spring apart then remove the retaining hoop.
  • Ease the edge of the seal boot off the lip of the door opening near the door lock/switch assembly. Remove enough of the seal boot to gain access to the door lock/switch assembly behind the front panel of the washer. Be careful not to tear the seal boot. It will cause water to leak out of the machine.
  • Remove the three screws securing the door lock/switch assembly to the front panel.
  • Slightly lift the door lock/switch assembly, pull it away from the front panel then pull it out of the machine.
  • Disconnect the wiring harness and connect the new door lock/switch assembly.
  • Reinstall the new door lock/switch assembly and the seal boot in reverse order of the procedure above.
Jan 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Door drops hard and i have an error code 7 -
The door slamming open is a broken spring/springs. They are very easy to replace - remove the screws holding the dishwasher in... pull out slightly and replace with good ones on the sides.
Can you clear the error code by shutting off power to it?
(Mdl # helps)
Dec 01, 2009 | KitchenAid Dishwashers
Door spring broken
the door links are broken need to get new ones and replace
Nov 04, 2009 | Kenmore Elite 45986 Front Load Washer
Door springs dont stop door from opening slowly and it slams to the floor
Hi Thanks For The Question. The Springs Are Broken Under The Door, Remove The Bottom Panel .One Spring Each Side Replace Thanks The Appliance Doc
Oct 03, 2008 | KitchenAid Dishwashers
Panasonic inverter door won't shut, light stays on.
Thanks for the tips - here is what I did (my wife calls me the Canadian McGuyver!) After taking off the plastic frame (using instructions in Solutions noted above) I used the metal part of a key ring and hooked one end to the spring and looped it around the thick finger/protrusion at the bottom. _197.jpg
Jan 28, 2008 | Microwave Ovens
Door sensor broken?
Sounds like you, indeed, have a broken door latch. If the latch is not able to lock successfully, it will not go into any wash cycle and will exhibit the symptoms you are describing. The door was designed to be closed gently, not slammed or forced. To replace, you will need to do the following: 1. Unplug the machine. 2. Remove the bottom kick plate. 3. Remove the rubber door boot from the around the door opening. There should be a wire hoop holding it into a groove with a small tension spring located at the bottom of the door opening. Feel around the rubber lip and locate the tension spring. Stretch this spring and pull the wire hoop from the groove. 4. Remove the rubber boot from the outer seal and push towards the inside of the wash tub. This will give you access to the inside of the machine casing. 5. The door latch is located inside the casing on the right hand side. There are three screws holding it in from the outside and a wiring harness and retaining clip holding it from the inside. Use care when removing the wires from the old latch. The wires are small and can break. I hope this leads you in the right direction. Let me know if you need any further advice.
Jun 07, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Dishwashers Logo
285 people viewed this question
Top Dishwashers Experts
